HP DesignJet T1530 36" Colour InkJet PostScript Printer
Quicklinx: BT6YWS00 Mfr#: L2Y24A#B19
You can look to this printer to boost workgroup performance. Impress clients with professional quality. Work quickly and effectively with features that enable efficiency and productivity. Secure your information, and manage the printer easily.
  • QUALITY-Your projects, presented at their best
    Six Original HP inks produce a wide color gamut ideal for color graphics.Original HP gray and photo black inks achieve precise line accuracy, dark blacks, and true neutral grays.Make your architectural prints shine with professional, high-resolution graphics-opt for Adobe PostScript .Communicate with precision-produce plans, drawings, and maps with fine line quality, and up to 2400 dpi.
  • PRODUCTIVITY-Ease, efficiency empower workgroups
    Stay organized and on task-the integrated 50-page output stacking tray delivers flat, collated prints.Two rolls help save time-easy front loading, automatic alignment; two media types/sizes, smart switching.Print complex files fast-one A1/D in 21 sec (120 A1/D per hr), 96 GB virtual memory (based on 1.5 GB RAM).Print from your mobile device/USB drive with HP Mobile Printing; add features with HP AiO Printer Remote.
  • SECURITY-Enterprise compatible, IT manageable
    Enable highly unattended printing with two 91.4-m (300-ft) rolls and Original HP ink cartridges up to 300 ml.Safeguard information with security protocols like IPSec, 802.1x, SNMPv3, PIN printing, and other options.Use HP Embedded Web Server and Web Jetadmin to easily manage your printer and fleet while also tracking costs.Integrates easily with your other office devices-iOS and Android compatibility with HP Mobile Printing.
HP DesignJet T1530 PostScript - large-format printer - colour - ink-jet
Printer Type
36" large-format printer - ink-jet - colour
88 kg
English, German, French, Italian, Spanish / Europe
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
6-ink - cyan, magenta, yellow, photo black, pigment matte black, grey
Max Media Size
Roll (91.4 cm x 91.4 m), 914 x 1219 mm
Min Media Size (Custom)
210 mm x 279 mm
Max Media Size (Custom)
914 mm
Print Speed
Up to 0.35 min/page - draft - ANSI D (559 x 864 mm)
Max Resolution (B&W)
2400 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
Cutter
Gigabit LAN, USB 2.0 host
AirPrint Enabled
RAM Installed (Max)
1.5 GB
Hard Drive
500 GB
Language Simulation
PCL 3, PostScript 3, HP RTL, CALS G4, HP GL/2, TIFF, PDF 1.7
Media Type
Plain paper, photo paper, tracing paper, glossy photo paper, matt photo paper, bond paper, film, backlit paper, translucent bond paper, coated paper, heavy-weight coated paper, semi-gloss photo paper, high-gloss photo paper, matte film, vellum paper, polyester film, self-adhesive vinyl, satin photo paper, self-adhesive paper
Total Media Capacity
2 rolls
Media Handling
2 automatic roll feeds
Print server
Printer Features
Print from mobile device, PANTONE calibrated
Apple MacOS, Microsoft Windows, Windows 10
1-year warranty
139.9 cm x 91.6 cm x 111 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
9632 nozzles
Minimum Ink Droplet Size
9 pl (black), 6 pl (colour)
Ink Cartridge Configuration
6 cartridges (1 each: cyan, magenta, yellow, grey, photo black, matte black)
Print Speed
Wired
AirPrint Enabled
2400 x 1200 dpi
2400 x 1200 dpi
Language Simulation
Cutter
Printer Features
Media Handling
RAM
RAM Installed (Max)
1.5 GB
Storage
Hard Drive
500 GB
Media Handling
Media Type
Max Media Size
210 mm x 279 mm
914 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI E (864 x 1118 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 91.4 m), 914 x 1219 mm, 210 x 279 mm, 210 x 914 mm
Max Printing Length
91.4 m
Media Thickness Range
Up to 0.5 mm
2 rolls
Media Feeders
1 x manual - 2 rolls - Roll (91.4 cm x 91.4 m)
Output Trays Capacity
50 sheets
Print server
Security Protocols & Features
IPsec, 802.1x
1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Media bin, stand, stacking tray, spindles
Consumables Included
1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (grey) , 1 x ink cartridge (photo black) , 1 x ink cartridge (matte black) , 1 x printhead
CSA, VCCI, GOST, CCC, PSB, FCC, IRAM, RoHS, EN 60950-1, KCC, WEEE, ICES, REACH, FSC, LVD, EuP, EMC Class B, PEFC, IPv6 Ready, China RoHS, ACMA
Power supply - internal
Frequency Required
50/60 Hz
120 Watt
Power Consumption Sleep
5 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
5 °C
20 - 80%
Sound Emission (Idle)
39 dBA
Sound Emission (Operating)
47 dBA
139.9 cm
91.6 cm
111 cm
88 kg
Width (Shipping)
150 cm
Depth (Shipping)
78.1 cm
Height (Shipping)
81.5 cm
Weight (Shipping)
120 kg
