This is multifunction, reinvented – a robust, compact 91.4 cm Wi-Fi MFP with a built-in scanner at an unbeatable price. Ideal for the studio or the construction site, this easy-to-use MPF enhances team collaboration with mobile printing/scanning.
CONVENIENT – Fast, agile, intuitive print/scan/copy
Enjoy easy installation in the office, construction job site with the most compact 36-in large-format MFP.Easily print project sets and PDF documents with HP Click printing software.Anyone can print smoothly from a smartphone or tablet with HP Mobile Printing.Choose from 130/300 ml HP ink cartridges to fit your print volume, large supplies can reduce interventions. -
TRUSTED – HP DesignJet quality and reliability
Get HP DesignJet quality also in small-format sizes – print half-size documents with 50 sheet A4/A3 input tray.Smart scanning technology protects originals from damage when scanning and obtains precise colours.Reinforced design and strong legs for easy transport and use at the job site.Redesigned stand reduces C02e up to 197 tons/year by units sold. -
COMMUNICATION – Immediately share meeting results
Use built-in scanner to copy and distribute sketches and hand-annotated drawings to peers/partners right away.Easily link your computer, smartphone, or tablet to the printer with Wi-Fi Direct.Share drawings immediately – scan/email from front panel, use HP Smart app to email contacts, post to cloud.No learning curve – with the intuitive design of a single touchscreen, you can scan, copy, and share instantly.
- HP DesignJet T830 - multifunction printer - colour
- 36" multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Up to 0.42 min/page (mono) / up to 0.42 min/page (colour)
- Max Printing Resolution
- Up to 2400 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Original Size
- 127 x 127 mm (min) - 914 x 2770 mm (max)
- Media Size
- 127 x 127 mm (min) - Roll (91.4 cm x 45.7 m), 914 x 1897 mm (max)
- Media Type
- Recycled paper, photo paper, coated paper, bond paper, film, vellum paper, heavy-weight paper, glossy photo paper, satin photo paper, semi-gloss photo paper
- Standard Media Capacity
- 1 roll
- Connection Availability
- Interface
- Gigabit LAN, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, scan to network, automatic cutter
- Power
- AC 120/230 V (50/60Hz)
- 140.3 cm x 62.9 cm x 115.5 cm
- 62.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Ink-jet - colour
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1 GB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 1376 nozzles
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, pigment black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, pigment black
- 4-ink
- Minimum Ink Droplet Size
- 6 pl
- Printer Drivers / Emulations
- TIFF, HPGL/2, HP-RTL, PCL 3 GUI, CALS G4, URF
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 600 dpi
- Colour Depth
- 24-bit
Document & Media Handling
- Min Original Size
- 127 x 127 mm
- Max Original Size
- 914 x 2770 mm
- Min Media Size
- 127 x 127 mm
- Max Media Size
- Other
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), ANSI B (Ledger) (279 x 432 mm), 330 x 482 mm, ANSI C (432 x 559 mm), ANSI E (864 x 1118 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 45.7 m), 210 x 279 mm, 914 x 1897 mm
- 1 roll
- Input tray - 1 roll
- Speed Details
- Printing: 25 sec (A1) , Printing: 25 sec (D) , Scanning: up to 38.1 mm/sec - colour , Scanning: up to 114.3 mm/sec - B/W , Printing: up to 1.36 ppm (A1)
- 1 x Gigabit LAN - RJ-45
- Operating System Support
- Apple Mac OS, Windows 8
- Software Included
- Drivers & Utilities
- Voltage Required
- 35 Watt
- Power Consumption Sleep
- 3.5 Watt
- Included Accessories
- Stand, spindles
- Consumables Included
- 1 x printhead , 1 x ink cartridge (yellow/cyan/magenta/black) - HP 728
- CSA, VCCI, GOST, CCC, EMC, PSB, FCC, IRAM, RoHS, EN 60950-1, KCC, WEEE, ICES, REACH, LVD, IPv6 Ready
- ENERGY STAR Certified
- 140.3 cm
- 62.9 cm
- 115.5 cm
- 62.5 kg
- Shipping Width
- 157.8 cm
- Shipping Depth
- 57.5 cm
- Shipping Height
- 64.6 cm
- Shipping Weight
- 137 kg
- Sound Emission
- 48 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80%
Ink (3)
HP 728 - 300ml Yellow Original DesignJet Ink Cartridge | In Stock | £155.53 |
HP 728 - 300ml Magenta Original DesignJet Ink Cartridge | In Stock | £155.53 |
HP 728 - 300ml Cyan Original DesignJet Ink Cartridge | In Stock | £155.53 |
Other bundles (2)
HP Care Pack Installation Service - Installation / Configuration | In Stock | £375.11 |
HP 5Y NBD DESIGNJET T830 MFP HW SUPP | In Stock | £1,523.50 |
