Increase productivity with a colour MFP
Get the fastest in-class two-sided printing speed and First Page Out Time (FPOT).Get automatic two-sided printing, and breeze through tasks with a 50-page automatic document feeder.Scan digital files directly to email, network folders, and more. Safeguard data, devices, and documents.Stay productive and change paper less often with a 250-sheet capacity paper tray.Speed through multipage documents with automatic two-sided printing. -
More
Count on high-quality colour and more pages with Original HP Toner cartridges with JetIntelligence.Get the Original HP quality you paid for with anti-fraud technology.Spend less time replacing toner, with optional high-yield cartridges.Speed through print jobs right out of the box, using preinstalled Original HP Toner cartridges. -
Easy mobile printing and scanning – HP Smart app
Print and scan from your smartphone, and easily order toner, with the HP Smart app.Have confidence in your connection with steady performance from dual band Wi-Fi .Connect your smartphone or tablet directly to your printer – and easily print without accessing a network.Simply tap the print button on your smartphone or tablet to print.
- HP Color LaserJet Pro MFP M281fdw - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 40000 pages
- Recommended Monthly Volume
- 150 - 2500 pages
- Max Copying Speed
- Up to 21 ppm (mono) / up to 21 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.7"
- Original Size
- 102 x 152 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, greeting cards, photo paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, save to network folder, Instant-on Technology
- Power
- AC 230 V (50/60Hz)
- 42 cm x 42.17 cm x 33.41 cm
- 18.7 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty (Austria, Germany - 3 years with product registration)
- Fax Type
- Plain paper
- Laser - colour
- 40000 pages
- 150 - 2500 pages
- Display Diagonal Size
- 2.7"
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Fit to page, ID Card Copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF, PCLm, URF
- Image Enhancement Technology
- HP ImageREt 3600
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 1300 pages
- PC Faxing
- Yes (send only)
Fax Machine Features
- Speed Dialing
- 120 station(s)
- Broadcast Transmission
- 119 stations
- Delayed Transmission
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), poll receive
Document & Media Handling
- Min Original Size
- 102 x 152 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 1 sheet
- 100 sheets
- Bypass tray - 1 sheet , Input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: 102 x 152 mm - Legal (216 x 356 mm) weight: 60 g/m² - 75 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 21 ppm (A4) - B/W (ISO) , Printing: up to 21 ppm (A4) - colour (ISO) , Printing: up to 21 ppm (Letter A) - B/W (ISO) , Printing: up to 21 ppm (Letter A) - colour (ISO) , Copying: up to 21 ppm (A4) - B/W normal , Copying: up to 21 ppm (A4) - colour normal , Copying: up to 12 ppm (A4) - B/W duplex , Copying: up to 12 ppm (A4) - colour duplex , Scanning: up to 26 ppm (A4)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x modem - RJ-11
- Operating System Support
- UNIX, Sun Solaris 8, MS Windows XP SP3, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows XP 64-bit Edition, SuSe Linux 10.3, HP-UX 11.0, Ubuntu Linux 9.10, Ubuntu Linux 10.04, MS Windows Server 2008 R2, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Apple Mac OS X 10.7, Debian Linux 5.0, Red Hat Enterprise Linux 5, MS Windows Server 2008 R2 x64 Edition, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 11.10, Ubuntu Linux 12.04, Ubuntu Linux 8.04, Oracle Solaris 9, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, Fedora 17, MS Windows Server 2012 x64 Edition, Android, iOS, Fedora 18, openSUSE 12.2, openSUSE 12.3, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, Apple Mac OS X 10.9, Windows 8.1 64-bit, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, Fedora 19, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Linux 9.4, Linux 9.5, Ubuntu Linux 8.04.1, Ubuntu Linux 8.04.2, Ubuntu Linux 13.04, Linux Mint 15, Windows RT 8, Apple Mac OS X 10.10, Windows 8 Pro, Windows 8 Pro 64-bit, Windows 8 Enterprise, Windows 8 Enterprise 64-bit, Windows 8 Enterprise N, Windows 8 Enterprise N 64-bit, Ubuntu Linux 13.10, SuSe Linux 13.1, Boss 3.0, Boss 5.0, Ubuntu Linux 14.10, Debian Linux 7.x, Fedora 20, Linux Mint 16, Linux Mint 17, Ubuntu Linux 14.04, Debian Linux 6.0.x, Novell NetWare 6.5 SP8, Novell Open Enterprise Server 11 SP1, Novell Open Enterprise Server 2
- Software Included
- Drivers & Utilities
- Voltage Required
- 342 Watt
- Power Consumption Standby
- 8 Watt
- Power Consumption Sleep
- 1.2 Watt
- First Copy Out Time B/W
- 11.1 sec
- First Copy Out Time Colour
- 13.9 sec
- Consumables Included
- 1 x Cartridge (black) - up to 1400 pages , 1 x Cartridge (cyan) - up to 700 pages , 1 x Cartridge (magenta) - up to 700 pages , 1 x Cartridge (yellow) - up to 700 pages
- FCC Class B certified, CISPR 22 Class B, CB, RSS-210, FCC CFR47 Part 68, R&TTE, Laser Class 1, FCC CFR47 Part 15, FCC CFR47 Part 15 C, TBR21, EN 60825-1, CECP, EN 61000-3-3:2008, CSA C22.2 No. 60950-1-07 Second Edition, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, ICES-003 issue 5 Class B, EN 62479:2010, EN 300 328, 21 CFR 1040.10, 21 CFR 1040.11, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, IEC60950-1:2005+A1:2009, EN 55024:2010, EN 62311:2008, IEC 62479:2010, ETSI ES203 201, IEC 62311:2007, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN 55022:2010 Class B
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 42 cm
- 42.17 cm
- 33.41 cm
- 18.7 kg
- Shipping Width
- 49.8 cm
- Shipping Depth
- 39.8 cm
- Shipping Height
- 53.2 cm
- Shipping Weight
- 21.5 kg
- Sound Emission
- 52 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
