HP DesignJet T830 24-in Multifunction Printer
Quicklinx: D93KWS00 Mfr#: F9A28A#B19
£1,783.77 ex VAT
£2,140.52 inc VAT
Immediately update all your partners on project review results with the most compact large-format MFP. Intuitive, convenient print/scan/copy and HP DesignJet print quality help you communicate effectively and move the project forward.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
  • CONVENIENT – Fast, agile, intuitive print/scan/copy
    Print documents fast-up to 26 seconds for A1/D-size prints.Enjoy easy installation in the office, construction job site with the most compact large-format MFP.Easily print project sets and PDF documents with HP Click printing software.Fit your print volume – choose from a variety of 40/130/300-ml colour and 69/300-ml black HP ink cartridges.
  • TRUSTED – HP DesignJet quality and reliability
    Get HP DesignJet quality also in small-format sizes – print half-size documents with 50-sheet A4/A3 input tray.Achieve precise lines up to 0.1% line accuracy, up to 2400 dpi, and high contrast – HP Bright Office Inks.Smart scanning technology protects originals from damage when scanning and obtains precise colours.Reinforced design and strong legs for easy transport and use at the job site.
  • COMMUNICATION – Immediately share meeting results
    Use built-in scanner to copy and distribute sketches and hand-annotated drawings to peers/partners right away.Share drawings immediately – scan/email from front panel, use HP Smart app to email contacts, post to cloud.Share drawings immediately-scan/email from front panel, use HP Smart app to email contacts, post to cloud.No learning curve – with the intuitive design of a single touchscreen, you can scan, copy, and share instantly.
HP DesignJet T830 - multifunction printer - colour
24" multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 0.42 min/page (mono) / up to 0.42 min/page (colour)
Max Printing Resolution
Up to 2400 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Scanning
600 dpi
Original Size
127 x 127 mm (min)
Media Size
127 x 127 mm (min)
Media Type
Recycled paper, photo paper, coated paper, bond paper, film, vellum paper, heavy-weight paper, glossy photo paper, satin photo paper, semi-gloss photo paper
Standard Media Capacity
1 roll
Connection Availability
Gigabit LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to network, automatic cutter
AC 120/230 V (50/60Hz)
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Document Enlargement
400%
Max Document Reduction
50%
Maximum Copies
99
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
1376 nozzles
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, pigment black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Minimum Ink Droplet Size
6 pl
Printer Drivers / Emulations
TIFF, HPGL/2, HP-RTL, PCL 3 GUI, CALS G4, URF, JPEG
Scanning
Scan Element
CIS
Optical Resolution
600 dpi
Interpolated Resolution
600 dpi
Colour Depth
24-bit
Document & Media Handling
Min Original Size
127 x 127 mm
Min Media Size
127 x 127 mm
Max Media Size
Other
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), ANSI B (Ledger) (279 x 432 mm), 330 x 482 mm, ANSI C (432 x 559 mm), ANSI D (559 x 864 mm), 210 x 279 mm
1 roll
Input tray - 1 roll
Speed Details
Printing: 25 sec (A1) , Printing: 25 sec (D) , Scanning: up to 38.1 mm/sec - colour , Scanning: up to 114.3 mm/sec - B/W , Printing: up to 1.36 ppm (A1)
1 x Gigabit LAN - RJ-45
Operating System Support
Apple Mac OS, Windows 8
Software Included
Drivers & Utilities
35 Watt
Power Consumption Standby
0.2 Watt
Power Consumption Sleep
3.5 Watt
Stand, spindles
Consumables Included
1 x printhead , 1 x Cartridge (colour (cyan, magenta, yellow, black)) - HP 728
CSA, VCCI, GOST, CCC, EMC, PSB, FCC, IRAM, RoHS, EN 60950-1, KCC, WEEE, ICES, REACH, LVD, IPv6 Ready
ENERGY STAR Certified
Shipping Width
131 cm
Shipping Depth
64.5 cm
Shipping Height
57 cm
Shipping Weight
70 kg
Sound Emission
48 dBA (operating)
5 °C
20 - 80%
Type: Printer / copier / scanner
Functionality: Copier
Functionality: Printer
Functionality: Scanner
Brand: HP
Price Range Ex VAT: 1500+
