Unmatched print, scan, copy, and fax performance plus robust, comprehensive security for how you work. This colour MFP finishes key tasks faster and guards against threats. Original HP Toner cartridges with JetIntelligence produce more pages.
- HP Color LaserJet Pro MFP M477fdn - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Max Copying Speed
- Up to 27 ppm (mono) / up to 27 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 38400 x 600 dpi (mono) / up to 38400 x 600 dpi (colour)
- Scanning
- 1200 x 1200 dpi
- Display
- 4.3"
- Original Size
- 54 x 70 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, photo paper, bond paper, glossy photo paper, glossy paper, punched paper, preprinted paper, postcards
- Standard Media Capacity
- 300 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, save to network folder, scan to Cloud, Instant-on Technology
- Power
- AC 230 V (50Hz)
- 41.6 cm x 47.2 cm x 40 cm
- 23.2 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Fax Type
- Plain paper
- Laser - colour
- 50000 pages
- 750 - 4000 pages
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Fit to page, ID Card Copy, collation copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF, PCLm, URF
- Image Enhancement Technology
- HP ImageREt 3600
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 9.9 sec
Scanning
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 30-bit
Fax Machine
- PC Faxing
- Yes (send only)
Fax Machine Features
- Speed Dialing
- 120 station(s)
- Telephone / Fax Switch
- Broadcast Transmission
- 119 stations
- Delayed Transmission
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax memory backup, block fax, poll receive, fax activity reports, print fax log, billing codes
Document & Media Handling
- Min Original Size
- 54 x 70 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 197 x 273 mm, 76 x 127 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 300 sheets
- 50 sheets
- 150 sheets
- ADF - 50 sheets size: 102 x 152 mm - Legal (216 x 356 mm) weight: 60 g/m² - 90 g/m² , Input tray - 250 sheets size: 100 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , Output tray - 150 sheets
- Speed Details
- Scanning: up to 47 ipm (A4) - B/W duplex , Scanning: up to 30 ipm (A4) - colour duplex , Printing: up to 28 ppm (Letter A) - B/W (ISO/IEC 24734) , Printing: up to 28 ppm (Letter A) - color (ISO/IEC 24734) , Printing: up to 27 ppm (A4) - B/W (ISO/IEC 24734) , Printing: up to 27 ppm (A4) - color (ISO/IEC 24734) , Scanning: up to 26 ppm (A4) - B/W , Scanning: up to 21 ppm (A4) - colour , Copying: up to 28 ppm (Letter A) - B/W , Copying: up to 28 ppm (Letter A) - colour , Copying: up to 27 ppm (A4) - B/W , Copying: up to 27 ppm (A4) - colour , Scanning: up to 26 ppm (Letter A) - B/W , Scanning: up to 21 ppm (Letter A) - colour , Scanning: up to 47 ipm (Letter A) - B/W duplex , Scanning: up to 30 ipm (Letter A) - colour duplex , Printing: up to 24 ipm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 24 ipm (A4) - colour duplex (ISO/IEC 24734) , Printing: up to 25 spm (Letter A) - B/W duplex (ISO/IEC 24734) , Printing: up to 25 ipm (Letter A) - colour duplex (ISO/IEC 24734)
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x modem - RJ-11
- LDAP, SSL, Apple Bonjour, TLS
- Operating System Support
- UNIX, MS Windows XP SP3, Ubuntu Linux 10.04, Apple Mac OS X 10.7, Ubuntu Linux 11.10, Ubuntu Linux 12.04, Apple Mac OS X 10.8, Fedora 17, Android, iOS, Fedora 18, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, MS Windows XP 64-bit Edition SP3 or later, Apple Mac OS X 10.9, Fedora 19, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Linux Mint 15, Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Ubuntu Linux 13.10, Windows 10 (32/64-bits), SuSe Linux 12.2, SuSe Linux 12.3, SuSe Linux 13.1, Boss 3.0, Boss 5.0, Ubuntu Linux 14.10, Debian Linux 7.x, Fedora 20, Linux Mint 16, Linux Mint 17, Ubuntu Linux 14.04, Debian Linux 6.0.x
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V (50Hz)
- 560 Watt
- Power Consumption Standby
- 18.2 Watt
- Power Consumption Sleep
- 2.6 Watt
- First Copy Out Time B/W
- 9.8 sec
- First Copy Out Time Colour
- 12.3 sec
- Included Accessories
- USB cable
- Consumables Included
- 1 x Cartridge (black) - up to 2300 pages , 1 x Cartridge (cyan) - up to 1200 pages , 1 x Cartridge (yellow) - up to 1200 pages , 1 x Cartridge (magenta) - up to 1200 pages
- UL, cUL, FCC Part 15.247, RSS-210, FCC CFR47 Part 68, R&TTE, FCC CFR47 Part 15 B, EN 62311, EN 61000-3-3:2008, IECEE CB, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, ICES-003 issue 5 Class B, EN 300 328 V1.8.1:2012, EN 62479:2010, 21 CFR 1040.10, 21 CFR 1040.11, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, CoC, EN55022:2010 Class B, EN 55024:2010, EN 60950-1:2006+A1:2010+A2:2013+A11:2009+A12:2011, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, AS/NZS CISPR22:2008 Class B, ETSI ES203 201
- ENERGY STAR Certified
- Blue Angel Compliant
- 41.6 cm
- 47.2 cm
- 40 cm
- 23.2 kg
- Shipping Width
- 59.7 cm
- Shipping Depth
- 49.7 cm
- Shipping Height
- 49 cm
- Shipping Weight
- 26.7 kg
- Sound Emission
- 32 dBA (idle) / 49 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
HP 410A Black Original LaserJet Toner Cartridge | In Stock | £63.50 |
HP 410A Cyan Original LaserJet Toner Cartridge | In Stock | £80.48 |
HP 410A Magenta Original LaserJet Toner Cartridge | In Stock | £80.07 |
HP 410X High Yield Black Original LaserJet Toner Cartridge | In Stock | £104.12 |
HP 410X High Yield Cyan Original LAS | In Stock | £137.54 |
HP 410X High Yield Magenta Original | In Stock | £137.54 |
HP 410A Yellow Origional Laserjet Toner | In Stock | £78.39 |
