HP Colour LaserJet Enterprise M680f Multifunction Printer
Quicklinx: 9HFHWS00 Mfr#: CZ249A#B19
Functionality: Printer, Copier, Scanner, Fax
Output Type: Colour
Wireless Capability: Wireless, Wired
Technology: Laser
£2,549.68 ex VAT
£3,059.61 inc VAT
Tackle high-volume jobs with this high-performance colour MFP. Print and copy, plus scan and fax. Enhanced scanning features and a 20cm (8-inch) colour touchscreen smooth workflows. Mobile printing options help you stay productive on the go.
  • 20.3 cm colour touchscreen (printer)
    Manage jobs directly at the MFP, using the HP colour touchscreen.
HP LaserJet Enterprise MFP M680f - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
120000 pages
Recommended Monthly Volume
3000 - 17000 pages
Max Copying Speed
Up to 42 ppm (mono) / up to 42 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 43 ppm (mono) / up to 42 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi, 100 x 100 dpi
Scanning
600 dpi
Display
8"
Original Size
68 x 148 mm (min) - Legal (216 x 356 mm) (max)
Document Feeder Capacity
100 sheets
Media Size
101.6 x 152.4 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Standard Media Capacity
1100 sheets
Max Media Capacity
3100 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Document send function
AC 230 V (50Hz)
84 cm x 68.1 cm x 113.5 cm
77.9 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
120000 pages
3000 - 17000 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Max Supported Memory
2 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 5e, PCL 6, PDF
Image Enhancement Technology
HP ImageREt 4800, HP ProRes 1200
Automatic Duplexing
First Print Out Time B/W
18.5 sec
Scanning
Scan Element
CCD
Optical Resolution
600 dpi
Grayscale Depth
8-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
PC Faxing
Yes (send only)
Fax Machine Features
Broadcast Transmission
100 stations
Document & Media Handling
Min Original Size
68 x 148 mm
Max Original Size
100 sheets
Min Media Size
101.6 x 152.4 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), JIS B6 (128 x 182 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm), 101.6 x 152.4 mm
1100 sheets
Max Media Capacity
3100 sheets
100 sheets
500 sheets
ADF - 100 sheets size: 68 x 148 mm - Legal (216 x 356 mm) , 2 x input tray - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Bypass tray - 100 sheets , Output tray - 500 sheets
Speed Details
Scanning: up to 60 ppm (Letter A) - B/W normal , Scanning: up to 45 ppm (Letter A) - colour normal , Printing: up to 43 ppm (A4) - B/W (ISO) , Printing: up to 42 ppm (A4) - colour (ISO) , Printing: up to 45 ppm (Letter A) - B/W (ISO) , Printing: up to 38 ipm (A4) - duplex normal , Printing: up to 40 ipm (Letter A) - duplex normal , Copying: up to 40 ipm (Letter A) - B/W duplex , Copying: up to 40 ppm (Letter A) - colour duplex , Copying: up to 45 ppm (Letter A) - B/W (ISO) , Copying: up to 42 ppm (A4) - B/W (ISO) , Copying: up to 42 ppm (A4) - colour (ISO) , Copying: up to 38 ppm (A4) - colour duplex , Copying: up to 38 ipm (A4) - B/W duplex , Printing: up to 45 ppm (Letter A) - colour (ISO) , Copying: up to 45 ppm (Letter A) - colour (ISO)
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A
Security Protocols & Features
IPsec
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, MS Windows Server 2008 R2, Apple Mac OS X 10.7, HP-UX 10.20, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, Apple Mac OS X 10.9
Software Included
Drivers & Utilities
AC 230 V (50Hz)
797 Watt
Power Consumption Standby
83 Watt
Power Consumption Sleep
7 Watt
First Copy Out Time B/W
10.5 sec
ENERGY STAR Certified
Limited warranty - 1 year - on-site
84 cm
68.1 cm
113.5 cm
77.9 kg
Shipping Width
85.6 cm
Shipping Depth
76 cm
Shipping Height
137.3 cm
Shipping Weight
96.6 kg
Sound Emission
36 dBA (idle) / 56 dBA (operating)
15 °C
30 °C
10 - 80%
Ink (6)
9HFH HP 648A Toner Collection Unit In Stock £19.49
9HFH HP Colour LaserJet Transfer Kit In Stock £236.40
9HFH HP 652A Black Original LaserJet Toner Cartridge In Stock £159.49
9HFH HP 653A Cyan Original Toner Cartridge In Stock £258.41
9HFH HP 653A Yellow Original Toner Cartridge In Stock £258.41
9HFH HP 653A Magenta Original Toner Cartridge In Stock £258.41
Other bundles (2)
9HFH HP Colour LaserJet CE247A 220V Fuser Kit In Stock £157.20
9HFH HP Scanjet ADF Roller Replacement Kit In Stock £46.40
Functionality: Copier
Functionality: Scanner
Functionality: Fax
Output Type: Colour
Wireless Capability: Wired
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
Price Range Ex VAT: £1500+
