Improve productivity with the fastest MFP on the market for all your black-and-white and colour needs. Enjoy unattended operation at costs rivaling similar black-and-white LED MFPs. This MFP is built for rigorous IT demands and top security.
All your workflow needs in a high-productivity MFP
Be the fastest – print A1-size pages in 21 seconds with dark blacks, neutral greys, and vivid colours.
Print out your first page right away thanks to ultra-fast processing and zero warm-up time.
Copy and scan quickly with advanced features and efficient workflow tools – presets, batch scanning, multipage PDFs, and scan to email.
Stay organised and avoid clutter – the integrated 100-page stacker delivers prints and copies neatly collated.
A production printer for unattended, low-cost use
Print your black-and-white drawings at the same cost per page as comparable black-and-white LED MFPs.
Operate unattended thanks to two heavy rolls of up to 200 m (650 ft) and a total ink capacity of 1800 ml.
Built for high-volume printing – rely on a robust design to fulfil the most demanding jobs.
Manage projects and control costs effectively, using embedded professional accounting features.
Built for rigorous IT demands and top security
Minimise device-management tasks and costs, using the HP DesignJet Universal Print Driver.
Manage your fleet with ease, while saving time and helping to reduce costs, thanks to HP Web Jetadmin.
Protect and manage confidential jobs securely – retrieve documents at the printer with a personal PIN.
Safeguard confidential information, using a self-encrypting HDD with AES-256, Secure Disk Erase, and IPsec.
Be the fastest – print A1-size pages in 21 seconds with dark blacks, neutral greys, and vivid colours.Print out your first page right away thanks to ultra-fast processing and zero warm-up time.Copy and scan quickly with advanced features and efficient workflow tools – presets, batch scanning, multipage PDFs, and scan to email.Stay organised and avoid clutter – the integrated 100-page stacker delivers prints and copies neatly collated. -
Print your black-and-white drawings at the same cost per page as comparable black-and-white LED MFPs.Operate unattended thanks to two heavy rolls of up to 200 m (650 ft) and a total ink capacity of 1800 ml.Built for high-volume printing – rely on a robust design to fulfil the most demanding jobs.Manage projects and control costs effectively, using embedded professional accounting features. -
Minimise device-management tasks and costs, using the HP DesignJet Universal Print Driver.Manage your fleet with ease, while saving time and helping to reduce costs, thanks to HP Web Jetadmin.Protect and manage confidential jobs securely – retrieve documents at the printer with a personal PIN.Safeguard confidential information, using a self-encrypting HDD with AES-256, Secure Disk Erase, and IPsec.
- HP DesignJet T3500 Production eMFP - multifunction printer - colour
- 36" multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 6-ink
- Max Printing Speed
- Up to 0.35 min/page (mono) / up to 0.35 min/page (colour)
- Max Printing Resolution
- Up to 2400 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Original Size
- 210 x 297 mm (min) - 914 x 8000 mm, 610 x 15000 mm (max)
- Media Size
- 914 x 1219 mm, Roll (91.4 cm x 200 m) (max)
- Standard Media Capacity
- 2 rolls
- Connection Availability
- Interface
- Gigabit LAN, USB 2.0 host
- Office Machine Features
- Automatic cutter
- Power
- AC 120/230 V (50/60Hz)
- 140 cm x 78.4 cm x 110.9 cm
- 114 kg
- Environmental Standards
- ENERGY STAR Qualified
- Ink-jet - colour
- Interface
- Automatic cutter
- Localisation
- Hard Disk Drive
- 500 GB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 9632 nozzles
- Ink Cartridge Configuration
- 6 cartridges (1 each: cyan, magenta, yellow, grey, photo black, matte black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, photo black, pigment matte black, grey
- 6-ink
- Printer Drivers / Emulations
- TIFF, HPGL/2, HP-RTL, PCL 3 GUI, CALS G4
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Min Original Size
- 210 x 297 mm
- Max Original Size
- Max Media Size
- Other
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 328 g/m²
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI E (864 x 1118 mm), ANSI D (559 x 864 mm), 914 x 1219 mm, Roll (91.4 cm x 200 m), 210 x 279 mm
- 2 rolls
- Input tray - 2 rolls
- Speed Details
- Printing: 21 sec (A1) , Printing: 21 sec (D) , Scanning: up to 63.5 mm/sec - colour , Scanning: up to 190.5 mm/sec - B/W
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type A
- Operating System Support
- Apple Mac OS X, MS Windows
- Voltage Required
- 120 Watt
- Power Consumption Sleep
- 2 Watt
- FCC Class A certified, CSA, GOST, PSB, IRAM, RoHS, EN 60950-1, WEEE, REACH, ICES Class A, LVD, KC, EMC Class A, MSIP Class A, CCC Class A, China RoHS
- ENERGY STAR Certified
- 140 cm
- 78.4 cm
- 110.9 cm
- 114 kg
- Shipping Width
- 150.2 cm
- Shipping Depth
- 78.05 cm
- Shipping Height
- 80.4 cm
- Shipping Weight
- 141 kg
- Sound Emission
- 38 dBA (idle) / 50 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80%
HP Heavyweight Coated Paper-914 mm x 30.5 m (36in x 100ft) | In Stock | £35.96 |
