Reliable, affordable A3 color printing that grows with your business. HP Managed MFPs and printers are optimized for managed environments. Offering increased monthly page volumes and fewer interventions, this portfolio of products can help reduce printing and copying costs.
Expand possibilities with broad capabilities and brilliant color with this affordable A3 MFP
Increase color printing capabilities with media sizes up to A3 for impressive marketing materials and more. Impress with bold text and smooth color and get the color output you intended with Pantone matching. Go from start to finish, right at the MFP - print, copy, scan and fax from the large touchscreen. Print from your smartphone or tablet from virtually anywhere with HP ePrint. Boost productivity and easily manage printing. Boost productivity - get up to 4,350-sheet paper capacity for large printing jobs from this workhorse MFP. Automate high-volume print jobs to save time, using the 100-page automatic document feeder. Easily manage your business's color printing with HP color access controls. Save and print files directly at the MFP via an easy-access USB port. -
Streamline your workflow with robust scanning
Improve workflow using touchscreen controls to preview, edit and digitally send documents at the device. Streamline tasks: print, copy, fax and scan projects directly at the MFP's large color touchscreen. Incorporate paper documents into digital workflows - easily send scans to fax, e-mail or network folders. Efficiently capture the right content: remove blank pages in scanned documents to avoid wasted paper. -
Invest in robust security that grows with you
Extend the capabilities of workteam print environments, using a rich array of easy-to-integrate solutions. Boost printing and imaging safeguards and protect business data with fleet-level security solutions. Add security solutions such as card and badge readers through the hardware integratio pocket. Help control expenses with energy-saving features.
- HP LaserJet Managed MFP M775fm - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 180000 pages
- Recommended Monthly Volume
- 2500 - 30000 pages
- Max Copying Speed
- Up to 30 ppm (mono) / up to 30 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 dpi
- Display
- 8"
- Original Size
- A3 (297 x 420 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min) - 320 x 470 mm (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, greeting cards, film, heavy-weight paper, thin paper, thick paper, card stock, glossy paper, matte paper, preprinted paper, semi-gloss paper
- Standard Media Capacity
- 1350 sheets
- Max Media Capacity
- 1350 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 175 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Hardware Integration Pocket, HP High-Performance Secure Hard Disk
- Power
- AC 230 V (50/60Hz)
- 96.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Laser - colour
- 180000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1.5 GB
- Max Supported Memory
- 1.5 GB
- Hard Disk Drive
- 320 GB
Copying
- Max Copying Speed
- Maximum Copies
- 9999
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF 1.4, PCL 5
- First Print Out Time B/W
- 10.5 sec
- First Print Out Time Colour
- 10.5 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
Document & Media Handling
- Max Original Size
- A3 (297 x 420 mm)
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 297 x 432 mm, 148 x 182 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), SRA4 (225 x 320 mm), 76 x 127 mm, 320 x 470 mm, JIS B6 (128 x 182 mm), A5 Maxi, RA4 (215 x 305 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 1350 sheets
- 1350 sheets
- 100 sheets
- 175 sheets
- RADF - 100 sheets - A3 (297 x 420 mm) , Bypass tray - 100 sheets size: 76 x 127 mm - 320 x 470 mm weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: 148 x 182 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 220 g/m² , 2 x input tray - 500 sheets size: A5 (148 x 210 mm) - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 220 g/m² , Output tray - 175 sheets
- Speed Details
- Printing: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Printing: up to 30 ipm (A4) - B/W duplex , Printing: up to 15 ppm (A3) - B/W , Printing: up to 15 ppm (A3) - colour , Copying: up to 30 ppm (A4) - B/W , Copying: up to 30 ppm (A4) - colour , Scanning: up to 30 ppm - B/W , Scanning: up to 30 ppm - colour , Scanning: up to 14 ppm - B/W duplex , Scanning: up to 14 ppm - colour duplex
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x modem - RJ-11
- SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP, WPA2-Enterprise
- Operating System Support
- MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Windows 8, MS Windows Server 2008 (32/64-bits)
- Software Included
- Drivers & Utilities
- Voltage Required
- 703 Watt
- Power Consumption Standby
- 85 Watt
- Power Consumption Sleep
- 14.8 Watt
- Included Accessories
- Phone cable, stand
- Consumables Included
- 1 (black) - up to 13500 pages , 1 (cyan) - up to 16000 pages , 1 (magenta) - up to 16000 pages , 1 (yellow) - up to 16000 pages
- FCC CFR47, GB 9254-2008, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN55024:1998 + A1 + A2, EMC 2004/108/EC, EN55022:2010 Class A, GB 17625.1-2003, CISPR 22:2008
- ENERGY STAR Certified
- Limited warranty - 1 year
- 96.8 kg
- Shipping Weight
- 116 kg
- Sound Emission
- 53 dBA (operating)
- 15 °C
- 27 °C
- 30 - 70%
