HP Colour LaserJet Managed MFP M775zm Printer
Quicklinx: C78MWS00 Mfr#: L3U50A#B19
Functionality: Copier, Fax, Printer, Scanner
Output Type: Colour
Technology: Laser
Max Paper Size: 320 x 470 mm
£4,055.18 ex VAT
£4,866.21 inc VAT
HP LaserJet 700 M775zm Laser Multifunction Printer - Colour - Plain Paper Print - 30 ppm Mono/30 ppm Color Print - Ethernet - USB
PC Connection: Gigabit LAN, USB 2.0 host, USB 2.0 Printing Output Type: Colour Type of Machine: Fax / copier / printer / scanner - all-in-one Ink type: Laser Printing speed (monochrome): 30 ppm (mono) Printing speed (colour): 30 ppm (color)
HP LaserJet Managed MFP M775zm - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
180000 pages
Recommended Monthly Volume
2500 - 30000 pages
Max Copying Speed
Up to 30 ppm (mono) / up to 30 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 dpi
Display
8"
Original Size
A3 (297 x 420 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76 x 127 mm (min) - 320 x 470 mm (max)
Media Type
Envelopes, plain paper, labels, recycled paper, greeting cards, film, heavy-weight paper, thin paper, thick paper, card stock, glossy paper, matte paper, preprinted paper, semi-gloss paper
Standard Media Capacity
1850 sheets
Max Media Capacity
1850 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Stacker
Included
Stapler
Included
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Hardware Integration Pocket, HP High-Performance Secure Hard Disk
AC 230 V (50/60Hz)
107.7 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
180000 pages
2500 - 30000 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1.5 GB
Max Supported Memory
1.5 GB
Hard Disk Drive
320 GB
Copying
Max Copying Speed
Maximum Copies
9999
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PDF 1.4, PCL 5
Automatic Duplexing
First Print Out Time B/W
10.5 sec
First Print Out Time Colour
10.5 sec
Scanning
Scan Element
CCD
Automatic Duplexing
Optical Resolution
600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Document & Media Handling
Max Original Size
A3 (297 x 420 mm)
Original Type
Sheets
100 sheets
Min Media Size
76 x 127 mm
Max Media Size
A3/Ledger
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 297 x 432 mm, 148 x 182 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), SRA4 (225 x 320 mm), 76 x 127 mm, 320 x 470 mm, JIS B6 (128 x 182 mm), A5 Maxi, RA4 (215 x 305 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
1850 sheets
Max Media Capacity
1850 sheets
100 sheets
500 sheets
RADF - 100 sheets - A3 (297 x 420 mm) , Bypass tray - 100 sheets size: 76 x 127 mm - 320 x 470 mm weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: 148 x 182 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 220 g/m² , 3 x input tray - 500 sheets size: A5 (148 x 210 mm) - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 220 g/m² , Stacker / stapler - 500 sheets
Speed Details
Printing: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Printing: up to 30 ipm (A4) - B/W duplex , Printing: up to 15 ppm (A3) - B/W , Printing: up to 15 ppm (A3) - colour , Copying: up to 30 ppm (A4) - B/W , Copying: up to 30 ppm (A4) - colour , Scanning: up to 30 ppm - B/W , Scanning: up to 30 ppm - colour , Scanning: up to 14 ppm - B/W duplex , Scanning: up to 14 ppm - colour duplex
Finishing Equipment
Stacker
Included
Stapler
Included
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x modem - RJ-11
Security Protocols & Features
SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP, WPA2-Enterprise
Operating System Support
MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Windows 8, MS Windows Server 2008 (32/64-bits)
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
703 Watt
Power Consumption Standby
85 Watt
Power Consumption Sleep
14.8 Watt
Phone cable, stand
Consumables Included
1 (black) - up to 13500 pages , 1 (cyan) - up to 16000 pages , 1 (magenta) - up to 16000 pages , 1 (yellow) - up to 16000 pages
FCC CFR47, GB 9254-2008, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN55024:1998 + A1 + A2, EMC 2004/108/EC, EN55022:2010 Class A, GB 17625.1-2003, CISPR 22:2008
ENERGY STAR Certified
Limited warranty - 1 year
107.7 kg
Shipping Weight
126.7 kg
Sound Emission
53 dBA (operating)
15 °C
27 °C
30 - 70%
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Technology: Laser
Brand: HP
Price Range Ex VAT: 1500+
