HP Colour Laserjet M281fdn MFP
Quicklinx: D3ZNWS00 Mfr#: T6B81A#B19
13 in stock
£196.22 ex VAT
£235.46 inc VAT
  • Increase productivity with a colour MFP
    Get the fastest in-class two-sided printing speed and First Page Out Time (FPOT).Get automatic two-sided printing, and breeze through tasks with a 50-page automatic document feeder.Scan digital files directly to email, network folders, and more. Safeguard data, devices, and documents.Easily manage tasks at the device with an intuitive touchscreen. Print documents directly from a USB drive.Get versatile performance and print, scan, copy, and fax.
  • More
    Count on high-quality colour and more pages with Original HP Toner cartridges with JetIntelligence.Get the Original HP quality you paid for with anti-fraud technology.Spend less time replacing toner, with optional high-yield cartridges.Speed through print jobs right out of the box, using preinstalled Original HP Toner cartridges.
  • Easy mobile printing and scanning – HP Smart app
    Print and scan from your smartphone, and easily order toner, with the HP Smart app.Simply tap the print button on your smartphone or tablet to print.Easily print from a variety of smartphones and tablets.Easily share resources – access and print with Ethernet networking.
HP Color LaserJet Pro MFP M281fdn - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
40000 pages
Recommended Monthly Volume
150 - 2500 pages
Max Copying Speed
Up to 21 ppm (mono) / up to 21 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
Scanning
1200 x 1200 dpi
Display
2.7"
Original Size
102 x 152 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, photo paper, heavy-weight paper, light-weight paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, save to network folder, Instant-on Technology
AC 230 V (50/60Hz)
42 cm x 42.17 cm x 33.41 cm
18.7 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty (Austria, Germany - 3 years with product registration)
Fax Type
Plain paper
Printing Technology
Laser - colour
40000 pages
150 - 2500 pages
Display Diagonal Size
2.7"
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Fit to page, ID Card Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, PCLm, URF
Image Enhancement Technology
HP ImageREt 3600
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 1300 pages
PC Faxing
Yes (send only)
Fax Machine Features
Speed Dialing
120 station(s)
Broadcast Transmission
119 stations
Delayed Transmission
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), poll receive
Document & Media Handling
Min Original Size
102 x 152 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
250 sheets
1 sheet
100 sheets
Bypass tray - 1 sheet , Input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: 102 x 152 mm - Legal (216 x 356 mm) weight: 60 g/m² - 75 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 21 ppm (A4) - B/W (ISO) , Printing: up to 21 ppm (A4) - colour (ISO) , Printing: up to 12 ppm (A4) - B/W duplex , Printing: up to 12 ppm (A4) - colour duplex , Copying: up to 21 ppm (A4) - B/W normal , Copying: up to 21 ppm (A4) - colour normal , Copying: up to 12 ppm (A4) - B/W duplex , Copying: up to 12 ppm (A4) - colour duplex , Scanning: up to 26 ppm (A4) , Printing: up to 38 ppm (A5) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x modem - RJ-11
Operating System Support
UNIX, Sun Solaris 8, MS Windows XP SP3, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows XP 64-bit Edition, SuSe Linux 10.3, HP-UX 11.0, Ubuntu Linux 9.10, Ubuntu Linux 10.04, MS Windows Server 2008 R2, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Apple Mac OS X 10.7, Debian Linux 5.0, Red Hat Enterprise Linux 5, MS Windows Server 2008 R2 x64 Edition, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 11.10, Ubuntu Linux 12.04, Ubuntu Linux 8.04, Oracle Solaris 9, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, Fedora 17, MS Windows Server 2012 x64 Edition, Android, iOS, Fedora 18, openSUSE 12.2, openSUSE 12.3, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, Apple Mac OS X 10.9, Windows 8.1 64-bit, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, Fedora 19, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Linux 9.4, Linux 9.5, Ubuntu Linux 8.04.1, Ubuntu Linux 8.04.2, Ubuntu Linux 13.04, Linux Mint 15, Windows RT 8, Apple Mac OS X 10.10, Windows 8 Pro, Windows 8 Pro 64-bit, Windows 8 Enterprise, Windows 8 Enterprise 64-bit, Windows 8 Enterprise N, Windows 8 Enterprise N 64-bit, Ubuntu Linux 13.10, SuSe Linux 13.1, Boss 3.0, Boss 5.0, Ubuntu Linux 14.10, Debian Linux 7.x, Fedora 20, Linux Mint 16, Linux Mint 17, Ubuntu Linux 14.04, Debian Linux 6.0.x, Novell NetWare 6.5 SP8, Novell Open Enterprise Server 11 SP1, Novell Open Enterprise Server 2
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
342 Watt
Power Consumption Standby
8 Watt
Power Consumption Sleep
1.2 Watt
First Copy Out Time B/W
11.3 sec
First Copy Out Time Colour
14 sec
Consumables Included
1 x Cartridge (black) - up to 1400 pages , 1 x Cartridge (cyan) - up to 1300 pages , 1 x Cartridge (magenta) - up to 1300 pages , 1 x Cartridge (yellow) - up to 1300 pages
FCC Class B certified, CISPR 22 Class B, CB, RSS-210, FCC CFR47 Part 68, R&TTE, Laser Class 1, FCC CFR47 Part 15, FCC CFR47 Part 15 C, TBR21, EN 60825-1, CECP, EN 61000-3-3:2008, CSA C22.2 No. 60950-1-07 Second Edition, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, ICES-003 issue 5 Class B, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN 62479:2010, EN55024:2010, EN 300 328, 21 CFR 1040.10, 21 CFR 1040.11, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, IEC60950-1:2005+A1:2009, EN55022:2010 Class B, EN 62311:2008, IEC 62479:2010, ETSI ES203 201, IEC 62311:2007
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year
42 cm
42.17 cm
33.41 cm
18.7 kg
Shipping Width
49.8 cm
Shipping Depth
39.8 cm
Shipping Height
53.2 cm
Shipping Weight
21.5 kg
Sound Emission
50 dBA (operating)
15 °C
30 °C
10 - 80% (non-condensing)
Functionality: Copier
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
Price Range Ex VAT: 150 - 300
