HP COLOUR LASERJET 512MB DDR2 SODIMM. FR
Quicklinx: 88K9WS00 Mfr#: CE467A
Type: DDR2 SDRAM
Capacity: 512MB
Connection: SO-DIMM 200-pin
Speed: 533MHz
Data Integrity: Non-ECC
£497.49 ex VAT
£596.98 inc VAT
HP printer memory improves the printing performance of complex documents and complex files like colour presentations, two-sided output, graphic-intensive PDF files and web pages.
  • Get the most out of your printer and increase the memory of your HP Color LaserJet
    Get the most out of your printer and increase the memory of your HP Color LaserJet.
  • Print more complex files without out-of-memory errors
    Print more complex files without out-of-memory errors.
  • Increase the performance and processing speed of your HP Color LaserJet
    Increase the performance and processing speed of your HP Color LaserJet.
HP - DDR2 - 512 MB - SO-DIMM 200-pin - unbuffered
RAM memory
512 MB
Memory Type
DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
533 MHz (PC2-4200)
Unbuffered
Color LaserJet Enterprise CP4025dn, CP4025n, CP4525dn, CP4525n, CP4525xh
512 MB
Upgrade Type
System specific
DRAM
DDR2 SDRAM
SO-DIMM 200-pin
Speed
533 MHz (PC2-4200)
Non-ECC
Unbuffered
Module Configuration
128 x 32
Compatible Slots
1 x memory - SO-DIMM 200-pin
17.8 cm x 13.3 cm x 2.5 cm / 0.1 kg
HP Color LaserJet Enterprise CP4025dn, CP4025n, CP4525dn, CP4525n, CP4525xh
Type: DDR2 SDRAM
Capacity: 512MB
Speed: 533MHz
Registered/Buffered: Unbuffered
Standard: PC2-4200
Brand: HP
Price Range Ex VAT: 300 - 500
