HP DesignJet T520 36" ePrinter
Quicklinx: 8JK0WS00 Mfr#: CQ893A#B19
Reliable, accurate, and easy to use – this large-format printer is a good investment for your studio. Grow your business with convenient printing that lets you work and print wherever you are.
  • OFFICE-READY-Fits the way you work
    Compact, standalone printer with legs and a stand-for easy office placement and positioning.The professional look and feel of this printer is designed to complement your workplace.Produce a range of applications including architectural designs, maps, photos, and presentations.Take advantage of the most affordable, compact 914 mm (36-inch) HP DesignJet Printer.
  • EASY-Convenient printing
    Easily print project sets and PDF documents with HP Click printing software.Move this printer any time, any place-with Wi-Fi connectivity, all you need is a power plug.The intuitive, full-colour touchscreen simplifies navigation and printing.Produce A1/D prints in 35 seconds-this printer also provides original HP-GL/2 compatibility.
  • TRUSTED-HP DesignJet quality and reliability
    Get HP DesignJet quality in small-format sizes-print half-size technical documents with the A4/A3 input tray.Achieve precise lines with sharp detail up to 2400 dpi.Join the hundreds of thousands of users who trust HP DesignJet T520 Printers for outstanding print quality.Flexibility for today and tomorrow-print easily from your smartphone or tablet with HP Mobile Printing.
HP DesignJet T520 ePrinter - large-format printer - colour - ink-jet
Printer Type
36" large-format printer - ink-jet - colour
39.2 kg
English, German, French, Italian, Spanish / Europe
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, pigment black
Max Media Size
A0 (841 x 1189 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 45.7 m)
Min Media Size (Custom)
210 mm
Max Media Size (Custom)
914 mm x 457 mm
Print Speed
Up to 0.58 min/page - black draft - ANSI D (559 x 864 mm) , Up to 0.58 min/page - colour draft - ANSI D (559 x 864 mm) , Up to 0.58 min/page - black draft - A1 (594 x 841 mm) , Up to 0.58 min/page - colour draft - A1 (594 x 841 mm)
Max Resolution (B&W)
2400 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
Cutter
USB 2.0, LAN, Wi-Fi
Preview Screen Size
4.3"
RAM Installed (Max)
1 GB (1 GB)
Language Simulation
PCL 3, HP RTL, CALS G4, HP GL/2
Media Type
Plain paper, photo paper, glossy photo paper, bond paper, recycled paper, film, coated paper, heavy-weight coated paper, semi-gloss photo paper, matte film, vellum paper, satin photo paper, glossy paper
Print server - Ethernet, Fast Ethernet
Linux, Microsoft Windows XP Professional x64 Edition SP3, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Microsoft Windows 7 Home Premium (32/64 bits), Microsoft Windows Vista Business (32/64 bits), Microsoft Windows Vista Home Premium (32/64 bits), Microsoft Windows Vista Ultimate (32/64 bits), Microsoft Windows 7 Professional (32/64 bits), Microsoft Windows 7 Ultimate (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Microsoft Windows XP Home Edition x64 Edition SP3, Apple OS X 10.8 Mountain Lion, Citrix XenServer, Citrix XenApp
Microsoft Certification
Compatible with Windows 7
Environmental Standards
EPEAT Bronze
129.2 cm x 53 cm x 93.2 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Minimum Ink Droplet Size
12 pl (black), 5.5 pl (colour)
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Print Speed
Built-in Devices
Touch screen
Preview Screen Size
4.3"
Wired
USB 2.0, LAN, Wi-Fi
2400 x 1200 dpi
2400 x 1200 dpi
Language Simulation
Cutter
RAM
RAM Installed (Max)
1 GB / 1 GB (max)
Media Handling
Media Type
Max Media Size
210 mm
914 mm x 457 mm
Media Sizes
A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 45.7 m)
Media Thickness Range
Up to 0.3 mm
Media Weight
60 g/m² - 280 g/m²
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Stand
FCC Class B certified, CSA, VCCI Class B ITE, GOST, PSB, R&TTE, RoHS, EN 60950-1, ICES Class B, CCC Class B, WEEE, REACH, KCC Class A, LVD, EuP, EMC Class B
Power supply - internal
Frequency Required
50/60 Hz
35 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Software Included
Drivers & Utilities
System Requirements Details
Windows 7/Vista - 1 GHz - RAM 1 GB - HD 1 GB , Windows XP SP3 - Pentium - 1 GHz - RAM 512 MB - HD 1 GB , MacOS X 10.6 - RAM 1 GB - HD 2 GB
EPEAT Compliant
EPEAT Bronze
ENERGY STAR
5 °C
20 - 80%
Sound Emission (Idle)
16 dBA
Sound Emission (Operating)
48 dBA
129.2 cm
53 cm
93.2 cm
39.2 kg
Width (Shipping)
142.3 cm
Depth (Shipping)
57.7 cm
Height (Shipping)
62.6 cm
Weight (Shipping)
62 kg
8JK0 HP Universal Bond Paper-610 mm x 45.7 m (24in x 150ft) In Stock £11.37
8JK0 HP Coated Paper-610 mm x 45.7 m (24in x 150ft) In Stock £29.82
