Enhance your CAD and GIS projects with professional-quality prints. Stay organised and on task with features that streamline printing workflows and boost productivity. Easily manage and secure your HP DesignJet printer.
QUALITY – Your projects, presented at their best
Six Original HP inks produce a wide color gamut ideal for color graphics.Original HP gray and photo black inks achieve precise line accuracy, dark blacks, and true neutral grays.Make your architectural prints shine with professional, high-resolution graphics – opt for Adobe PostScript .Communicate with precision-produce plans, drawings, and maps with fine line quality, and up to 2400 dpi. -
EFFICIENCY-Productive printing for demanding teams
Stay organized and on task-the integrated 50-page output stacking tray delivers flat, collated prints.At this print speed, you can get right back to work-see A1/D-size prints delivered in 21 seconds.Print efficiently-parallel file processing with 64 GB virtual memory (based on 1.5 GB RAM).Print from your mobile device/USB drive with HP Mobile Printing; add features with HP AiO Printer Remote. -
SECURITY-Easily, confidently manage your printer
Print without interruption-91.4-m (300-ft) media roll and Original HP ink cartridges up to 300 ml.Safeguard information with security protocols like IPSec, 802.1x, SNMPv3, PIN printing, and other options.Easily configure and manage your printer from the comfort of your desk with HP Embedded Web Server.Integrates easily with your other office devices-iOS and Android compatibility with HP Mobile Printing.
- HP DesignJet T930 PostScript - large-format printer - colour - ink-jet
- Printer Type
- 36" large-format printer - ink-jet - colour
- 87 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 6-ink - cyan, magenta, yellow, photo black, pigment matte black, grey
- Max Media Size
- Roll (91.4 cm x 91.4 m), 914 x 1219 mm
- Min Media Size (Custom)
- 210 mm x 279 mm
- Max Media Size (Custom)
- 914 mm
- Print Speed
- Up to 0.35 min/page - draft - ANSI D (559 x 864 mm)
- Max Resolution (B&W)
- 2400 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Cutter
- Interface
- Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- RAM Installed (Max)
- 1.5 GB
- Hard Drive
- 500 GB
- Language Simulation
- PCL 3, PostScript 3, HP RTL, CALS G4, HP GL/2, TIFF, PDF 1.7, URF
- Media Type
- Plain paper, photo paper, tracing paper, glossy photo paper, matt photo paper, bond paper, film, backlit paper, translucent bond paper, coated paper, heavy-weight coated paper, semi-gloss photo paper, high-gloss photo paper, matte film, vellum paper, polyester film, self-adhesive vinyl, satin photo paper, self-adhesive paper
- Networking
- Print server
- Printer Features
- Hard Disk Drive Encryption, print from mobile device, 64GB virtual memory
- System Requirements
- Apple MacOS, Microsoft Windows, Windows 10
- 1-year warranty
- 139.9 cm x 91.6 cm x 111 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 9632 nozzles
- Minimum Ink Droplet Size
- 9 pl (black), 6 pl (colour)
- Ink Cartridge Configuration
- 6 cartridges (1 each: cyan, magenta, yellow, grey, photo black, matte black)
- Print Speed
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 2400 x 1200 dpi
- 2400 x 1200 dpi
- Cutter
- Printer Features
RAM
- 1.5 GB
Storage
- Hard Drive
- 500 GB
Media Handling
- Media Type
- Max Media Size
- 210 mm x 279 mm
- 914 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI E (864 x 1118 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 91.4 m), 914 x 1219 mm, 210 x 279 mm, 210 x 914 mm
- Max Printing Length
- 91.4 m
- Media Thickness Range
- Up to 0.5 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (91.4 cm x 91.4 m)
- Output Trays Capacity
- 50 sheets
- Networking
- Print server
- IPsec, 802.1x
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Included Accessories
- Media bin, stand, stacking tray, spindles
- Consumables Included
- 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (grey) , 1 x ink cartridge (photo black) , 1 x ink cartridge (matte black) , 1 x printhead
- CSA, VCCI, GOST, CCC, PSB, FCC, IRAM, RoHS, FIPS 140-2, EN 60950-1, KCC, WEEE, ICES, REACH, FSC, LVD, EuP, EMC Class B, PEFC, IPv6 Ready, China RoHS, ACMA
- Power Device
- Power supply - internal
- Frequency Required
- 50 Hz
- 120 Watt
- Power Consumption Sleep
- 5 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Idle)
- 39 dBA
- Sound Emission (Operating)
- 47 dBA
- 139.9 cm
- 91.6 cm
- 111 cm
- 87 kg
- Width (Shipping)
- 150 cm
- Depth (Shipping)
- 78.1 cm
- Height (Shipping)
- 81.5 cm
- Weight (Shipping)
- 120 kg
