HP Colour LaserJet Pro MFP M477fdw
Quicklinx: BPMNWS00 Mfr#: CF379A#B19
  • Speed through tasks
    Scan digital files directly to email, USB, network folders, and the cloud with preloaded business apps.Grab pages and go – without waiting around. This MFP wakes up and prints faster than the competition.Breeze through multipage documents with two-sided printing that's the fastest in its class of devices.Control access to print jobs and help keep printing safe with security features like LDAP authentication, HP JetAdvantage Private Print or optional Job Storage with PIN printing.
  • Easy management
    Easily manage print jobs directly at the MFP – just tap and swipe the 10.9 cm touchscreen.Easily print Microsoft Word and PowerPoint documents – now directly from your USB drive.Easily manage devices and settings using HP Web Jetadmin with a suite of essential management features.Print using less energy than competitors – enhanced by Original HP Toner cartridges with JetIntelligence.
  • More
    Get the most prints for your money – with Original HP High Yield Colour Toner cartridges with JetIntelligence.Count on consistent professional quality at high speeds with HP ColorSphere 3 toner.Help ensure you're getting the authentic HP quality you paid for with innovative anti-fraud technology.Print right away with preinstalled toner cartridges. Replace them with optional high-yield cartridges.
  • Stay connected with easy mobile printing options
    Easily print from a variety of smartphones and tablets – generally no setup or apps required.Count on wireless direct printing in the office – from mobile devices – without accessing the company network.Help workers print with just a touch of their NFC-enabled mobile device to the printer – no network needed.Easily access, print, and share resources with Ethernet and wireless networking.
HP Color LaserJet Pro MFP M477fdw - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Speed
Up to 27 ppm (mono) / up to 27 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 38400 x 600 dpi (mono) / up to 38400 x 600 dpi (colour)
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
54 x 70 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, photo paper, bond paper, glossy photo paper, glossy paper, punched paper, preprinted paper, postcards
Standard Media Capacity
300 sheets
Max Media Capacity
850 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, save to network folder, scan to Cloud, Instant-on Technology, touch-to-print
AC 230 V (50Hz)
41.6 cm x 47.2 cm x 40 cm
23.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Printing Technology
Laser - colour
50000 pages
750 - 4000 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
Fit to page, ID Card Copy, collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, PCLm, URF
Image Enhancement Technology
HP ImageREt 3600
Automatic Duplexing
First Print Out Time B/W
9 sec
First Print Out Time Colour
9.9 sec
Scanning
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
30-bit
Fax Machine
PC Faxing
Yes (send only)
Fax Machine Features
Speed Dialing
120 station(s)
Telephone / Fax Switch
Broadcast Transmission
119 stations
Delayed Transmission
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax memory backup, block fax, poll receive, fax activity reports, print fax log, billing codes
Document & Media Handling
Min Original Size
54 x 70 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 197 x 273 mm, 76 x 127 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
300 sheets
Max Media Capacity
850 sheets
50 sheets
150 sheets
ADF - 50 sheets size: 102 x 152 mm - Legal (216 x 356 mm) weight: 60 g/m² - 90 g/m² , Input tray - 250 sheets size: 100 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , Output tray - 150 sheets
Speed Details
Scanning: up to 47 ipm (A4) - B/W duplex , Scanning: up to 30 ipm (A4) - colour duplex , Printing: up to 28 ppm (Letter A) - B/W (ISO/IEC 24734) , Printing: up to 28 ppm (Letter A) - colour (ISO/IEC 24734) , Printing: up to 27 ppm (A4) - B/W (ISO/IEC 24734) , Printing: up to 27 ppm (A4) - colour (ISO/IEC 24734) , Scanning: up to 26 ppm (A4) - B/W , Scanning: up to 21 ppm (A4) - colour , Copying: up to 28 ppm (Letter A) - B/W , Copying: up to 28 ppm (Letter A) - colour , Copying: up to 27 ppm (A4) - B/W , Copying: up to 27 ppm (A4) - colour , Scanning: up to 26 ppm (Letter A) - B/W , Scanning: up to 21 ppm (Letter A) - colour , Scanning: up to 47 ipm (Letter A) - B/W duplex , Scanning: up to 30 ipm (Letter A) - colour duplex , Printing: up to 24 ipm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 24 ipm (A4) - colour duplex (ISO/IEC 24734) , Printing: up to 25 spm (Letter A) - B/W duplex (ISO/IEC 24734) , Printing: up to 25 ipm (Letter A) - colour duplex (ISO/IEC 24734)
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x modem - RJ-11
Security Protocols & Features
LDAP, SSL, Apple Bonjour, TLS
Operating System Support
UNIX, MS Windows XP SP3, Ubuntu Linux 10.04, Apple Mac OS X 10.7, Ubuntu Linux 11.10, Ubuntu Linux 12.04, Apple Mac OS X 10.8, Fedora 17, Android, iOS, Fedora 18, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, MS Windows XP 64-bit Edition SP3 or later, Apple Mac OS X 10.9, Fedora 19, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Linux Mint 15, Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Ubuntu Linux 13.10, Windows 10 (32/64-bits), SuSe Linux 12.2, SuSe Linux 12.3, SuSe Linux 13.1, Boss 3.0, Boss 5.0, Ubuntu Linux 14.10, Debian Linux 7.x, Fedora 20, Linux Mint 16, Linux Mint 17, Ubuntu Linux 14.04, Debian Linux 6.0.x
Software Included
Drivers & Utilities
AC 230 V (50Hz)
560 Watt
Power Consumption Standby
18.2 Watt
Power Consumption Sleep
2.6 Watt
First Copy Out Time B/W
9.8 sec
First Copy Out Time Colour
12.3 sec
USB cable
Consumables Included
1 x Cartridge (black) - up to 2300 pages , 1 x Cartridge (cyan) - up to 1200 pages , 1 x Cartridge (yellow) - up to 1200 pages , 1 x Cartridge (magenta) - up to 1200 pages
UL, cUL, FCC Part 15.247, RSS-210, FCC CFR47 Part 68, R&TTE, FCC CFR47 Part 15 B, EN 62311, EN 61000-3-3:2008, IECEE CB, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, ICES-003 issue 5 Class B, EN 300 328 V1.8.1:2012, EN 62479:2010, 21 CFR 1040.10, 21 CFR 1040.11, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, CoC, EN55022:2010 Class B, EN 55024:2010, EN 60950-1:2006+A1:2010+A2:2013+A11:2009+A12:2011, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, AS/NZS CISPR22:2008 Class B, ETSI ES203 201
ENERGY STAR Certified
Blue Angel Compliant
41.6 cm
47.2 cm
40 cm
23.2 kg
Shipping Width
59.7 cm
Shipping Depth
49.7 cm
Shipping Height
49 cm
Shipping Weight
26.8 kg
Sound Emission
32 dBA (idle) / 49 dBA (operating)
15 °C
30 °C
10 - 80% (non-condensing)
BPMN HP 410A Black Original LaserJet Toner Cartridge In Stock £66.71
BPMN HP 410A Cyan Original LaserJet Toner Cartridge In Stock £85.99
BPMN HP 410A Magenta Original LaserJet Toner Cartridge In Stock £86.92
BPMN HP 410X High Yield Black Original LaserJet Toner Cartridge In Stock £114.07
BPMN HP 410X High Yield Cyan Original LAS In Stock £154.57
BPMN HP 410X High Yield Magenta Original In Stock £148.02
BPMN HP 410A Yellow Origional Laserjet Toner In Stock £84.56
