Ideal for businesses that want to boost productivity and print professional-quality marketing materials without leaving the office. This networked HP Color LaserJet Pro MFP prints, copies and scans in vibrant colour.
Fit this compact, colour MFP in small spaces, and finish print jobs in fewer steps
Get brilliant, consistent colour using Original HP LaserJet print cartridges, and print crisp text at the same black cost-per-page as from a black-and-white HP LaserJet.Handle big copy jobs with the 35-page automatic document feeder, while you work on other business.Expand your media options with support for a wide variety of media types.Speed through document tasks: get the first print out in a matter of seconds. Set the pace for success with an MFP that prints, copies, scans and faxes fast. -
Easy control at your fingertips
Set up each task with just a few simple taps on the 7.6 cm colour touchscreen, and access apps that make document management easier.Easily copy both sides of a two-sided ID or other small document onto the front of a single-page.Help save energy with HP Auto-On/Auto-Off Technology – intelligence that can turn your printer on when you need it and off when you don't. -
Print on your terms
Print from virtually anywhere using your smartphone, tablet, and PC – with HP ePrint and Apple AirPrint.Extend your printing reach. Easily set up, print, and share using built-in Ethernet and wireless connectivity.Easily manage your MFP with convenient device management tools.
- HP Color LaserJet Pro MFP M177fw - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 20000 pages
- Recommended Monthly Volume
- 250 - 950 pages
- Max Copying Speed
- Up to 16 ppm (mono) / up to 4 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 400 dpi (colour)
- Max Printing Speed
- Up to 17 ppm (mono) / up to 4 ppm (colour)
- Max Printing Resolution
- Up to 2400 dpi (mono) / up to 2400 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 203 x 392 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 3"
- Original Size
- Legal (216 x 356 mm) (max)
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels, photo paper, film, glossy paper
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 50 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to application
- Power
- AC 230 V (50/60Hz)
- 42.3 cm x 42.5 cm x 33.5 cm
- 16 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Laser - colour
- 20000 pages
- 250 - 950 pages
- Display Diagonal Size
- 3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 128 MB
- Max Supported Memory
- 128 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCL
- Image Enhancement Technology
- HP ImageREt 2400
- First Print Out Time B/W
- 16 sec
- First Print Out Time Colour
- 27.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 500 pages
- Fax Printing Speed
- Up to 20 ppm
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 100 stations
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending, fax polling
Document & Media Handling
- Max Original Size
- 35 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 101.6 x 152.4 mm, 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 50 sheets
- ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 150 sheets - Legal (216 x 356 mm) , Output tray - 50 sheets
- Speed Details
- Printing: up to 17 ppm (Letter A) - B/W , Printing: up to 4 ppm (Letter A) - colour , Printing: up to 16 ppm (A4) - B/W , Printing: up to 4 ppm (A4) - colour , Copying: up to 17 ppm (Letter A) - B/W , Copying: up to 4 ppm (Letter A) - colour , Copying: up to 16 ppm (A4) - B/W , Copying: up to 4 ppm (A4) - colour , Scanning: up to 7.5 ipm - B/W , Scanning: up to 5.5 ipm - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- WEP, WPA, WPA2
- Operating System Support
- Linux, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 SP1 or later, MS Windows XP 64-bit Edition SP2 or later, MS Windows Server 2012, Windows 8, MS Windows Server 2008 R2 SP1
- Software Included
- Drivers & Utilities, Readiris
- Voltage Required
- 290 Watt
- Power Consumption Standby
- 9.2 Watt
- Power Consumption Sleep
- 1.3 Watt
- First Copy Out Time B/W
- 15 sec
- First Copy Out Time Colour
- 28 sec
- Included Accessories
- USB cable, phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 500 pages , 1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages , 1 x toner cartridge (yellow) - up to 500 pages
- UL, cUL, GS, ICES-003, EN55024, CISPR 22, EN55022 Class B, EMC, Laser Class 1, IEC 60950-1, FCC CFR47 Part 15 B, EN 60825-1, GB 17625.1, Directive 2004/108/EC, GB 9254-2008, Directive 2006/95/EC, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60950-1:2006, IEC 60825-1:2007
- ENERGY STAR Certified
- Limited warranty - 1 year
- 42.3 cm
- 42.5 cm
- 33.5 cm
- 16 kg
- Shipping Width
- 59.8 cm
- Shipping Depth
- 46.4 cm
- Shipping Height
- 39.8 cm
- Shipping Weight
- 19.6 kg
- Sound Emission
- 53 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80%
HP 130A Black LaserJet Toner Cartridge | In Stock | £49.86 |
HP 130A Cyan LaserJet Toner Cartridge | In Stock | £51.41 |
HP 130A Yellow LaserJet Toner Cartridge | In Stock | £51.41 |
HP 130A Magenta LaserJet Toner Cartridge | In Stock | £51.41 |
