Print professional-quality CAD and GIS applications up to 1118 mm (44 inches). Produce prints quickly with an easy, convenient workflow. Take advantage of flexible size, media, and application options.
QUALITY – Quickly produce outstanding results
Six Original HP inks produce a wide colour gamut ideal for colour graphics.Original HP grey and photo black inks achieve precise line accuracy, dark blacks, and true neutral greys.Communicate with precision – produce plans, drawings, and maps with fine line quality, and up to 2400 dpi.Print up to A0 without sacrificing quality; create A1-size prints in 28 seconds with Economode. -
CONVENIENCE – Speed up printing with easy workflow
Print TIFF, JPEG, and PDF files from your printer's USB thumb drive – no computer required.If you're on-the-go, attach your document to an email and send it directly to your printer via ePrint.The intuitive touchscreen simplifies navigation and printing. -
FLEXIBILITY – Prints on sheets or rolls up to 1118 mm (44 in)
Gain flexibility to print a range of sizes from sheets to 1118-mm (44-inch) roll width.Use different media – this printer supports everything from bond and coated papers to film and vinyl substrates.Print a range of CAD and GIS applications, including large infrastructure projects and geospatial mapping.
- HP DesignJet T795 ePrinter - large-format printer - colour - ink-jet
- Printer Type
- 44" large-format printer - ink-jet - colour
- 81.6 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 6-ink - cyan, magenta, yellow, photo black, pigment matte black, grey
- Max Media Size
- Roll (111.8 cm)
- Min Media Size (Custom)
- 210 mm x 279 mm
- Max Media Size (Custom)
- 1118 mm x 1676 mm
- Print Speed
- Up to 0.65 min/page - black draft - A1 (594 x 841 mm) , Up to 41 sq.m/hour - colour draft - A1 (594 x 841 mm) , Up to 0.47 min/page - colour draft - A1 (594 x 841 mm)
- Max Resolution (B&W)
- 2400 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Interface
- USB 2.0, Gigabit LAN
- Language Simulation
- PCL 3, HP RTL, CALS G4, HP GL/2, TIFF
- Media Type
- Plain paper, tracing paper, glossy photo paper, matt photo paper, bond paper, film, backlit paper, translucent bond paper, coated paper, heavy-weight coated paper, semi-gloss photo paper, high-gloss photo paper, matte film, vellum paper, self-adhesive vinyl, satin photo paper, matte paper
- Networking
- Print server
- Microsoft Certification
- Compatible with Windows 7
- 177 cm x 70.1 cm x 105 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 3 x 1056 nozzles
- Minimum Ink Droplet Size
- 9 pl (matte black, yellow), 6 pl (cyan, grey, magenta, photo black)
- Ink Cartridge Configuration
- 6 individual ink tanks; 2 colours per print head
- Print Speed
- Connectivity Technology
- Wired
- Interface
- 2400 x 1200 dpi
- 2400 x 1200 dpi
Media Handling
- Media Type
- Max Media Size
- Roll (111.8 cm)
- 210 mm x 279 mm
- 1118 mm x 1676 mm
- Media Sizes
- A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), 210 x 279 mm, 1118 x 1676 mm
- Media Thickness Range
- Up to 0.8 mm
- Media Weight
- 60 g/m² - 328 g/m²
- Media Feeders
- 1 x manual - 1 roll - Roll (111.8 cm) weight: 60 g/m² - 328 g/m²
- Networking
- Print server
- Expansion Slots
- 1 x EIO
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
- Included Accessories
- Spindle, stand
- Consumables Included
- 3 x printhead , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (photo black) , 1 x ink cartridge (grey) , 1 x ink cartridge (matte black)
- GOST, EMC, RoHS, EN 60950-1, WEEE, REACH, LVD, China RoHS
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 120 Watt
- Power Consumption Stand by
- 27 Watt
- Power Consumption Sleep
- 7 Watt
- Software Included
- HP ePrint
Environmental Standards
- ENERGY STAR
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Idle)
- 29 dBA
- Sound Emission (Operating)
- 43 dBA
- 177 cm
- 70.1 cm
- 105 cm
- 81.6 kg
- Width (Shipping)
- 193 cm
- Depth (Shipping)
- 76.6 cm
- Height (Shipping)
- 77 cm
- Weight (Shipping)
- 103 kg
