Tackle high-volume jobs with this high-performance colour MFP. Print and copy, plus scan and fax. Enhanced scanning features and a 20cm (8-inch) colour touchscreen smooth workflows. Mobile printing options help you stay productive on the go.
Boost your workflow
Get more done much faster: scan two-sided documents in a single pass ÔÇô no missed pages, no flipping pages by hand.Preview and edit scans, adjust images, and launch standard processes, all at the 20 cm (8-inch) colour touchscreen.Fast, accurate input: enter data more quickly and accurately, using the pull-out keyboard.Scan and send digital files directly to email, SharePoint , network folders or the cloud. -
Mobilise business printing
Print without wires or a network. Get easy access to the MFP through optional wireless direct printing.Mobile printing at a touch: enable touch-to-print convenience from mobile devices.Easily print from smartphones, tablets, and notebooks at work, home, or on the go with Apple AirPrint and HP ePrint; Mopria-certified.Pull print jobs from your pocket ÔÇô walk up and print or scan from your USB drive. -
Easily upgrade and add new capabilities as your needs change
Secure your investment ÔÇô depend on an MFP that can expand with your business, whenever solutions advance.Keep a close watch, even from afar ÔÇô centrally monitor and control your MFPs with HP Web Jetadmin.Be confident that sensitive business data is protected with advanced security and an encrypted hard disk. -
Power up your productivity
Tackle high volume printing: load the MFP with up to 3,100 sheets and high-capacity Original HP cartridges, and let it go to work.Reduce employee time at the MFP, using the automatic document feeder.Confidently capture data. HP EveryPage lets you scan without worry and detect potential errors on the spot.Save time with automatic job sorting and finishing, using the 3-bin stapling mailbox.
- HP LaserJet Enterprise MFP M680f - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 120000 pages
- Recommended Monthly Volume
- 3000 - 17000 pages
- Max Copying Speed
- Up to 42 ppm (mono) / up to 42 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 43 ppm (mono) / up to 42 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 200 dpi, 100 x 100 dpi
- Scanning
- 600 dpi
- Display
- 8"
- Original Size
- 68 x 148 mm (min) - Legal (216 x 356 mm) (max)
- Document Feeder Capacity
- 100 sheets
- Media Size
- 101.6 x 152.4 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Standard Media Capacity
- 1100 sheets
- Max Media Capacity
- 3100 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Document send function
- Power
- AC 230 V (50Hz)
- 84 cm x 68.1 cm x 113.5 cm
- 77.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Laser - colour
- 120000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Max Supported Memory
- 2 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
Printing
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PDF
- Image Enhancement Technology
- HP ImageREt 4800, HP ProRes 1200
- First Print Out Time B/W
- 18.5 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- PC Faxing
- Yes (send only)
Fax Machine Features
- Broadcast Transmission
- 100 stations
Document & Media Handling
- Min Original Size
- 68 x 148 mm
- Max Original Size
- 100 sheets
- Min Media Size
- 101.6 x 152.4 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), JIS B6 (128 x 182 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm), 101.6 x 152.4 mm
- 1100 sheets
- 3100 sheets
- 100 sheets
- 500 sheets
- ADF - 100 sheets size: 68 x 148 mm - Legal (216 x 356 mm) , 2 x input tray - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Bypass tray - 100 sheets , Output tray - 500 sheets
- Speed Details
- Printing: up to 43 ppm (A4) - B/W normal , Printing: up to 42 ppm (A4) - colour normal , Printing: up to 45 ppm (Letter A) - B/W normal , Copying: up to 42 ppm (A4) - colour normal , Copying: up to 38 ipm (A4) - colour duplex , Copying: up to 40 ipm (Letter A) - B/W duplex , Copying: up to 40 ppm (Letter A) - colour duplex , Copying: up to 45 ppm (Letter A) - B/W normal , Scanning: up to 60 ppm (Letter A) - B/W normal , Scanning: up to 45 ppm (Letter A) - colour normal
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A
- IPsec
- Operating System Support
- MS Windows 7, MS Windows XP SP3, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, MS Windows Server 2008 R2, Apple Mac OS X 10.7, HP-UX 10.20, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, Apple Mac OS X 10.9
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V (50Hz)
- 797 Watt
- Power Consumption Standby
- 83 Watt
- Power Consumption Sleep
- 7 Watt
- First Copy Out Time B/W
- 10.5 sec
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site
- 84 cm
- 68.1 cm
- 113.5 cm
- 77.9 kg
- Shipping Width
- 85.6 cm
- Shipping Depth
- 76 cm
- Shipping Height
- 137.3 cm
- Shipping Weight
- 96.6 kg
- Sound Emission
- 36 dBA (idle) / 56 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80%
HP 653X High Yield Black Original Toner Cartridge | In Stock | £202.28 |
HP 653A Cyan Original Toner Cartridge | In Stock | £272.40 |
HP 653A Yellow Original Toner Cartridge | In Stock | £272.40 |
HP 653A Magenta Original Toner Cartridge | In Stock | £312.53 |
