You can look to this printer to boost workgroup performance. Impress clients with professional quality. Work quickly and effectively with features that enable efficiency and productivity. Secure your information, and manage the printer easily.
QUALITY-Your projects, presented at their best
Six Original HP inks produce a wide color gamut ideal for color graphics.Original HP gray and photo black inks achieve precise line accuracy, dark blacks, and true neutral grays.Make your architectural prints shine with professional, high-resolution graphics-opt for Adobe PostScript .Communicate with precision-produce plans, drawings, and maps with fine line quality, and up to 2400 dpi. -
PRODUCTIVITY-Ease, efficiency empower workgroups
Stay organized and on task-the integrated 50-page output stacking tray delivers flat, collated prints.Two rolls help save time-easy front loading, automatic alignment; two media types/sizes, smart switching.Print complex files fast-one A1/D in 21 sec (120 A1/D per hr), 96 GB virtual memory (based on 1.5 GB RAM).Print from your mobile device/USB drive with HP Mobile Printing; add features with HP AiO Printer Remote. -
SECURITY-Enterprise compatible, IT manageable
Enable highly unattended printing with two 91.4-m (300-ft) rolls and Original HP ink cartridges up to 300 ml.Safeguard information with security protocols like IPSec, 802.1x, SNMPv3, PIN printing, and other options.Use HP Embedded Web Server and Web Jetadmin to easily manage your printer and fleet while also tracking costs.Integrates easily with your other office devices-iOS and Android compatibility with HP Mobile Printing.
- HP DesignJet T1530 PostScript - large-format printer - colour - ink-jet
- Printer Type
- 36" large-format printer - ink-jet - colour
- 88 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 6-ink - cyan, magenta, yellow, photo black, pigment matte black, grey
- Max Media Size
- Roll (91.4 cm x 91.4 m), 914 x 1219 mm
- Min Media Size (Custom)
- 210 mm x 279 mm
- Max Media Size (Custom)
- 914 mm
- Print Speed
- Up to 0.35 min/page - draft - ANSI D (559 x 864 mm)
- Max Resolution (B&W)
- 2400 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Cutter
- Interface
- Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- RAM Installed (Max)
- 1.5 GB
- Hard Drive
- 500 GB
- Language Simulation
- PCL 3, PostScript 3, HP RTL, CALS G4, HP GL/2, TIFF, PDF 1.7
- Media Type
- Plain paper, photo paper, tracing paper, glossy photo paper, matt photo paper, bond paper, film, backlit paper, translucent bond paper, coated paper, heavy-weight coated paper, semi-gloss photo paper, high-gloss photo paper, matte film, vellum paper, polyester film, self-adhesive vinyl, satin photo paper, self-adhesive paper
- Total Media Capacity
- 2 rolls
- Media Handling
- 2 automatic roll feeds
- Networking
- Print server
- Printer Features
- Print from mobile device, PANTONE calibrated
- System Requirements
- Apple MacOS, Microsoft Windows, Windows 10
- 1-year warranty
- 139.9 cm x 91.6 cm x 111 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 9632 nozzles
- Minimum Ink Droplet Size
- 9 pl (black), 6 pl (colour)
- Ink Cartridge Configuration
- 6 cartridges (1 each: cyan, magenta, yellow, grey, photo black, matte black)
- Print Speed
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 2400 x 1200 dpi
- 2400 x 1200 dpi
- Cutter
- Printer Features
- Media Handling
RAM
- 1.5 GB
Storage
- Hard Drive
- 500 GB
Media Handling
- Media Type
- Max Media Size
- 210 mm x 279 mm
- 914 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI E (864 x 1118 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 91.4 m), 914 x 1219 mm, 210 x 279 mm, 210 x 914 mm
- Max Printing Length
- 91.4 m
- Media Thickness Range
- Up to 0.5 mm
- 2 rolls
- Media Feeders
- 1 x manual - 2 rolls - Roll (91.4 cm x 91.4 m)
- Output Trays Capacity
- 50 sheets
- Networking
- Print server
- IPsec, 802.1x
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Included Accessories
- Media bin, stand, stacking tray, spindles
- Consumables Included
- 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (grey) , 1 x ink cartridge (photo black) , 1 x ink cartridge (matte black) , 1 x printhead
- CSA, VCCI, GOST, CCC, PSB, FCC, IRAM, RoHS, EN 60950-1, KCC, WEEE, ICES, REACH, FSC, LVD, EuP, EMC Class B, PEFC, IPv6 Ready, China RoHS, ACMA
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 120 Watt
- Power Consumption Sleep
- 5 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Idle)
- 39 dBA
- Sound Emission (Operating)
- 47 dBA
- 139.9 cm
- 91.6 cm
- 111 cm
- 88 kg
- Width (Shipping)
- 150 cm
- Depth (Shipping)
- 78.1 cm
- Height (Shipping)
- 81.5 cm
- Weight (Shipping)
- 120 kg
