Your basket is empty
HP Designjet T795 44" ePrinter
Quicklinx: 9HGBWS00 Mfr#: CR649C#B19
Print professional-quality CAD and GIS applications up to 1118 mm (44 inches). Produce prints quickly with an easy, convenient workflow. Take advantage of flexible size, media, and application options.
HP DesignJet T795 ePrinter - large-format printer - colour - ink-jet
Printer Type
44" large-format printer - ink-jet - colour
81.6 kg
English, German, French, Italian, Spanish / Europe
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
6-ink - cyan, magenta, yellow, photo black, pigment matte black, grey
Max Media Size
Roll (111.8 cm)
Min Media Size (Custom)
210 mm x 279 mm
Max Media Size (Custom)
1118 mm x 1676 mm
Print Speed
Up to 0.65 min/page - black draft - A1 (594 x 841 mm) , Up to 41 sq.m/hour - colour draft - A1 (594 x 841 mm) , Up to 0.47 min/page - colour draft - A1 (594 x 841 mm)
Max Resolution (B&W)
2400 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
USB 2.0, Gigabit LAN
Language Simulation
PCL 3, HP RTL, CALS G4, HP GL/2, TIFF
Media Type
Plain paper, tracing paper, glossy photo paper, matt photo paper, bond paper, film, backlit paper, translucent bond paper, coated paper, heavy-weight coated paper, semi-gloss photo paper, high-gloss photo paper, matte film, vellum paper, self-adhesive vinyl, satin photo paper, matte paper
Print server
AC 120/230 V
Microsoft Certification
Compatible with Windows 7
177 cm x 70.1 cm x 105 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
3 x 1056 nozzles
Minimum Ink Droplet Size
9 pl (matte black, yellow), 6 pl (cyan, grey, magenta, photo black)
Ink Cartridge Configuration
6 individual ink tanks; 2 colours per print head
Print Speed
Wired
2400 x 1200 dpi
2400 x 1200 dpi
Language Simulation
Media Handling
Media Type
Max Media Size
Roll (111.8 cm)
210 mm x 279 mm
1118 mm x 1676 mm
Media Sizes
A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), 210 x 279 mm, 1118 x 1676 mm
Media Thickness Range
Up to 0.8 mm
Media Weight
60 g/m² - 328 g/m²
Media Feeders
1 x manual - 1 roll - Roll (111.8 cm) weight: 60 g/m² - 328 g/m²
Print server
Expansion Slots
1 x EIO
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Spindle, stand
Consumables Included
3 x printhead , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (photo black) , 1 x ink cartridge (grey) , 1 x ink cartridge (matte black)
GOST, EMC, RoHS, EN 60950-1, WEEE, REACH, LVD, China RoHS
Power supply - internal
AC 120/230 V
Frequency Required
50/60 Hz
120 Watt
Power Consumption Stand by
27 Watt
Power Consumption Sleep
7 Watt
Software Included
HP ePrint
Environmental Standards
ENERGY STAR
5 °C
20 - 80%
Sound Emission (Idle)
29 dBA
Sound Emission (Operating)
43 dBA
177 cm
70.1 cm
105 cm
81.6 kg
Width (Shipping)
193 cm
Depth (Shipping)
76.6 cm
Height (Shipping)
77 cm
Weight (Shipping)
103 kg
