HP Managed MFPs and printers are optimized for managed environments. Offering increased monthly page volumes and fewer interventions, this portfolio of products can help reduce printing and copying costs.
Boost your workflow
Get more done, faster: scan two-sided documents in a single pass. No missed pages, no flipping pages by hand. Preview and edit scans, adjust images, and launch standard processes, all at the 20 cm color touchscreen. Fast, accurate input: enter data more quickly and accurately, using the pull-out keyboard. Print without wires or a network. Get easy access to the MFP through optional wireless direct printing. Mobile printing at a touch: enable touch-to-print convenience from mobile devices. Easily print from smartphones, tablets and notebooks at work, home or on the go. -
Mopria-certified
Pull print jobs from your pocket - walk up and print or scan from your USB drive. -
Ready, set, grow
Secure your investment - depend on an MFP that can expand with your business, whenever solutions advance. Keep a close watch, even from afar - centrally monitor and control your MFPs with HP.
- HP Color LaserJet Managed Flow MFP M880zm - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 300000 pages
- Recommended Monthly Volume
- 5000 - 50000 pages
- Max Copying Speed
- Up to 46 ppm (mono) / up to 46 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 200 dpi, 100 x 100 dpi
- Scanning
- 600 dpi
- Display
- 8"
- Original Size
- 147 x 68 mm (min) - A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 200 sheets
- Media Size
- 76.2 x 127 mm (min) - 320 x 457.2 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, photo paper, film, glossy paper
- Standard Media Capacity
- 2100 sheets
- Max Media Capacity
- 2100 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Stacker
- Optional
- Stapler
- Optional
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host, USB 2.0 host (internal)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to network, Hardware Integration Pocket, Foreign Interface Harness (FIH), HP High-Performance Secure Hard Disk, pull-out keyboard
- Power
- AC 230 V (50Hz)
- 70.4 cm x 63.5 cm x 119.9 cm
- 150.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Laser - colour
- 300000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 2.5 GB
- Max Supported Memory
- 2.5 GB
- Hard Disk Drive
- 320 GB
Copying
- Max Copying Speed
- Maximum Copies
- 9999
Printing
- First Print Out Time B/W
- 11 sec
- First Print Out Time Colour
- 11 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Fax Printing Resolution
- 300 x 300 dpi
Fax Machine Features
- One-Touch Dialing
- 100 station(s)
- Fax forwarding
Document & Media Handling
- Min Original Size
- 147 x 68 mm
- Max Original Size
- Original Type
- Sheets
- 200 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 297 x 432 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), SRA4 (225 x 320 mm), 76.2 x 127 mm, RA3 (305 x 430 mm), 320 x 457 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 2100 sheets
- 2100 sheets
- 100 sheets
- 500 sheets
- ADF - 200 sheets size: 147 x 68 mm - A3/Ledger (297 x 432 mm) , Bypass tray - 100 sheets size: 76.2 x 127 mm - 320 x 457.2 mm weight: 60 g/m² - 220 g/m² , Input tray - 500 sheets size: A5 (148 x 210 mm) - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 220 g/m² , 3 x input tray - 500 sheets size: A5 (148 x 210 mm) - 320 x 457 mm weight: 60 g/m² - 220 g/m² , Output tray - 500 sheets
- Speed Details
- Printing: up to 46 ppm (A4) - B/W , Printing: up to 46 ppm (A4) - colour , Printing: up to 43 ipm (A4) - B/W duplex , Printing: up to 43 ipm (A4) - colour duplex , Printing: up to 22 ppm (A3) - B/W , Printing: up to 22 ppm (A3) - colour , Copying: up to 46 ppm (A4) - B/W , Copying: up to 46 ppm (A4) - colour , Scanning: up to 70 ppm - B/W , Scanning: up to 68 ppm - colour , Scanning: up to 85 ipm - B/W duplex , Scanning: up to 63 ipm - colour duplex
Finishing Equipment
- Stacker
- Optional
- Stapler
- Optional
- 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host (internal) , 1 x modem - RJ-11
- Kerberos, LDAP, SSL, TLS, 802.1x, EAP-TLS, PEAP
- Operating System Support
- MS Windows XP SP2 or later, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6.8, Apple Mac OS X 10.7.5, MS Windows Server 2008 (32/64-bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Windows 8 (32/64-bits)
- Voltage Required
- AC 230 V (50Hz)
- 1100 Watt
- Power Consumption Standby
- 80 Watt
- Power Consumption Sleep
- 8 Watt
- Included Accessories
- Phone cable, stand
- Consumables Included
- 1 x drum (black) - up to 30000 pages , 1 x drum (cyan) - up to 30000 pages , 1 x drum (magenta) - up to 30000 pages , 1 x drum (yellow) - up to 30000 pages , 1 x Cartridge (black) - up to 29500 pages , 1 x Cartridge (cyan) - up to 32000 pages , 1 x Cartridge (magenta) - up to 32000 pages , 1 x Cartridge (yellow) - up to 32000 pages
- EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EMC 2004/108/EC, EN 55024:2010, EN 55022:2010 Class A, CISPR 22:2008
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site - response time: next business day
- 70.4 cm
- 63.5 cm
- 119.9 cm
- 150.6 kg
- Shipping Width
- 85.6 cm
- Shipping Depth
- 79 cm
- Shipping Height
- 156.7 cm
- Shipping Weight
- 173.33 kg
- Sound Emission
- 55 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80%
