HP Managed MFPs and printers are optimized for managed environments. Offering increased monthly page volumes and fewer interventions, this portfolio of products can help reduce printing and copying costs.
- HP Color LaserJet Managed Flow MFP M680zm - multifunction printer (colour)
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 180000 pages
- Recommended Monthly Volume
- 3000 - 30000 pages
- Max Copying Speed
- Up to 42 ppm (mono) / up to 42 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 dpi
- Display
- 8"
- Original Size
- 68 x 148 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 101.6 x 152.4 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, film, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, glossy paper, punched paper, preprinted paper
- Standard Media Capacity
- 3100 sheets
- Max Media Capacity
- 3100 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 1400 sheets
- Stapler
- Included
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, Hardware Integration Pocket, Hard Disk Drive Encryption, save to network folder, Foreign Interface Harness (FIH), HP EveryPage, HP High-Performance Secure Hard Disk, pull-out keyboard, scan to Cloud, Mobile Printing
- Power
- AC 230 V (50Hz)
- 87 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Fax Type
- Plain paper
- Laser - colour
- 180000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 2 GB
- Max Supported Memory
- 3 GB
- Hard Disk Drive
- 320 GB
Copying
- Max Copying Speed
- Maximum Copies
- 9999
- Copying Features
- Collation copy
Printing
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF
- First Print Out Time B/W
- 10.5 sec
- First Print Out Time Colour
- 10.5 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Min Original Size
- 68 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 101.6 x 152.4 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, JIS B6 (128 x 182 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 3100 sheets
- 3100 sheets
- 100 sheets
- 1400 sheets
- ADF - 100 sheets size: 68 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 101.6 x 152.4 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 3 x input tray - 500 sheets size: A5 (148 x 210 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Input tray - 1500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , 3-bin mailbox - 900 sheets , Output tray - 500 sheets
- Speed Details
- Printing: up to 42 ppm (A4) - B/W , Printing: up to 42 ppm (A4) - colour , Printing: up to 38 ipm (A4) - B/W duplex , Printing: up to 38 ipm (A4) - colour duplex , Copying: up to 42 ppm (A4) - B/W , Copying: up to 42 ppm (A4) - colour
Finishing Equipment
- Stapler
- Included
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x modem - RJ-11
- Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Operating System Support
- Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, MS Windows XP 64-bit Edition SP3 or later, MS Windows Server 2003 SP2 or later, MS Windows Server 2003 x64 Edition SP2 or later, Apple Mac OS X 10.9, MS Windows Server 2008 (32/64-bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits)
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V (50Hz)
- 797 Watt
- Power Consumption Standby
- 83 Watt
- Power Consumption Sleep
- 7 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x Cartridge (black) - up to 11500 pages , 1 x Cartridge (cyan) - up to 16500 pages , 1 x Cartridge (magenta) - up to 16500 pages , 1 x Cartridge (yellow) - up to 16500 pages
- ICES-003, FCC CFR47, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN55024:2010, EMC 2004/108/EC, EN55022:2010 Class A, CISPR 22:2008
- ENERGY STAR Certified
- Blue Angel Compliant
- 87 kg
- Shipping Weight
- 116.8 kg
- Sound Emission
- 54 dBA (operating)
- 15 °C
- 30 °C
- 30 - 70%
