Take advantage of an integrated scanning, copying and printing experience. Enhance your productivity with fast, right-click printing and high-quality colour for all your jobs - from fine lines to photographs and everything in between.
Rely on one complete, easy, integrated solution
Manage large-format documents from scan through print or archive with this reliable MFP.Operation is intuitive and simple with a full-station 38.1 cm (15-inch) touch screen display, which also includes a virtual keyboard.Perform scan, copy and print functions with greater control and confidence. -
Do more with one device and see your productivity soar
Save time and paper with 2 online rolls and smart switching, so you can handle CAD and GIS projects at the same time.You're back to business in no time with this HP MFP that scans, copies, and prints your projects quickly.Batch scanning and printing is fast and easy thanks to free HP Instant Printing and collating features. -
See top quality results across a broad range of applications from any original
Get a high level of quality in line drawings, maps and posters with 4 camera CCD scanning technology with 600 dpi.Experience added versatility when you scan and print AEC, CAD, and GIS documents.Produce fine lines, crisp text, and vivid colour with Original HP inks, including 2 blacks and a grey ink.Transform your everyday printing using HP everyday bond papers with ColorPRO Technology.
- HP DesignJet T1200 HD-MFP - multifunction printer - colour
- 44" multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 6-ink
- Max Copying Resolution
- 9600 dpi (colour)
- Max Printing Speed
- Up to 0.47 min/page (mono) / up to 41 sq.m/hour (colour)
- Max Printing Resolution
- Up to 2400 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 15"
- Original Size
- 1067 mm width (max)
- Media Size
- Roll (111.8 cm x 91 m) (max)
- Media Type
- Coated paper, bond paper, film, vellum paper, glossy photo paper, matte photo paper, satin photo paper
- Standard Media Capacity
- 2 rolls
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, IEEE-1394 (Firewire)
- Office Machine Features
- EIO slot, automatic cutter
- Power
- AC 120/230 V (50/60Hz)
- 190 cm x 100 cm x 160 cm
- 200 kg
- Ink-jet - colour
- Display Diagonal Size
- 15"
- Display Features
- Touch screen
- Interface
- Localisation
- Hard Disk Drive
- 320 GB
Copying
- 9600 dpi (colour)
- Max Document Enlargement
- 10000%
- Max Document Reduction
- 1%
- Maximum Copies
- 1000
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 6 cartridges (1 each: cyan, magenta, yellow, grey, photo black, matte black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, photo black, pigment matte black, grey
- 6-ink
- Printer Drivers / Emulations
- PostScript 3, PCL 3, PDF 1.7, TIFF, HPGL/2, HP-RTL, CALS G4
- Colour Management Features
- PANTONE Digital Color
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 dpi
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 1067 mm width
- Max Media Size
- Other
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 328 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A0 (841 x 1189 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI E (864 x 1118 mm), ANSI D (559 x 864 mm), Roll (111.8 cm x 91 m), 210 x 279 mm, 1118 x 1676 mm
- 2 rolls
- Input tray - 2 rolls - Roll (111.8 cm x 91 m) weight: 60 g/m² - 328 g/m²
- Speed Details
- Printing: 28 sec (A1) - B/W draft , Printing: 28 sec (D) - B/W draft , Printing: up to 41 sq.m/hour - colour draft , Scanning: up to 51 mm/sec - colour , Scanning: up to 152 mm/sec - B/W
- 2 x Gigabit LAN - RJ-45 , 2 x USB 2.0 , 1 x FireWire
- Operating System Support
- MS Windows XP SP2 or later, Apple Mac OS X 10.4, Apple Mac OS X 10.5, Apple Mac OS X 10.6, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits)
- Software Included
- Drivers & Utilities
- Voltage Required
- 300 Watt
- Power Consumption Standby
- 65.3 Watt
- Power Consumption Sleep
- 7 Watt
- Included Accessories
- USB cable, stand, Ethernet cable, Firewire cable, spindle
- FCC Class A certified, CSA, VCCI, GOST, VCCI Class A ITE, PSB, MOC, IRAM, RoHS, EN 60950-1, WEEE, ACA, REACH, BSMI Class A, ICES Class A, KCC Class A, LVD, EMC Class A, CCC Class A
- 190 cm
- 100 cm
- 160 cm
- 200 kg
- Shipping Width
- 193 cm
- Shipping Depth
- 76.6 cm
- Shipping Height
- 152.9 cm
- Shipping Weight
- 280 kg
- Sound Emission
- 32 dBA (idle) / 47 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80%
HP Universal Bond Paper-610 mm x 45.7 m (24in x 150ft) | In Stock | £11.37 |
HP Bright White Inkjet Paper-914 mm x 45.7 m | In Stock | £24.94 |
HP Coated Paper-1067 mm x 45.7 m (42in x 150ft) | In Stock | £55.96 |
