HP Colour LaserJet Enterprise Flow M880z Multifunction Printer
Quicklinx: 9HF9WS00 Mfr#: A2W75A#B19
Functionality: Copier, Fax, Printer, Scanner
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Laser
£5,495.79 ex VAT
£6,594.94 inc VAT
This top-of-the-line enterprise MFP helps streamline workflows and accelerate document tasks with advanced finishing options and file sharing. Give users simple, direct access to this MFP through mobile printing and touch-to-print capabilities.
  • Give workgroups the speed they need
    Let departments scan without worry: HP EveryPage detects potential errors or missed pages on the spot.Manage content in a way you never thought possible with HP Flow CM Enterprise.Forget email – let employees scan and send documents to Microsoft SharePoint in one step.Make it easy to be efficient with an intuitive touchscreen and large pull-out keyboard.
  • Keep your business moving
    Save on both sides – capture documents faster with two-sided, single-pass scanning.Create easily searchable scanned files, using built-in optical character recognition software.Save IT time and make printing easy for the entire company by using a single driver for all HP devices.Let employees complete big jobs faster, choosing from a range of finishing options.
  • Be much more efficient with mobile printing
    Give users simple, direct access through wireless direct printing and touch-to-print technology.Mobile printing at a touch – enable touch-to-print convenience from mobile devices.Let employees print from mobile devices with built-in print capability or HP ePrint app and software.Give users the power to print wirelessly from an iPad , iPhone , or iPod touch .
  • Invest once, expand easily and manage efficiently
    Expand your options: easily upgrade firmware on your schedule, and easily integrate solutions or devices at will.Help build business efficiency. Centrally monitor and control printers with HP Web Jetadmin.Apply fleet-wide policies to help protect all your HP devices with the HP Imaging and Printing Center.Confidently safeguard the sensitive data sent to your MFP with the HP High-Performance Secure Hard Disk.
HP LaserJet Enterprise Flow MFP M880z - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
200000 pages
Recommended Monthly Volume
5000 - 25000 pages
Max Printing Speed
Up to 46 ppm (mono) / up to 46 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 100 dpi
Scanning
600 dpi
Display
8"
Original Size
A3 (297 x 420 mm), Ledger (279 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
200 sheets
Media Size
76 x 127 mm (min) - 320 x 470 mm (max)
Media Type
Transparencies, plain paper, labels, recycled paper, bond paper, card stock
Standard Media Capacity
2100 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host, USB host (internal)
Office Machine Features
Save to USB flash drive, scan to e-mail, save to network folder, HP EveryPage, HP High-Performance Secure Hard Disk, pull-out keyboard, scan to Cloud, HP EasyColor, Instant-on Technology
AC 230 V (50Hz)
70.4 cm x 63.5 cm x 119.9 cm
150.6 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel, EPEAT Silver
Fax Type
Plain paper
Printing Technology
Laser - colour
200000 pages
5000 - 25000 pages
Display Diagonal Size
8"
Display Features
Touch screen
Standard Memory
1.5 GB
Hard Disk Drive
320 GB
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Automatic Duplexing
Copying Features
Edge Erase
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF 1.4
Image Enhancement Technology
HP FastRes 1200, HP ImageREt 4800, HP ProRes 1200
Automatic Duplexing
First Print Out Time B/W
11 sec
Scanning
Automatic Duplexing
Optical Resolution
600 dpi
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Fax Machine Features
Speed Dialing
100 station(s)
Broadcast Transmission
100 stations
Fax forwarding, automatic redialing, auto reduction, fax polling
Document & Media Handling
Max Original Size
Original Type
Sheets
200 sheets
Min Media Size
76 x 127 mm
Max Media Size
A3/Ledger
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ARCH B (304.8 x 457.2 mm), JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), SRA4 (225 x 320 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 197 x 273 mm, 76.2 x 127 mm, RA3 (305 x 430 mm), 127 x 177.8 mm, 279.4 x 431.8 mm, 215.9 x 330.2 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm), 270 x 390 mm, 260 x 368 mm, 273 x 394 mm, 195 x 270 mm, 184 x 260 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
2100 sheets
100 sheets
500 sheets
ADF - 200 sheets - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 199 g/m² , Input tray - 100 sheets size: 76 x 127 mm - 320 x 470 mm weight: 60 g/m² - 220 g/m² , 4 x input tray - 500 sheets size: 148 x 210 mm - 297 x 431.8 mm weight: 60 g/m² - 199 g/m² , Output tray - 500 sheets
Speed Details
Printing: up to 46 ppm (A4) - B/W normal , Printing: up to 46 ppm (A4) - colour , Printing: up to 22 ppm (A3) - B/W , Printing: up to 22 ppm (A3) - colour , Scanning: up to 70 ppm (A4) - B/W , Scanning: up to 85 ipm (A4) - B/W duplex , Scanning: up to 68 ppm (A4) - colour , Scanning: up to 63 ipm (A4) - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 2 x USB host (internal) , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, AES-256
Operating System Support
MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), MS Windows Server 2008, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, MS Windows XP 64-bit Edition SP3 or later, MS Windows Server 2003 SP2 or later, MS Windows Server 2003 x64 Edition SP2 or later
Software Included
Drivers & Utilities
AC 230 V (50Hz)
1100 Watt
Power Consumption Standby
80 Watt
Power Consumption Sleep
8 Watt
First Copy Out Time B/W
12 sec
Phone cable
Consumables Included
1 x Cartridge (black) - up to 29500 pages , 1 x Cartridge (cyan) - up to 32000 pages , 1 x Cartridge (magenta) - up to 32000 pages , 1 x Cartridge (yellow) - up to 32000 pages
UL, CISPR 22 Class A, cUL, EN 61000-3-2, GS, ICES-003, EN 61000-3-3, EN55024, FCC Part 68 / CS03 Issue 8, EMC, R&TTE, FCC CFR47 Part 15, IEC 60950-1, IEC 60825-1, GB 17625.1-2003 EMC, IEC 62479
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Blue Angel Compliant
70.4 cm
63.5 cm
119.9 cm
150.6 kg
Shipping Weight
173.3 kg
Sound Emission
33 dBA (idle) / 55 dBA (operating)
15 °C
30 °C
10 - 80%
9HF9 HP 827A Yellow Original LaserJet Toner Cartridge In Stock £380.78
9HF9 HP 827A Cyan Original LaserJet Toner Cartridge In Stock £380.78
9HF9 HP 827A Black Original LaserJet Toner Cartridge In Stock £84.38
9HF9 HP 827A Magenta Original LaserJet Toner Cartridge In Stock £380.78
9HF9 HP 828A Yellow LaserJet Image Drum In Stock £202.99
9HF9 HP 828A Black LaserJet Image Drum In Stock £73.37
9HF9 HP 828A Cyan LaserJet Image Drum In Stock £202.99
9HF9 HP 828A Magenta LaserJet Image Drum In Stock £202.99
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Wireless Capability: Wireless
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: 320 x 470 mm
Brand: HP
Price Range Ex VAT: 1500+
