Product
HP DesignJet Z2100 44" A0 Large Format Printer
You Buy. You Try. You Decide!
Quicklinx: 85SGWS00 Mfr#: Q6677D#B19
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired
Technology: Ink-jet
Hurry, only 1 left in stock!
£2,742.54 ex VAT
£3,291.04 inc VAT
HP's 8-ink Designjet delivers superior colour accuracy and consistency with the first-ever embedded spectrophotometer. Produce vivid, large format prints (up to 610 mm or 1118mm) in colour or black-and-white with 8 Original HP Photo Inks.
  • High-impact, long-lasting color prints
    Produce vivid, high-quality color and black-and-white prints that impress your customers.Get rich, dark blacks on matte and glossy papers with matte black and photo black HP Photo Inks.8 Original HP Photo Inks deliver durable prints in color and blackand-white lasting up to 200 years.Save time with borderless printing and fast-drying HP Photo Inks.
  • Easy color calibration and profiling
    Generate custom ICC profiles and achieve color accuracy, consistency with the embedded spectrophotometer.See consistent print-to-print color regardless of fluctuating environmental conditions with HP technologies.Boost color accuracy-complete coverage of SWOP, ISO, GRACOL, 3DAP, EUROSCALE, TOYO, and FOGRA gamut.Supported by industry leaders, including EFI, X-Rite, GMG, ColorByte, Adobe, Creo, and Apple.
  • Unattended operation with HP technologies
    Optimize performance, ink usage-automatic servicing routines help prevent nozzle clogging, reduce media waste.Save time-HP Printer Utility software provides printer status, desktop alerts, and automatic updates.Get assistance-HP Color Center tool effortlessly guides you through color management and printing.Eliminate trial and error with real-time layout and orientation preview.
HP DesignJet Z2100 - large-format printer - colour - ink-jet
Printer Type
44" large-format printer - ink-jet - colour
Stationary
86 kg
English, German, French, Italian, Spanish / Europe
Ink Palette Supported (Colours)
8-ink
Max Media Size
Roll (111.8 cm x 91.4 m)
Max Media Size (Custom)
1117 mm
Print Speed
Up to 2 min/page - colour draft , Up to 4.2 min/page - colour normal , Up to 9.8 min/page - colour best
Max Resolution (B&W)
2400 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
USB, LAN
RAM Installed (Max)
128 MB
Hard Drive
80 GB
Language Simulation
PCL 3
Media Type
Glossy photo paper, matt photo paper, bond paper, matte proofing paper, semi-gloss proofing paper, backlit paper, high-gloss proofing paper, coated paper, heavy-weight coated paper, semi-gloss photo paper, self-adhesive vinyl, satin photo paper
Print server - Ethernet, Fast Ethernet
AC 120/230 V
Apple MacOS X 10.2, Microsoft Windows 2000 / XP, Apple MacOS X 10.3, Apple MacOS X 10.4 or later
Microsoft Certification
Compatible with Windows 7
1 year warranty
177 cm x 69 cm x 104.7 cm
Printer Type
Stationary
Printer
8-ink
Nozzle Configuration
8 x 1056 nozzles
Minimum Ink Droplet Size
4 pl
Ink Cartridge Configuration
8 individual ink tanks; 2 colours per print head
Ink Type
HP Vivera Inks
Print Speed
Wired
USB, LAN
2400 x 1200 dpi
2400 x 1200 dpi
Language Simulation
PCL 3
RAM
RAM Installed (Max)
128 MB
Storage
Hard Drive
80 GB
Media Handling
Media Type
Max Media Size
1117 mm
Max Printing Length
91 m
Media Weight
500 g/m²
Print server
Expansion Slots
1 x EIO
1 x LAN - RJ-45 , 1 x USB 2.0
Spindle, stand
1 x USB cable
Consumables Included
1 x ink cartridge (light cyan) - 69 ml , 1 x ink cartridge (light magenta) - 69 ml , 1 x ink cartridge (light grey) - 69 ml , 1 x ink cartridge (photo black) - 69 ml , 1 x ink cartridge (cyan) - 69 ml , 1 x ink cartridge (magenta) - 69 ml , 1 x ink cartridge (yellow) - 69 ml , 1 x ink cartridge (matte black) - 69 ml
Media Included
Roll of media
CSA, VCCI, BSMI, GOST, BSMI CNS 13438 Class B, CCC, DOC, PSB, MIC, MOC, FCC, IEC 60950-1, EN 60950-1
Power supply - internal
AC 120/230 V
Frequency Required
50/60 Hz
200 Watt
Power Consumption Stand by / Sleep
43 Watt
System Requirements Details
MacOS X 10.2 - PowerPC G4 RAM 1 GB - HD 2 GB , MacOS X 10.3 - PowerPC G4 RAM 1 GB - HD 2 GB , MacOS X 10.4 or later - PowerPC G4 RAM 1 GB - HD 2 GB , Windows 2000/XP - Pentium 4 - 3 GHz - RAM 1 GB - HD 2 GB
Environmental Standards
ENERGY STAR
Limited warranty - parts and labour - 1 year - on-site - response time: next business day
5 °C
20 - 80%
Sound Emission (Idle)
29 dBA
Sound Emission (Operating)
49 dBA
177 cm
69 cm
104.7 cm
86 kg
Width (Shipping)
196.5 cm
Depth (Shipping)
78 cm
Height (Shipping)
0.2 cm
Weight (Shipping)
123 kg
85SG HP Bright White Inkjet Paper-914 mm x 45.7 m In Stock £18.26
85SG HP Heavyweight Coated Paper-610 mm x 30.5 m (24in x 100ft) In Stock £25.38
85SG HP Coated Paper-1067 mm x 45.7 m (42in x 150ft) In Stock £36.29
Type: Printer
Output Type: Colour
Technology: Ink-jet
Max Print Speed: 0.5ppm
Brand: HP
Price Range Ex VAT: 1500+
