HP Colour Laserjet M181fw
Quicklinx: D3ZKWS00 Mfr#: T6B71A#B19
25 in stock
£218.96 ex VAT
£262.75 inc VAT
Standard delivery Delivered within 3-5 working days
  • Increase versatility with a colour MFP
    Get fast print speeds and rapid first page out time (FPOT).Breeze through print, scan, copy, and fax tasks, using the automatic document feeder (fax and ADF available on M181fw only).Help save energy with HP Auto-On/Auto-Off Technology.Get quick and easy printing directly at the control panel.
  • More
    Count on high-quality colour with Original HP Toner cartridges with JetIntelligence.Get the Original HP quality you paid for with anti-fraud technology.Speed through print jobs right out of the box, using preinstalled Original HP Toner cartridges.
  • Easy mobile printing and scanning – HP Smart app
    Print and scan from your smartphone, and easily order toner, with the HP Smart app.Have confidence in your connection with steady performance from dual band Wi-Fi .Connect your smartphone or tablet directly to your printer – and easily print without accessing a network.Simply tap the print button on your smartphone or tablet to print.
HP Color LaserJet Pro MFP M181fw - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
150 - 1500 pages
Max Copying Speed
Up to 16 ppm (mono) / up to 16 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
Scanning
1200 x 1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, heavy-weight paper, light-weight paper, glossy paper
Standard Media Capacity
150 sheets
Max Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to folder, scan to application
AC 230 V (50/60Hz)
42 cm x 38 cm x 34.12 cm
16.3 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty (Austria, Germany - 3 years with product registration)
Fax Type
Plain paper
Printing Technology
Laser - colour
30000 pages
150 - 1500 pages
Display
2 lines
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
ID Card Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, PCLm, URF
Image Enhancement Technology
HP ImageREt 3600
First Print Out Time B/W
11.8 sec
First Print Out Time Colour
13.5 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 1300 pages
PC Faxing
Fax Machine Features
Speed Dialing
120 station(s)
Broadcast Transmission
119 stations
Delayed Transmission
Remote Fax Retrieval (Polling)
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax polling
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 76 x 127 mm, 127 x 203.2 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
150 sheets
Max Media Capacity
150 sheets
100 sheets
ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 16 ppm (Letter A) - B/W (ISO) , Printing: up to 16 ppm (Letter A) - colour (ISO) , Printing: up to 16 ppm (A4) - B/W (ISO) , Printing: up to 16 ppm (A4) - colour (ISO) , Copying: up to 16 ppm (Letter A) - B/W normal , Copying: up to 16 ppm (Letter A) - colour normal , Copying: up to 16 ppm (A4) - B/W normal , Copying: up to 16 ppm (A4) - colour normal , Scanning: up to 14 ppm (A4)
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA, WPA2, TKIP, AES, WPS, Wi-Fi Direct
Operating System Support
Linux, MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), MS Windows Server 2008, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 SP1 or later, MS Windows XP 64-bit Edition SP2 or later, MS Windows Server 2012, Windows 8, Windows 8 64-bit, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2003 x64 Edition SP1 or later, MS Windows Server 2008 Enterprise, MS Windows Server 2008 Standard
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
337 Watt
Power Consumption Standby
8 Watt
Power Consumption Sleep
1 Watt
First Copy Out Time B/W
12.3 sec
First Copy Out Time Colour
18.1 sec
Consumables Included
1 x Cartridge (black) - up to 1100 pages , 1 x Cartridge (cyan) - up to 900 pages , 1 x Cartridge (magenta) - up to 900 pages , 1 x Cartridge (yellow) - up to 900 pages
FCC Class B certified, UL, cUL, GS, ICES-003, CISPR 22, EN55022 Class B, EN 301.489.1, EN 301.489.17, RSS-210, FCC Part 68, EMC, CS-03, R&TTE, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60825-1, GB 17625.1, LVD, Directive 2004/108/EC, GB 9254-2008, EN 62311, Directive 2006/95/EC, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 300 328 V1.7.1, NOM-151-SCTI-1999, IEC 60825-1:2007, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN55024:2010
ENERGY STAR Certified
Limited warranty - 1 year
42 cm
38 cm
34.12 cm
16.3 kg
Shipping Width
49.7 cm
Shipping Depth
39.8 cm
Shipping Height
46.6 cm
Shipping Weight
19.5 kg
Sound Emission
50 dBA (operating)
15 °C
30 °C
10 - 80%
Functionality: Copier
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
Price Range Ex VAT: 150 - 300
