HP DesignJet T930 36" Colour InkJet PostScript Printer
Quicklinx: BT6VWS00 Mfr#: L2Y22A#B19
Enhance your CAD and GIS projects with professional-quality prints. Stay organised and on task with features that streamline printing workflows and boost productivity. Easily manage and secure your HP DesignJet printer.
  • QUALITY – Your projects, presented at their best
    Six Original HP inks produce a wide color gamut ideal for color graphics.Original HP gray and photo black inks achieve precise line accuracy, dark blacks, and true neutral grays.Make your architectural prints shine with professional, high-resolution graphics – opt for Adobe PostScript .Communicate with precision-produce plans, drawings, and maps with fine line quality, and up to 2400 dpi.
  • EFFICIENCY-Productive printing for demanding teams
    Stay organized and on task-the integrated 50-page output stacking tray delivers flat, collated prints.At this print speed, you can get right back to work-see A1/D-size prints delivered in 21 seconds.Print efficiently-parallel file processing with 64 GB virtual memory (based on 1.5 GB RAM).Print from your mobile device/USB drive with HP Mobile Printing; add features with HP AiO Printer Remote.
  • SECURITY-Easily, confidently manage your printer
    Print without interruption-91.4-m (300-ft) media roll and Original HP ink cartridges up to 300 ml.Safeguard information with security protocols like IPSec, 802.1x, SNMPv3, PIN printing, and other options.Easily configure and manage your printer from the comfort of your desk with HP Embedded Web Server.Integrates easily with your other office devices-iOS and Android compatibility with HP Mobile Printing.
HP DesignJet T930 PostScript - large-format printer - colour - ink-jet
Printer Type
36" large-format printer - ink-jet - colour
87 kg
English, German, French, Italian, Spanish / Europe
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
6-ink - cyan, magenta, yellow, photo black, pigment matte black, grey
Max Media Size
Roll (91.4 cm x 91.4 m)
Min Media Size (Custom)
210 mm x 279 mm
Max Media Size (Custom)
914 mm x 91.4 m
Print Speed
Up to 0.35 ppm - draft - ANSI D (559 x 864 mm)
Max Resolution (B&W)
2400 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
Cutter
Gigabit LAN, USB 2.0 host
AirPrint Enabled
RAM Installed (Max)
1.5 GB
Hard Drive
320 GB
Language Simulation
PCL 3, PostScript 3, HP RTL, CALS G4, HP GL/2, TIFF, PDF 1.7, URF
Media Type
Plain paper, photo paper, tracing paper, glossy photo paper, matt photo paper, bond paper, film, backlit paper, translucent bond paper, coated paper, heavy-weight coated paper, semi-gloss photo paper, high-gloss photo paper, matte film, vellum paper, polyester film, self-adhesive vinyl, satin photo paper, self-adhesive paper
Print server
Printer Features
Print from mobile device, 64GB virtual memory
Apple MacOS, Microsoft Windows, Windows 10
139.9 cm x 91.6 cm x 111 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
9632 nozzles
Minimum Ink Droplet Size
9 pl (black), 6 pl (colour)
Ink Cartridge Configuration
6 cartridges (1 each: cyan, magenta, yellow, grey, photo black, matte black)
Print Speed
Wired
AirPrint Enabled
2400 x 1200 dpi
2400 x 1200 dpi
Language Simulation
Cutter
Printer Features
RAM
RAM Installed (Max)
1.5 GB
Storage
Hard Drive
320 GB
Media Handling
Media Type
Max Media Size
210 mm x 279 mm
914 mm x 91.4 m
Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI E (864 x 1118 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 91.4 m), 914 x 1219 mm, 210 x 279 mm, 210 x 914 mm
Media Thickness Range
Up to 0.5 mm
Media Feeders
1 x manual - 1 roll - Roll (91.4 cm x 91.4 m)
Output Trays Capacity
50 sheets
Print server
Security Protocols & Features
IPsec, 802.1x
1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Media bin, stand, stacking tray, spindles
Consumables Included
1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (grey) , 1 x ink cartridge (photo black) , 1 x ink cartridge (matte black) , 1 x printhead
CSA, VCCI, GOST, CCC, PSB, FCC, IRAM, RoHS, EN 60950-1, KCC, WEEE, ICES, REACH, FSC, LVD, EuP, EMC Class B, PEFC, IPv6 Ready, China RoHS, ACMA
Power supply - internal
Frequency Required
50/60 Hz
120 Watt
Power Consumption Sleep
5 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
5 °C
20 - 80%
Sound Emission (Idle)
39 dBA
Sound Emission (Operating)
47 dBA
139.9 cm
91.6 cm
111 cm
87 kg
Width (Shipping)
150 cm
Depth (Shipping)
78.1 cm
Height (Shipping)
81.5 cm
Weight (Shipping)
120 kg
