Your basket is empty
HP Designjet T1300 44" PostScript Colour Laser ePrinter
Quicklinx: 7J7FWS00 Mfr#: CR652A#B19
So easy and intuitive, you'll love using it. Print to any HP Designjet printer without installing any drivers thanks to free HP ePrint & Share1. Save time with accurate page previews, and discover the power of touch through its colour touchscreen that enables easy printing. Secure your investment: this HP eprinter is Web-connected and easy to update. Software updates occur automatically, every six months. Create a print-ready PDF2 file at the same time you print with HP ePrint & Share1].
Access and print files where the job takes you. Print TIFF, JPEG, and PDF3 files directly from your USB flash drive - no computer required. Walk up to your printer's touchscreen, access files on the Web, and print them with HP ePrint & Share1. Select and share projects using the touchscreen thanks to HP ePrint & Share1. Send plans directly to your office or the client site, even when you're on the go, and print remotely4 to any large-format HP Web-connected Designjet from your computer or mobile device.
Do more in less time with two rolls, fast setup, printing and sharing. Save time and paper with two rolls. Load the printer with the same or different paper types and sizes. Get the job done quickly without sacrificing quality. Print up to 2 A1 prints per minute in Economode. Achieve high quality results - the 6-ink system has matte and photo black, and grey to produce true neutral greys and a wide range of vivid colours on plain and glossy media. Experience trusted security and manageability with features like HP Web Jetadmin and an embedded Web server.
