You'd never expect this much performance from such a small package. This loaded MFP and Original HP Toner cartridges with JetIntelligence combine to give you the tools you need to get the job done.
Accomplish more with your time
Create professional-quality colour documents and speed through tasks with super-fast two-sided printing.Choose the MFP that's the smallest in its class and prints from sleep mode faster than comparable devices.Access time-saving apps from the 7.6 cm touchscreen and scan directly to email, network folders and the cloud.Easily print Microsoft Word and PowerPoint documents – now directly from your USB drive. -
Rely on easy mobile printing options
Print to this MFP with just a touch of your NFC-enabled mobile device – no network needed.Count on wireless direct printing in the office – from mobile devices – without accessing the company network.Easily print from a variety of smartphones and tablets – generally no setup or apps required. -
Get more pages, performance and protection
Get more pages than ever before, using Original HP High-Yield Colour Toner cartridges with JetIntelligence.Count on professional quality at high speeds – HP ColorSphere 3 toner works best with your HP printer.Get the authentic HP quality you paid for with anti-fraud technology.Print right away with preinstalled toner cartridges. Replace them with optional high-yield cartridges. -
Meet everyday IT challenges head-on
Safeguard data and easily manage devices with a suite of essential security and management features.Easily access, print and share resources with Ethernet and wireless networking.Increase security, restore control and help avoid additional expenses with HP JetAdvantage Private Print.
- HP Color LaserJet Pro MFP M277dw - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 2500 pages
- Max Copying Speed
- Up to 18 ppm (mono) / up to 18 ppm (colour)
- Max Copying Resolution
- Up to 300 x 420 dpi (mono) / up to 300 x 420 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 203 x 96 dpi, 203 x 192 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 3"
- Original Size
- 101.6 x 152.4 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, greeting cards, photo paper
- Standard Media Capacity
- 150 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to Cloud, Instant-on Technology, touch-to-print
- Power
- AC 230 V (50Hz)
- 42 cm x 41.7 cm x 32.2 cm
- 16.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - colour
- 30000 pages
- 250 - 2500 pages
- Display Diagonal Size
- 3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Fit to page, ID Card Copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF, PCLm
- Image Enhancement Technology
- HP ImageREt 3600
- First Print Out Time B/W
- 11.5 sec
- First Print Out Time Colour
- 13 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 30-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 400 pages
- PC Faxing
- Yes (send only)
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 119 stations
- Delayed Transmission
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), poll receive
Document & Media Handling
- Min Original Size
- 101.6 x 152.4 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 52 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 101.6 x 152.4 mm, B6 (125 x 176 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, 127 x 203.2 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- 150 sheets
- 1 sheet
- 100 sheets
- Bypass tray - 1 sheet , Input tray - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 52 g/m² - 220 g/m² , ADF - 50 sheets size: 101.6 x 152.4 mm - Legal (216 x 356 mm) weight: 60 g/m² - 90 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 18 ppm (A4) - B/W normal , Printing: up to 18 ppm (A4) - colour normal , Printing: up to 19 ppm (Letter A) - B/W normal , Printing: up to 19 ppm (Letter A) - colour normal , Copying: up to 18 ppm (A4) - B/W normal , Copying: up to 18 ppm (A4) - colour normal , Copying: up to 19 ppm (Letter A) - B/W normal , Copying: up to 19 ppm (Letter A) - colour normal , Copying: up to 11 ipm (A4) - B/W duplex , Copying: up to 11 ipm (A4) - colour duplex , Copying: up to 11 ipm (Letter A) - B/W duplex , Copying: up to 11 ipm (Letter A) - colour duplex , Scanning: up to 21 ppm (A4) - B/W normal , Scanning: up to 14 ppm (A4) - colour normal , Scanning: up to 21 ppm (Letter A) - B/W normal , Scanning: up to 14 ppm (Letter A) - colour normal
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x modem - RJ-11
- WEP, WPA, WPA2, TKIP, AES
- Operating System Support
- Sun Solaris 8, MS Windows XP SP3, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows XP 64-bit Edition, SuSe Linux 10.3, HP-UX 11.0, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Apple Mac OS X 10.7, Debian Linux 5.0, Red Hat Enterprise Linux 5, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 8.04, Oracle Solaris 9, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, Android, iOS, Apple Mac OS X 10.9, Windows 8.1 64-bit, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Linux 9.4, Linux 9.5, Ubuntu Linux 8.04.1, Ubuntu Linux 8.04.2, Windows RT 8, Windows 8 Pro, Windows 8 Pro 64-bit, Windows 8 Enterprise, Windows 8 Enterprise 64-bit, Windows 8 Enterprise N, Windows 8 Enterprise N 64-bit
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V (50Hz)
- 365 Watt
- Power Consumption Standby
- 10.5 Watt
- Power Consumption Sleep
- 2.7 Watt
- First Copy Out Time B/W
- 13.5 sec
- First Copy Out Time Colour
- 16 sec
- Included Accessories
- USB cable
- Consumables Included
- 1 x toner cartridge (black) - up to 1500 pages , 1 x toner cartridge (cyan) - up to 700 pages , 1 x toner cartridge (magenta) - up to 700 pages , 1 x toner cartridge (yellow) - up to 700 pages
- FCC Class B certified, CISPR 22 Class B, Laser Class 1, FCC CFR47 Part 15, TBR21, EN 60825-1, CECP, EN 61000-3-3:2008, CSA C22.2 No. 60950-1-07 Second Edition, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, ICES-003 issue 5 Class B, EN 62479:2010, IEC60950-1:2005+A1:2009, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN 55022:2010 Class B
- ENERGY STAR Certified
- 42 cm
- 41.7 cm
- 32.2 cm
- 16.3 kg
- Shipping Width
- 53.2 cm
- Shipping Depth
- 49.8 cm
- Shipping Height
- 39.8 cm
- Shipping Weight
- 21.2 kg
- Sound Emission
- 50 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
HP 201A Black Original Toner Cartridge | In Stock | £61.54 |
HP 201A Cyan Original Toner Cartridge | In Stock | £70.74 |
HP 201A Magenta Original Toner Cartridge | In Stock | £72.59 |
HP 201X High Yield Black Original Toner Cartridge | In Stock | £82.73 |
HP 201X High Yield Yellow Original Toner Cartridge | In Stock | £91.69 |
HP 201X High Yield Magenta Original Toner Cartridge | In Stock | £89.34 |
