Product
HP Designjet T790 24" PostScript Colour Laser ePrinter
You Buy. You Try. You Decide!
Quicklinx: 7J76WS00 Mfr#: CR648A#B19
So easy and intuitive, you'll love using it. Print to any HP Designjet printer without installing any drivers thanks to free HP ePrint & Share1. Save time with accurate page previews, and discover the power of touch through its colour touchscreen that enables easy printing. Secure your investment: this HP ePrinter is Web-connected and easy to update. Software updates occur automatically, every six months. Create a print-ready PDF2 file at the same time you print with HP ePrint & Share1. Print high-quality results at fast speeds. Achieve high-quality results: the 6-ink system has matte and photo black, and grey to produce true neutral greys and a wide range of vivid colours on plain and glossy media. Produce fine detailed lines with 0.02 mm minimum line width3, and highly accurate drawings with innovative printhead technology and Original HP inks. Get the job done quickly without sacrificing quality: print up to 2 A1 prints per minute in Economode. Print complex files as easily as simple ones with 8 GB virtual memory4.
1 HP ePrint & Share is a free Web-printing solution that lets you automatically manage content online. It requires an Internet connection. Download ePrint & Share: www.hp.com/go/eprintandshare 2 Requires AutoCAD plug-in. 3 Using HP-GL/2. 4 Based on 640 MB RAM.
