HP Managed MFPs and printers are optimized for managed environments. Offering increased monthly page volumes and fewer interventions, this portfolio of products can help reduce printing and copying costs.
Boost your workflow
Get more done, faster: scan two-sided documents in a single pass. No missed pages, no flipping pages by hand. Preview and edit scans, adjust images, and launch standard processes, all at the 20 cm color touchscreen. Fast, accurate input: enter data more quickly and accurately, using the pull-out keyboard. Print without wires or a network. Get easy access to the MFP through optional wireless direct printing. Mobile printing at a touch: enable touch-to-print convenience from mobile devices. Easily print from smartphones, tablets and notebooks at work, home or on the go. -
Mopria-certified
Pull print jobs from your pocket - walk up and print or scan from your USB drive. -
Ready, set, grow
Secure your investment - depend on an MFP that can expand with your business, whenever solutions advance. Keep a close watch, even from afar - centrally monitor and control your MFPs with HP.
- HP Color LaserJet Managed Flow MFP M680zm - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 180000 pages
- Recommended Monthly Volume
- 3000 - 30000 pages
- Max Copying Speed
- Up to 42 ppm (mono) / up to 42 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 43 ppm (mono) / up to 42 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 dpi
- Display
- 8"
- Original Size
- 68 x 148 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 101.6 x 152.4 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, film, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, glossy paper, punched paper, preprinted paper
- Standard Media Capacity
- 3100 sheets
- Max Media Capacity
- 3100 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 1400 sheets
- Stapler
- Included
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, Hardware Integration Pocket, Hard Disk Drive Encryption, save to network folder, Foreign Interface Harness (FIH), HP EveryPage, HP High-Performance Secure Hard Disk, pull-out keyboard, scan to Cloud, Mobile Printing
- Power
- AC 230 V (50Hz)
- 87 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Fax Type
- Plain paper
- Laser - colour
- 180000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 2 GB
- Max Supported Memory
- 3 GB
- Hard Disk Drive
- 320 GB
Copying
- Max Copying Speed
- Maximum Copies
- 9999
- Copying Features
- Collation copy
Printing
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF
- First Print Out Time B/W
- 10.5 sec
- First Print Out Time Colour
- 10.5 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Min Original Size
- 68 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 101.6 x 152.4 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, JIS B6 (128 x 182 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 3100 sheets
- 3100 sheets
- 100 sheets
- 1400 sheets
- ADF - 100 sheets size: 68 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 101.6 x 152.4 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 3 x input tray - 500 sheets size: A5 (148 x 210 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Input tray - 1500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , 3-bin mailbox - 900 sheets , Output tray - 500 sheets
- Speed Details
- Printing: up to 42 ppm (A4) - B/W , Printing: up to 42 ppm (A4) - colour , Printing: up to 38 ipm (A4) - B/W duplex , Printing: up to 38 ipm (A4) - colour duplex , Copying: up to 42 ppm (A4) - B/W , Copying: up to 42 ppm (A4) - colour
Finishing Equipment
- Stapler
- Included
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x modem - RJ-11
- Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Operating System Support
- Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, MS Windows XP 64-bit Edition SP3 or later, MS Windows Server 2003 SP2 or later, MS Windows Server 2003 x64 Edition SP2 or later, Apple Mac OS X 10.9, MS Windows Server 2008 (32/64-bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits)
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V (50Hz)
- 797 Watt
- Power Consumption Standby
- 83 Watt
- Power Consumption Sleep
- 7 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x Cartridge (black) - up to 11500 pages , 1 x Cartridge (cyan) - up to 16500 pages , 1 x Cartridge (magenta) - up to 16500 pages , 1 x Cartridge (yellow) - up to 16500 pages
- ICES-003, FCC CFR47, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EMC 2004/108/EC, EN55022:2010 Class A, CISPR 22:2008, EN55024:2010
- ENERGY STAR Certified
- Blue Angel Compliant
- 87 kg
- Shipping Weight
- 116.8 kg
- Sound Emission
- 54 dBA (operating)
- 15 °C
- 30 °C
- 30 - 70%
