HP Color LaserJet Professional CP5225 Colour Laser Printer
Quicklinx: 70Q2WS00 Mfr#: CE710A#B19
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired
Technology: Laser
Hurry, only 3 left in stock!
£784.37 ex VAT
£941.24 inc VAT
Cover all your colour business printing needs from postcards to oversize documents, with this versatile and affordable A3 desktop printer. Get superior print quality with HP ColorSphere toner, fast speeds and ease of use, with unrivalled reliability.
  • Handle all your business printing with this affordable, versatile A3 colour printer
    This versatile A3 colour printer enables you to print everyday business documents, wide-format projects and marketing materials affordably, in house. Easily print on different types of paper: plain, premium and glossy, with expandable paper trays.Use the HP Print Cost Estimator-available in the included HP Print View Software-to compare the cost of printing internally versus at a copy shop.
  • Achieve consistently high-quality output with HP ColorSphere toner on a range of business documents
    Create high-quality output thanks to HP ColorSphere toner and HP ImageREt 3600. Achieve consistent results at speeds of up to 20 ppm black and colour A4. Get a first page out in less than 18 seconds from low-power mode with Instant-on Technology.Achieve consistent results at speeds of up to 20 ppm and a first page out in as fast as 14.5 seconds.With Instant-on Technology warm-up time from Low-power mode is up to 50% faster. In fact, your print job may be finished before many printers have started printing.
  • Simple to use, share, and maintain with an intuitive control panel and easily replaced supplies
    Easy to use and maintain with an intuitive control panel, and simple-to-replace supplies. Enjoy versatile High-speed USB 2.0 connectivity and easy workteam sharing.
HP Color LaserJet Professional CP5225 - printer - colour - laser
Printer Type
Personal printer - laser - colour
40.9 kg
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Print Speed
Up to 20 ppm - B/W - A4 (210 x 297 mm) , Up to 20 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
600 dpi
Max Resolution (Colour)
600 dpi
Image Enhancement Technology
HP ImageREt 3600
USB
540 MHz
RAM Installed (Max)
192 MB (448 MB)
Language Simulation
PCL 5, PostScript 3, PCL 6
Media Type
Envelopes, transparencies, labels, plain paper, cards, recycled paper, glossy paper
Total Media Capacity
350 sheets
Monthly Duty Cycle (max)
75000 pages
Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Apple MacOS X 10.3 or later, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008
Microsoft Certification
Works with Windows Vista
1-year warranty
54.5 cm x 59.9 cm x 33.8 cm
Printer Type
Printer
Print Speed
Wired
USB
600 dpi
600 dpi
HP ImageREt 3600
PostScript Support
Standard
Language Simulation
540 MHz
RAM
RAM Installed (Max)
192 MB / 448 MB (max)
Media Handling
Media Type
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Media Sizes
Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), C5 (162 x 229 mm), JIS B5 (182 x 257 mm)
Max Printing Width
297 mm
Max Printing Length
432 mm
Media Weight
60 g/m² - 220 g/m²
350 sheets
Max Media Capacity
850 sheets
Output Trays Capacity
250 sheets
Duty Cycle
75000 pages
1 x USB 2.0 - 4 pin USB Type B
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Power supply - internal
440 Watt
Power Consumption Stand by / Sleep
30 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site - response time: next business day
15 °C
27 °C
10 - 80%
54.5 cm
59.9 cm
33.8 cm
40.9 kg
Width (Shipping)
71.8 cm
Depth (Shipping)
70.2 cm
Height (Shipping)
47.8 cm
Weight (Shipping)
43 kg
Ink (4)
70Q2 HP 307A Black Original LaserJet Toner Cartridge In Stock £112.12
70Q2 HP 307A Cyan Original LaserJet Toner Cartridge In Stock £197.52
70Q2 HP 307A Yellow Original LaserJet Toner Cartridge In Stock £197.51
70Q2 HP 307A Magenta Original LaserJet Toner Cartridge In Stock £197.51
Other bundles (2)
70Q2 HP LASERJET 1X500 TRAY In Stock £229.44
70Q2 HPE Jetdirect ew2500 802.11g Print Server In Stock £228.10
Type: Printer
Output Type: Colour
Technology: Laser
Max Print Speed: 20ppm
Max Paper Size: A3 (297 x 420 mm)
Brand: HP
Price Range Ex VAT: 750 - 1000
