HP Colour LaserJet Flow MFP M680zm Printer
Quicklinx: C78DWS00 Mfr#: L3U48A#B19
HP Managed MFPs and printers are optimized for managed environments. Offering increased monthly page volumes and fewer interventions, this portfolio of products can help reduce printing and copying costs.
  • Boost your workflow
    Get more done, faster: scan two-sided documents in a single pass. No missed pages, no flipping pages by hand. Preview and edit scans, adjust images, and launch standard processes, all at the 20 cm color touchscreen. Fast, accurate input: enter data more quickly and accurately, using the pull-out keyboard. Print without wires or a network. Get easy access to the MFP through optional wireless direct printing. Mobile printing at a touch: enable touch-to-print convenience from mobile devices. Easily print from smartphones, tablets and notebooks at work, home or on the go.
  • Mopria-certified
    Pull print jobs from your pocket - walk up and print or scan from your USB drive.
  • Ready, set, grow
    Secure your investment - depend on an MFP that can expand with your business, whenever solutions advance. Keep a close watch, even from afar - centrally monitor and control your MFPs with HP.
HP Color LaserJet Managed Flow MFP M680zm - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
180000 pages
Recommended Monthly Volume
3000 - 30000 pages
Max Copying Speed
Up to 42 ppm (mono) / up to 42 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 43 ppm (mono) / up to 42 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Scanning
600 dpi
Display
8"
Original Size
68 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
101.6 x 152.4 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, film, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, glossy paper, punched paper, preprinted paper
Standard Media Capacity
3100 sheets
Max Media Capacity
3100 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
1400 sheets
Stapler
Included
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, Hardware Integration Pocket, Hard Disk Drive Encryption, save to network folder, Foreign Interface Harness (FIH), HP EveryPage, HP High-Performance Secure Hard Disk, pull-out keyboard, scan to Cloud, Mobile Printing
AC 230 V (50Hz)
87 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Printing Technology
Laser - colour
180000 pages
3000 - 30000 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
2 GB
Max Supported Memory
3 GB
Hard Disk Drive
320 GB
Copying
Max Copying Speed
Maximum Copies
9999
Automatic Duplexing
Copying Features
Collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF
Automatic Duplexing
First Print Out Time B/W
10.5 sec
First Print Out Time Colour
10.5 sec
Scanning
Scan Element
CCD
Automatic Duplexing
Optical Resolution
600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Min Original Size
68 x 148 mm
Max Original Size
Original Type
Sheets
100 sheets
Min Media Size
101.6 x 152.4 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, JIS B6 (128 x 182 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
3100 sheets
Max Media Capacity
3100 sheets
100 sheets
1400 sheets
ADF - 100 sheets size: 68 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 101.6 x 152.4 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 3 x input tray - 500 sheets size: A5 (148 x 210 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Input tray - 1500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , 3-bin mailbox - 900 sheets , Output tray - 500 sheets
Speed Details
Printing: up to 42 ppm (A4) - B/W , Printing: up to 42 ppm (A4) - colour , Printing: up to 38 ipm (A4) - B/W duplex , Printing: up to 38 ipm (A4) - colour duplex , Copying: up to 42 ppm (A4) - B/W , Copying: up to 42 ppm (A4) - colour
Finishing Equipment
Stapler
Included
1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x modem - RJ-11
Security Protocols & Features
Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
Operating System Support
Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, MS Windows XP 64-bit Edition SP3 or later, MS Windows Server 2003 SP2 or later, MS Windows Server 2003 x64 Edition SP2 or later, Apple Mac OS X 10.9, MS Windows Server 2008 (32/64-bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits)
Software Included
Drivers & Utilities
AC 230 V (50Hz)
797 Watt
Power Consumption Standby
83 Watt
Power Consumption Sleep
7 Watt
Phone cable
Consumables Included
1 x Cartridge (black) - up to 11500 pages , 1 x Cartridge (cyan) - up to 16500 pages , 1 x Cartridge (magenta) - up to 16500 pages , 1 x Cartridge (yellow) - up to 16500 pages
ICES-003, FCC CFR47, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EMC 2004/108/EC, EN55022:2010 Class A, CISPR 22:2008, EN55024:2010
ENERGY STAR Certified
Blue Angel Compliant
87 kg
Shipping Weight
116.8 kg
Sound Emission
54 dBA (operating)
15 °C
30 °C
30 - 70%
