Performance you can count on: high-volume, professional-quality, two-sided colour documents with outstanding reliability. Efficient one-touch printing and mobile printing options plus simple management help you be productive wherever work takes you.
2-sided printing
Allows you to print on both sides of the page, cutting your paper use by up to 50%. -
Only the power you need
Help save energy with HP Auto-On/Auto-Off Technology. -
Prints in a flash, savings that last
Print right away with Instant-on Technology. -
On-the-go printing with HP ePrint
Print photos, documents, and more when you're on the go, using HP ePrint. -
Ethernet (printer)
Add this device to your office Ethernet network to share with your workgroup.
- HP Color LaserJet Enterprise M651xh - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 69.6 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 42 ppm - black normal - A4 (210 x 297 mm) , Up to 42 ppm - colour normal - A4 (210 x 297 mm) , Up to 45 ppm - black normal - ANSI A (Letter) (216 x 279 mm) , Up to 45 ppm - colour normal - ANSI A (Letter) (216 x 279 mm) , Up to 38 ppm - duplex - A4 (210 x 297 mm) , Up to 40 ppm - duplex - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Image Enhancement Technology
- HP ImageREt 4800 / HP ProRes 1200
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- Processor
- 800 MHz
- RAM Installed (Max)
- 1.5 GB (1.5 GB)
- Language Simulation
- PCL 5, PostScript 3, PCL 6, PDF, URF
- Media Type
- Envelopes, transparencies, labels, plain paper, heavy-weight paper, heavy-weight glossy paper, bond paper, recycled paper, opaque film, card stock, extra heavy-weight paper, light-weight paper
- Total Media Capacity
- 3100 sheets
- Media Handling
- 2x 500-sheet input trays, 100-sheet multipurpose tray, 1500-sheet high-capacity feeder
- Monthly Duty Cycle (max)
- 120000 pages
- Recommended Monthly Volume
- 2500 - 17000 pages
- Networking
- Print server
- Printer Features
- Hard Disk Drive Encryption, on paper calibration technology
- System Requirements
- HP-UX 10.20, SunSoft Solaris 2.5 or later, IBM AIX 3.2.5 or later, Microsoft Windows 2000, HP-UX 11.x, HP MPE/iX, HP-UX 11i, Novell NetWare 5.1 or later, Microsoft Windows Server 2003 x64 Edition SP2 or later, Apple MacOS X 10.6, Microsoft Windows XP SP3 or later, Microsoft Windows Server 2003 SP2 or later, Citrix MetaFrame, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows XP Professional x64 Edition SP3 or later, Apple MacOS X Lion 10.7, Microsoft Windows 7 (32/64 bits) SP1 or later, Red Hat Linux 7.x or later, SuSE Linux 8.x or later, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Apple OS X 10.9 Mavericks
- 66 cm x 66.5 cm x 100 cm
- Printer Type
- Localisation
Printer
- Print Speed
- Built-in Devices
- HP Secure High Performance hard disk, 4.3 inch LCD touch screen
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 9 sec
- Fonts Included
- 105 x TrueType , 92 x scalable PostScript
- Printer Features
- Media Handling
- Processor
- 800 MHz
RAM
- 1.5 GB / 1.5 GB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 3100 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 3 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 1500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Max Media Capacity
- 3100 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 120000 pages
- Networking
- Print server
- Network Controller Name
- HP Jetdirect
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, NDPS, NDS, HTTPS, TFTP, IPPS
- Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
- FCC Class A certified, UL, CISPR 22 Class A, cUL, GS, ICES-003, EN55022 Class A, EMC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60825-1, LVD, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 62479, IEC 60825-1:2007, EN 62479:2010, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
- Security Slot Type
- Kensington security slot
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 650 Watt
- Power Consumption Stand by
- 67 Watt
- Power Consumption Sleep
- 8.5 Watt
- Software Included
- Drivers & Utilities, HP Web JetAdmin
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- 10 °C
- 30 °C
- 10 - 80%
- Sound Emission (Idle)
- 34 dBA
- Sound Emission (Operating)
- 55 dBA
- 66 cm
- 66.5 cm
- 100 cm
- 69.6 kg
- Width (Shipping)
- 76 cm
- Depth (Shipping)
- 86 cm
- Height (Shipping)
- 137.3 cm
- Weight (Shipping)
- 86 kg
HP 652A Black Original LaserJet Toner Cartridge | In Stock | £181.68 |
HP 654A Cyan Original LaserJet Toner Cartridge | In Stock | £332.98 |
HP 654A Magenta Original LaserJet Toner Cartridge | In Stock | £332.98 |
HP 654A Yellow Original LaserJet Toner Cartridge | In Stock | £332.98 |
HP 654X High Yield Black Original LaserJet Toner Cartridge | In Stock | £238.76 |
