HP DesignJet T830 36" Colour InkJet Multifunction Printer
Quicklinx: BT6RWS00 Mfr#: F9A30A#B19
Type: Printer / copier / scanner
Functionality: Copier, Printer, Scanner
Output Type: Colour
Wireless Capability: [N/A]
Technology: Ink-jet
Hurry, only 2 left in stock!
£3,540.79 ex VAT
£4,248.94 inc VAT
This is multifunction, reinvented – a robust, compact 91.4 cm Wi-Fi MFP with a built-in scanner at an unbeatable price. Ideal for the studio or the construction site, this easy-to-use MPF enhances team collaboration with mobile printing/scanning.
  • CONVENIENT – Fast, agile, intuitive print/scan/copy
    Enjoy easy installation in the office, construction job site with the most compact 36-in large-format MFP.Easily print project sets and PDF documents with HP Click printing software.Anyone can print smoothly from a smartphone or tablet with HP Mobile Printing.Fit your print volume – choose from a variety of 40/130/300-ml colour and 69/300-ml black HP ink cartridges.
  • TRUSTED – HP DesignJet quality and reliability
    Get HP DesignJet quality also in small-format sizes – print half-size documents with 50-sheet A4/A3 input tray.Achieve precise lines up to 0.1% line accuracy, up to 2400 dpi, and high contrast – HP Bright Office Inks.Smart scanning technology protects originals from damage when scanning and obtains precise colours.Reinforced design and strong legs for easy transport and use at the job site.
  • COMMUNICATION – Immediately share meeting results
    Use built-in scanner to copy and distribute sketches and hand-annotated drawings to peers/partners right away.Share drawings immediately – scan/email from front panel, use HP Smart app to email contacts, post to cloud.Easily link your computer, smartphone, or tablet to the printer with Wi-Fi Direct.No learning curve – with the intuitive design of a single touchscreen, you can scan, copy, and share instantly.
HP DesignJet T830 - multifunction printer - colour
36" multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 0.42 min/page (mono) / up to 0.42 min/page (colour)
Max Printing Resolution
Up to 2400 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Scanning
600 x 600 dpi
Original Size
127 x 127 mm (min) - 914 x 2770 mm (max)
Media Size
127 x 127 mm (min) - Roll (91.4 cm x 45.7 m), 914 x 1897 mm (max)
Media Type
Recycled paper, photo paper, coated paper, bond paper, film, vellum paper, heavy-weight paper, glossy photo paper, satin photo paper, semi-gloss photo paper
Standard Media Capacity
1 roll
Connection Availability
Gigabit LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to network, automatic cutter
AC 120/230 V (50/60Hz)
140.3 cm x 62.9 cm x 115.5 cm
62.5 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
1376 nozzles
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, pigment black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Minimum Ink Droplet Size
6 pl
Printer Drivers / Emulations
TIFF, HPGL/2, HP-RTL, PCL 3 GUI, CALS G4, URF
Scanning
Scan Element
CIS
Optical Resolution
600 x 600 dpi
Colour Depth
24-bit
Document & Media Handling
Min Original Size
127 x 127 mm
Max Original Size
914 x 2770 mm
Min Media Size
127 x 127 mm
Max Media Size
Other
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), ANSI B (Ledger) (279 x 432 mm), 330 x 482 mm, ANSI C (432 x 559 mm), ANSI E (864 x 1118 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 45.7 m), 210 x 279 mm, 914 x 1897 mm
1 roll
Input tray - 1 roll
Speed Details
Printing: 25 sec (A1) , Printing: 25 sec (D) , Scanning: up to 38.1 mm/sec - colour , Scanning: up to 114.3 mm/sec - B/W , Printing: up to 1.36 ppm (A1)
1 x Gigabit LAN - RJ-45
Operating System Support
Apple Mac OS, Windows 8
Software Included
Drivers & Utilities
35 Watt
Power Consumption Sleep
3.5 Watt
Stand, spindles
Consumables Included
1 x printhead , 1 x Cartridge (colour (cyan, magenta, yellow, black)) - HP 728
CSA, VCCI, GOST, CCC, EMC, PSB, FCC, IRAM, RoHS, EN 60950-1, KCC, WEEE, ICES, REACH, LVD, IPv6 Ready
ENERGY STAR Certified
140.3 cm
62.9 cm
115.5 cm
62.5 kg
Shipping Width
157.8 cm
Shipping Depth
57.5 cm
Shipping Height
64.6 cm
Shipping Weight
137 kg
Sound Emission
48 dBA (operating)
5 °C
20 - 80%
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: 914 x 1897 mm
Max Paper Size: Roll (91.4 cm x 45.7 m)
Brand: HP
Price Range Ex VAT: 1500+
