Ideal printing performance and solid security for how you work. This capable colour printer finishes jobs faster and delivers comprehensive security to guard against threats. Original HP Toner cartridges with JetIntelligence produce more pages.
Shift your office into high gear with a powerful colour printer that doesn’t keep you waiting. Print your first page and two-sided prints faster than the competition, and help keep your device, data, and documents safe – from boot up to shutdown.
Grab pages and go – without waiting around. This printer wakes up and prints faster than the competition. Breeze through multipage documents with two-sided printing that’s faster than leading competitors. Keep printing safe from boot up to shutdown with security features that guard against complex threats.
Easily produce the documents you need to move work forward, and help conserve energy. This power-saving printer is easy to set up and manage, and is built for even the most demanding office environments.
Easily manage tasks directly at the device. The 2-line LCD display is simple to read and operate. Set up this printer fast and easily manage device settings to help increase overall printing efficiency.
Print more professional-quality colour pages than ever before. Specially designed Original HP Toner cartridges with JetIntelligence deliver better performance, higher energy efficiency and authentic HP quality which the competition can’t match.
Get the most prints for your money – with Original HP High Yield Colour Toner cartridges with JetIntelligence. Count on professional quality at high speeds with HP ColorSphere 3 toner. Help ensure you’re getting the authentic HP quality you paid for with innovative anti-fraud technology. Print right away with preinstalled toner cartridges. Replace them with optional high-yield cartridges.
Keep your business nimble when needs shift or opportunity strikes – in the office or on the go. Ethernet capabilities help you stay connected and work with ease – from right where you are.
Easily print from a variety of smartphones and tablets – generally no setup or apps required. Easily set up, print, and share with built-in Ethernet networking.
- HP Color LaserJet Pro M452dn - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 18.9 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 27 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 27 ppm - colour (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 28 ppm - B/W (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm) , Up to 28 ppm - colour (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm) , Up to 49 ppm - black draft - A5 (148 x 210 mm) , Up to 49 ppm - colour draft - A5 (148 x 210 mm) , Up to 7 ppm - black best - A5 (148 x 210 mm) , Up to 7 ppm - colour best - A5 (148 x 210 mm) , Up to 24 ipm - B/W duplex (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 24 ipm - colour duplex (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 25 ipm - B/W duplex (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm) , Up to 25 ipm - colour duplex (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 38400 x 600 dpi
- Max Resolution (Colour)
- 38400 x 600 dpi
- Image Enhancement Technology
- HP ImageREt 3600
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 128 MB (128 MB)
- Flash Memory Installed (Max)
- 256 MB (256 MB)
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PDF, PCLm, URF, PWG
- Media Type
- Envelopes, labels, plain paper, photo paper, bond paper, recycled paper, punched paper, preprinted paper, postcards, glossy paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Networking
- Print server
- Printer Features
- PANTONE calibrated, Instant-on Technology
- Power
- AC 230V
- System Requirements
- UNIX, Android, Microsoft Windows Vista (32/64 bits), Ubuntu 10.04, Microsoft Windows XP (32/64 bits) SP3, Apple MacOS X Lion 10.7, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, openSUSE 12.2, Apple MacOS X 10.8, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Red Hat Fedora 18, openSUSE 12.3, Linux Mint 13, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, openSUSE 13.1, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x, Microsoft Windows 7 / 8 (32/64 bits)
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 41.2 cm x 46.9 cm x 29.5 cm
- Printer Type
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 38400 x 600 dpi
- 38400 x 600 dpi
- HP ImageREt 3600
- PostScript Support
- Standard
- Fonts Included
- 84 x TrueType
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 128 MB / 128 MB (max)
Flash Memory
- Flash Memory
- 256 MB (installed) / 256 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), 197 x 273 mm, 76 x 127 mm, Oficio (216 x 343 mm), JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 200 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m²
- Max Media Capacity
- 850 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 50000 pages
- 750 - 4000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS, SLP
- SSL, Apple Bonjour, TLS, 802.1x
- Connections
- 1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 1200 pages ISO/IEC 19752 - HP 410A , 1 x toner cartridge (cyan) - up to 1200 pages ISO/IEC 19752 - HP 410A , 1 x toner cartridge (magenta) - up to 1200 pages ISO/IEC 19752 - HP 410A , 1 x toner cartridge (yellow) - up to 1200 pages ISO/IEC 19752 - HP 410A
- FCC Class B certified, UL, CISPR 22 Class B, cUL, GS, EMC, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, EN 61000-3-3:2008, IECEE CB, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, ICES-003 issue 5 Class B, EN 62479:2010, LVD 2006/95/EC, 21 CFR 1040.10, 21 CFR 1040.11, CoC, IEC 60950-1:2005 + A1:2009, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN55024:2010, EN 55022:2010 Class B
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50 Hz
- 570 Watt
- Power Consumption Stand by
- 17.6 Watt
- Power Consumption Sleep
- 2.4 Watt
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Windows XP - 233 MHz - RAM 512 MB - HD 400 MB , MacOS X 10.7 or later - HD 1 GB
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - 1 year
- 15 °C
- 30 °C
- 10 - 80%
- Sound Emission (Idle)
- 34 dBA
- Sound Emission (Operating)
- 49 dBA
- 41.2 cm
- 46.9 cm
- 29.5 cm
- 18.9 kg
- Width (Shipping)
- 49.7 cm
- Depth (Shipping)
- 37.9 cm
- Height (Shipping)
- 58.3 cm
- Weight (Shipping)
- 22 kg
HP 410A Black Original LaserJet Toner Cartridge | In Stock | £64.87 |
HP 410A Cyan Original LaserJet Toner Cartridge | In Stock | £84.01 |
HP 410A Magenta Original LaserJet Toner Cartridge | In Stock | £83.78 |
HP 410X High Yield Black Original LaserJet Toner Cartridge | In Stock | £114.36 |
HP 410X High Yield Cyan Original LAS | In Stock | £142.54 |
HP 410X High Yield Magenta Original | In Stock | £145.81 |
HP 410A Yellow Origional Laserjet Toner | In Stock | £83.78 |
