Proven, flexible, capable: a consistently reliable PC that delivers proven technology, flexible productivity tools, and security features that are designed to provide a capable foundation for your business.
Having choices is ideal
A flexible and expandable PC that best suits your needs with a blend of ports, slots, and bays so you can create a customized solution. -
Easy to deploy and manage
Streamline business processes while lowering IT costs and operating expenses with features that allow for more efficient planning, deployment, and transition of PCs. -
Security that's right for you
Essential security features you can depend on to help protect both your physical assets and critical business data.
- HP Compaq 6005 Pro - SFF - Athlon II X2 B28 3.4 GHz - 2 GB - HDD 500 GB
- Personal computer - small form factor - administrator password, USB port control
- Localisation
- Processor
- AMD Athlon II X2 B28 / 3.4 GHz (Dual-Core)
- Cache Memory
- 2 MB L2 Cache
- Cache Per Processor
- 2 MB
- RAM
- 2 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-10600
- Storage Controller
- SATA (SATA 3Gb/s)
- Hard Drive
- HDD 500 GB - SATA 3Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- 22 in 1
- Graphics Controller
- ATI Radeon HD 4200 Shared Video Memory (UMA)
- Audio Output
- Stereo - integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition
- Microsoft Office Preloaded
- Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
- 33.8 cm x 37.9 cm x 10 cm
- 7.3 kg
- Manufacturer Selling Program
- HP Smart Buy
- Personal computer
- Product Form Factor
- Small form factor
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.4 GHz
- Number of Cores
- Dual-Core
- 64-bit Computing
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- AMD 785G
Cache Memory
- Installed Size
- L2 Cache - 2 MB
- 2 MB
RAM
- Installed Size
- 2 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1333 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total) / 2 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 2 x 1 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 3Gb/s
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ)
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 3Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
- Read Speed
- 40x (CD) / 16x (DVD)
- Write Speed
- 40x (CD) / 16x (DVD±R) / 12x (DVD±R DL)
- CD / DVD Rewrite Speed
- 32x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
Card Reader
- 22 in 1 card reader
- Supported Flash Memory Cards
- CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, miniSD, RS-MMC, MultiMediaCardmobile, microSD, MultiMediaCardplus, SDHC Memory Card, miniSDHC, microSDHC, Memory Stick PRO-HG Duo
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Mouse, keyboard
- Integrated
- Ethernet Controller
- Broadcom BCM5761
- Data Link Protocol
- Remote Management Protocol
- DMI 2.0, ASF 2.0
- Wake on LAN (WoL), ACPI support, PXE support
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
- Bays
- 1 (total) / 0 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x external 3.5" x 1/3H , 1 (total) / 0 (free) x internal 3.5" x 1/3H
- Slots
- 4 (total) / 2 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCI - low-profile , 2 (total) / 2 (free) x PCIe x1 - low-profile , 1 (total) / 1 (free) x PCIe x16 - low-profile , 1 (total) / 0 (free) x CPU
- 10 x USB 2.0 (4 front, 6 rear) , 1 x audio line-in/microphone , 1 x audio line-out , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x LAN (Gigabit Ethernet) , 1 x serial , 1 x VGA , 1 x DisplayPort
- Administrator password, USB port control
- Theft/Intrusion Protection
- ACPI, RoHS, WEEE
- HP Smart Buy
- Power supply
- Voltage Required
- Power Provided
- 240 Watt
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- OS Certified
- Red Hat Enterprise Linux, SUSE Linux Enterprise Desktop 11
- 33.8 cm
- 37.9 cm
- 10 cm
- 7.3 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
