Give your business the printing performance it needs with Ethernet and wireless networking options, easy printing from mobile devices, and essential management features.
Increase versatility with a colour MFP
Get fast print speeds and rapid first page out time (FPOT).Help save energy with HP Auto-On/Auto-Off Technology.Get quick and easy printing directly at the control panel.Change paper less often with a 150-sheet capacity paper tray. -
More
Count on high-quality colour and more pages with Original HP Toner cartridges with JetIntelligence.Get the Original HP quality you paid for with anti-fraud technology.Speed through print jobs right out of the box, using preinstalled Original HP Toner cartridges. -
Easy mobile printing and scanning – HP Smart app
Print and scan from your smartphone, and easily order toner, with the HP Smart app.Simply tap the print button on your smartphone or tablet to print.Easily print from a variety of smartphones and tablets.Easily share resources – access and print with Ethernet networking.
- HP Color LaserJet Pro MFP M180n - multifunction printer - colour
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 150 - 1500 pages
- Max Copying Speed
- Up to 16 ppm (mono) / up to 16 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Scanning
- 1200 x 1200 dpi
- Original Size
- 215.9 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, heavy-weight paper, light-weight paper, glossy paper
- Standard Media Capacity
- 150 sheets
- Max Media Capacity
- 150 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to folder, scan to application, Instant-on Technology, HP Auto-On/Auto-Off Technology
- Power
- AC 230 V (50/60Hz)
- 42 cm x 38 cm x 29.26 cm
- 15.7 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty (Austria, Germany - 3 years with product registration)
- Laser - colour
- 30000 pages
- 150 - 1500 pages
- Display Features
- 7 segment LCD display with icons
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF, PCLm, URF
- Image Enhancement Technology
- HP ImageREt 3600
- First Print Out Time B/W
- 11.8 sec
- First Print Out Time Colour
- 13.7 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 215.9 x 297 mm
- Original Type
- Sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 76 x 127 mm, 127 x 203.2 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 150 sheets
- 100 sheets
- Input tray - 150 sheets - Legal (216 x 356 mm) , Output tray - 100 sheets
- Speed Details
- Printing: up to 16 ppm - B/W (ISO) , Printing: up to 16 ppm - colour (ISO) , Printing: up to 27 ppm (A5) - B/W , Printing: up to 21 ppm (A5) - colour , Printing: up to 17 ppm (Letter A) - B/W , Printing: up to 17 ppm (Letter A) - colour , Copying: up to 16 ppm (A4) - B/W , Copying: up to 16 ppm (A4) - colour , Copying: up to 17 ppm (Letter A) - B/W , Copying: up to 17 ppm (Letter A) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Operating System Support
- Linux, MS Windows Server 2008, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
- Voltage Required
- 337 Watt
- Power Consumption Standby
- 8 Watt
- Power Consumption Sleep
- 1 Watt
- First Copy Out Time B/W
- 14.3 sec
- First Copy Out Time Colour
- 26.8 sec
- ICES-003, CISPR 22, Laser Class 1, IEC 60950-1, FCC CFR47 Part 15 B, EN 60825-1, GB 9254-2008, Directive 2006/95/EC, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, EN55022:2010, EN 55024:2010
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- Regional Warranty Exceptions
- Austria, Germany - 3 years with product registration
- 42 cm
- 38 cm
- 29.26 cm
- 15.7 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 37.9 cm
- Shipping Height
- 46.6 cm
- Shipping Weight
- 18.4 kg
- Sound Emission
- 49 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80%
Ink (2)
HP 205A Original Black Laserjet Tone | In Stock | £41.38 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £14.41 |
Other bundles (4)
HP Care Pack Standard Exchange Extended Service Agreement 3 Years Shipment | In Stock | £43.74 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment | In Stock | £54.67 |
HP Care Pack Standard Exchange Extended Service Agreement 2 Years Shipment | In Stock | £21.87 |
HP 2y Nbd Exch Cons Laserjet MFP-E SVC -HP Consumer Laserjet MF | In Stock | £27.33 |
