Reliable, accurate, and easy to use – this large-format printer is a good investment for your studio. Grow your business with convenient printing that lets you work and print wherever you are.
OFFICE-READY-Fits the way you work
Compact, standalone printer with legs and a stand-for easy office placement and positioning.The professional look and feel of this printer is designed to complement your workplace.Produce a range of applications including architectural designs, maps, photos, and presentations.Take advantage of the most affordable, compact 914 mm (36-inch) HP DesignJet Printer. -
EASY-Convenient printing
Easily print project sets and PDF documents with HP Click printing software.Move this printer any time, any place-with Wi-Fi connectivity, all you need is a power plug.The intuitive, full-colour touchscreen simplifies navigation and printing.Produce A1/D prints in 35 seconds-this printer also provides original HP-GL/2 compatibility. -
TRUSTED-HP DesignJet quality and reliability
Get HP DesignJet quality in small-format sizes-print half-size technical documents with the A4/A3 input tray.Achieve precise lines with sharp detail up to 2400 dpi.Join the hundreds of thousands of users who trust HP DesignJet T520 Printers for outstanding print quality.Flexibility for today and tomorrow-print easily from your smartphone or tablet with HP Mobile Printing.
- HP DesignJet T520 ePrinter - large-format printer - colour - ink-jet
- Printer Type
- 36" large-format printer - ink-jet - colour
- 39.2 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, pigment black
- Max Media Size
- A0 (841 x 1189 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 45.7 m)
- Min Media Size (Custom)
- 210 mm
- Max Media Size (Custom)
- 914 mm x 457 mm
- Print Speed
- Up to 0.58 min/page - black draft - ANSI D (559 x 864 mm) , Up to 0.58 min/page - colour draft - ANSI D (559 x 864 mm) , Up to 0.58 min/page - black draft - A1 (594 x 841 mm) , Up to 0.58 min/page - colour draft - A1 (594 x 841 mm)
- Max Resolution (B&W)
- 2400 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Cutter
- Interface
- USB 2.0, LAN, Wi-Fi
- Preview Screen Size
- 4.3"
- RAM Installed (Max)
- 1 GB (1 GB)
- Language Simulation
- PCL 3, HP RTL, CALS G4, HP GL/2
- Media Type
- Plain paper, photo paper, glossy photo paper, bond paper, recycled paper, film, coated paper, heavy-weight coated paper, semi-gloss photo paper, matte film, vellum paper, satin photo paper, glossy paper
- Networking
- Print server - Ethernet, Fast Ethernet
- System Requirements
- Linux, Microsoft Windows XP Professional x64 Edition SP3, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Microsoft Windows 7 Home Premium (32/64 bits), Microsoft Windows Vista Business (32/64 bits), Microsoft Windows Vista Home Premium (32/64 bits), Microsoft Windows Vista Ultimate (32/64 bits), Microsoft Windows 7 Professional (32/64 bits), Microsoft Windows 7 Ultimate (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Microsoft Windows XP Home Edition x64 Edition SP3, Apple OS X 10.8 Mountain Lion, Citrix XenServer, Citrix XenApp
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Bronze
- 129.2 cm x 53 cm x 93.2 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Minimum Ink Droplet Size
- 12 pl (black), 5.5 pl (colour)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Built-in Devices
- Touch screen
- 4.3"
- Connectivity Technology
- Wired
- Interface
- 2400 x 1200 dpi
- 2400 x 1200 dpi
- Cutter
RAM
- 1 GB / 1 GB (max)
Media Handling
- Media Type
- Max Media Size
- 210 mm
- 914 mm x 457 mm
- Media Sizes
- A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 45.7 m)
- Media Thickness Range
- Up to 0.3 mm
- Media Weight
- 60 g/m² - 280 g/m²
- Networking
- Print server
- Data Link Protocol
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Included Accessories
- Stand
- FCC Class B certified, CSA, VCCI Class B ITE, GOST, PSB, R&TTE, RoHS, EN 60950-1, ICES Class B, CCC Class B, WEEE, REACH, KCC Class A, LVD, EuP, EMC Class B
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 35 Watt
- Power Consumption Stand by / Sleep
- 0.3 Watt
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Windows 7/Vista - 1 GHz - RAM 1 GB - HD 1 GB , Windows XP SP3 - Pentium - 1 GHz - RAM 512 MB - HD 1 GB , MacOS X 10.6 - RAM 1 GB - HD 2 GB
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Idle)
- 16 dBA
- Sound Emission (Operating)
- 48 dBA
- 129.2 cm
- 53 cm
- 93.2 cm
- 39.2 kg
- Width (Shipping)
- 142.3 cm
- Depth (Shipping)
- 57.7 cm
- Height (Shipping)
- 62.6 cm
- Weight (Shipping)
- 62 kg
HP Universal Bond Paper-610 mm x 45.7 m (24in x 150ft) | In Stock | £11.37 |
HP Coated Paper-610 mm x 45.7 m (24in x 150ft) | In Stock | £29.82 |
