Workgroups can easily print, copy, scan, digitally send and fax with this intuitive colour MFP series. Brilliant colour plus robust paper handling, management, security and extensibility features make this MFP a productivity powerhouse.
Easily achieve brilliant colour output
Process jobs at the MFP with the award-winning HP Easy Select control panel. Print from the walk-up USB port with a flash drive.Achieve sharp contrast and bright colour with high-gloss HP ColorSphere toner. HP ImageREt delivers crisp, consistent detail.Save time with pre-installed Original HP LaserJet print cartridges and high-capacity black cartridges.Improve productivity with paper capacity up to 2,100 sheets; sort, collate, staple or stack documents with a 900-sheet, 3-bin mailbox . -
Experience market-leading fleet management and extensibility
Save time and money: manage printing fleets with industry-leading HP Web Jetadmin. Easily control who prints in colour with HP Color Access Controls.Simple setup wizards for save-to-folder and scan-to-email functions make digital workflows more efficient.Extend your MFP capabilities with a rich portfolio of HP and third-party solutions that are easy to integrate.Make printing as mobile as you are with HP ePrint. -
Protect your data with advanced security features
Protect sensitive data stored on your HP MFP with the standard encrypted HP High-Performance Secure Hard Disk.Attach security solutions to the control panel's hardware integration pocket for a seamless appearance.Process jobs securely without compromising efficiency via PIN authentication. Expand the number of IP addresses on your network with IPv6, and implement network access control with IPsec.Create, print, scan and share sensitive business information securely via encrypted e-mail and PDFs. -
Minimise your environmental impact
Get up to 50% energy savings over competitive products, using Instant-on Technology.Save paper and conserve resources – use digital workflows, two-sided printing, PIN print and image preview.Recycle with ease – print cartridges returned through HP Planet Partners are recycled responsibly.Reduce shipping materials with HP ClearView packaging and optional high-capacity black print cartridges.
- HP Color LaserJet Enterprise CM4540fskm MFP - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 175000 impressions
- Recommended Monthly Volume
- 5000 - 9000 pages
- Max Copying Speed
- Up to 40 ppm (mono) / up to 40 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- JBIG
- Scanning
- 600 x 600 dpi
- Display
- 8.1"
- Original Size
- 76 x 137 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper
- Standard Media Capacity
- 2100 sheets
- Output Trays Capacity
- 900 sheets
- Stacker
- Included
- Stapler
- Included
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail
- Power
- AC 230 V (50Hz)
- 107 cm x 66.8 cm x 112 cm
- 88.6 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - colour
- 5000 - 9000 pages
- Display Diagonal Size
- 8.1"
- Display Features
- Touch screen
- Interface
- Localisation
- Standard Memory
- 1.28 GB 1.25 GB
- Max Supported Memory
- 1.28 GB 1.25 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF
- Image Enhancement Technology
- HP ImageREt 3600
Scanning
- Optical Resolution
- 600 x 600 dpi
- Colour Depth
- 30-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- JBIG
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 100 stations
- Fax forwarding, automatic redialing
Document & Media Handling
- Min Original Size
- 76 x 137 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm)
- 2100 sheets
- 900 sheets
- ADF - 50 sheets , Output tray - 900 sheets , 4 x input tray - 500 sheets - Legal (216 x 356 mm) , Input tray - 100 sheets
- Speed Details
- Printing: up to 40 ppm (A4) - B/W , Printing: up to 40 ppm (A4) - colour , Copying: up to 40 ppm (A4) - colour , Copying: up to 40 ppm (A4) - B/W
Finishing Equipment
- Stacker
- Included
- Stapler
- Included
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- Operating System Support
- MS Windows Server 2003, MS Windows XP SP2 or later, Apple MacOS X 10.4 or later, MS Windows Vista, MS Windows Server 2008
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V (50Hz)
- 850 Watt
- Power Consumption Standby
- 91 Watt
- Power Consumption Sleep
- 21.5 Watt
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
- FCC Class A certified, UL, cUL, EN 61000-3-2, GS, ICES-003, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, EMC, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 107 cm
- 66.8 cm
- 112 cm
- 88.6 kg
- Shipping Width
- 174.3 cm
- Shipping Depth
- 85.6 cm
- Shipping Height
- 76 cm
- Shipping Weight
- 111.4 kg
- Sound Emission
- 57 dBA (operating)
- 10 °C
- 30 °C
- 10 - 80%
Ink (2)
HP 647A Black Original LaserJet Toner Cartridge | In Stock | £140.79 |
HP 646A Yellow Original LaserJet Toner Cartridge | In Stock | £228.00 |
Other bundles (1)
HP Colour LaserJet CE247A 220V Fuser Kit | In Stock | £194.27 |
