Brand
HP Color Laser MFP 179fnw Multifunction Printer
Quicklinx: FBX7WS00 Mfr#: 4ZB97A#B19
Functionality: Copier, Printer, Fax, Scanner
Max Paper Size: 216 x 356 mm
£264.84 ex VAT
£317.80 inc VAT
Get productive MFP performance – world's smallest in-class. Print, scan, copy, and fax, produce high-quality colour results, and print and scan from your phone.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
  • Uncompromising laser quality
    This surprisingly small laser delivers exceptional quality, page after page.
  • Sharp black text, high-quality colour
    Produce sharp text, bold blacks, and crisp colour graphics.
  • The right price
    Rely on a high-performance laser printer at an affordable price.
  • The power of your printer in the palm of your hand
    Get simple setup, and print and scan from your phone, with the HP Smart app.
  • Your device, your choice
    Easily print from a variety of smartphones and tablets.
  • Extend your printing reach
    Easily share resources – access and print with wireless and Ethernet networking.
HP Color Laser MFP 179fnw - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
20000 pages
Recommended Monthly Volume
100 - 500 pages
Max Copying Speed
Up to 18 ppm (mono) / up to 4 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
Scanning
600 x 600 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
40 sheets
Media Size
76 x 148.5 mm (min) - 216 x 356 mm (max)
Media Type
Labels, recycled paper, bond paper, heavy-weight paper, extra heavy-weight paper, light-weight paper, glossy paper, preprinted paper, coloured paper
Standard Media Capacity
150 sheets
Output Trays Capacity
50 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
Office Machine Features
Wireless direct printing, AirPrint ready, Mopria certified, Mobile Printing, scan to PC, Google Cloud Print
AC 230 V (50/60Hz)
40.6 cm x 36.3 cm x 34.41 cm
14.08 kg
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
20000 pages
100 - 500 pages
Display
2 lines
Display Features
LCD display
Standard Memory
128 MB
Max Supported Memory
128 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Printing
Max Printing Speed
First Print Out Time B/W
12.6 sec
Scanning
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
10-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
PC Faxing
Fax Machine Features
Speed Dialing
100 station(s)
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
40 sheets
Min Media Size
76 x 148.5 mm
Max Media Size
A4/Letter
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), Oficio (216 x 343 mm), 216 x 356 mm
150 sheets
50 sheets
ADF - 40 sheets - A4 (210 x 297 mm) , Input tray - 150 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 50 sheets
Speed Details
Printing: up to 18 ppm (A4) - B/W (ISO) , Printing: up to 4 ppm (A4) - colour (ISO) , Copying: up to 18 ppm (A4) - B/W normal , Copying: up to 4 ppm (A4) - colour normal
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN
AC 230 V (50/60Hz)
300 Watt
Power Consumption Standby
38 Watt
Power Consumption Sleep
1.9 Watt
Consumables Included
1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 700 pages , 1 x toner cartridge (magenta) - up to 700 pages , 1 x toner cartridge (yellow) - up to 700 pages
DEMKO, FIMKO, GS, NEMKO, SEMKO, ANSI C63.4-2009, CECP, IPv6 Ready, EN 62479:2010, CNS 13438, Blue Angel Ecolabel, EN 61000-3-3:2013, EN 55024:2010, CISPR 22:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, ICES-003 issue 5, KN32, KN35, EN 55032:2012, IEC/EN 60825-1:2014 Class 1, CISPR 32:2012, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Limited warranty - 1 year
40.6 cm
36.3 cm
34.41 cm
14.08 kg
Shipping Width
50.1 cm
Shipping Depth
46.6 cm
Shipping Height
44 cm
Shipping Weight
17.38 kg
15 °C
27 °C
10 - 80% (non-condensing)
FBX7 HP 117A Black Original Laser Toner Cartridge In Stock £33.48
FBX7 HP 117A Cyan Original Toner Cartridge In Stock £35.84
FBX7 HP 120A Original Laser Imaging Drum In Stock £77.06
FBX7 HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £12.44
Functionality: Printer
Functionality: Fax
Functionality: Scanner
Brand: HP
