Product
Brand
HP Designjet T1200 HD Multifunction Printer
Quicklinx: 9HFSWS00 Mfr#: CQ653C#B19
Take advantage of an integrated scanning, copying and printing experience. Enhance your productivity with fast, right-click printing and high-quality colour for all your jobs - from fine lines to photographs and everything in between.
HP DesignJet T1200 HD-MFP - multifunction printer (colour)
44" multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 6-ink
Max Copying Resolution
9600 dpi (colour)
Max Printing Speed
Up to 0.47 min/page (mono) / up to 41 sq.m/hour (colour)
Max Printing Resolution
Up to 2400 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Scanning
600 x 600 dpi
Display
15"
Original Size
1067 mm width (max)
Media Size
Roll (111.8 cm x 91 m) (max)
Media Type
Coated paper, bond paper, film, vellum paper, glossy photo paper, matte photo paper, satin photo paper
Standard Media Capacity
2 rolls
Connection Availability
USB 2.0, Gigabit LAN, IEEE-1394 (Firewire)
Office Machine Features
EIO slot, automatic cutter
AC 120/230 V (50/60Hz)
190 cm x 100 cm x 160 cm
200 kg
Printing Technology
Ink-jet - colour
Display Diagonal Size
15"
Display Features
Touch screen
Hard Disk Drive
320 GB
Copying
9600 dpi (colour)
Max Document Enlargement
10000%
Max Document Reduction
1%
Maximum Copies
1000
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
6 cartridges (1 each: cyan, magenta, yellow, grey, photo black, matte black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, photo black, pigment matte black, grey
6-ink
Printer Drivers / Emulations
PostScript 3, PCL 3, PDF 1.7, TIFF, HPGL/2, HP-RTL, CALS G4
Colour Management Features
PANTONE Digital Color
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 dpi
Colour Depth
24-bit
Document & Media Handling
Max Original Size
1067 mm width
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
328 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A0 (841 x 1189 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI E (864 x 1118 mm), ANSI D (559 x 864 mm), Roll (111.8 cm x 91 m), 210 x 279 mm, 1118 x 1676 mm
2 rolls
Input tray - 2 rolls - Roll (111.8 cm x 91 m) weight: 60 g/m² - 328 g/m²
Speed Details
Printing: 28 sec (A1) - B/W draft , Printing: 28 sec (D) - B/W draft , Printing: up to 41 sq.m/hour - colour draft , Scanning: up to 51 mm/sec - colour , Scanning: up to 152 mm/sec - B/W
2 x Gigabit LAN - RJ-45 , 2 x USB 2.0 , 1 x FireWire
Operating System Support
MS Windows XP SP2 or later, Apple Mac OS X 10.4, Apple Mac OS X 10.5, Apple Mac OS X 10.6, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits)
Software Included
Drivers & Utilities
300 Watt
Power Consumption Standby
65.3 Watt
Power Consumption Sleep
7 Watt
USB cable, stand, Ethernet cable, Firewire cable, spindle
FCC Class A certified, CSA, VCCI, GOST, VCCI Class A ITE, PSB, MOC, IRAM, RoHS, EN 60950-1, WEEE, ACA, REACH, BSMI Class A, ICES Class A, KCC Class A, LVD, EMC Class A, CCC Class A
190 cm
100 cm
160 cm
200 kg
Shipping Width
193 cm
Shipping Depth
76.6 cm
Shipping Height
152.9 cm
Shipping Weight
280 kg
Sound Emission
32 dBA (idle) / 47 dBA (operating)
5 °C
20 - 80%
9HFS HP Bright White Inkjet Paper-914 mm x 45.7 m In Stock £18.26
9HFS HP Coated Paper-1067 mm x 45.7 m (42in x 150ft) In Stock £36.29
