HP Chromebox Intel Celeron 2955U 4GB 16GB Chrome OS
Quicklinx: B5G3WS00 Mfr#: J4C96AA#ABU
  • Celeron
  • Bluetooth 4.0
  • IEEE 802.11n
Boost productivity in the office with the affordable and easy to manage HP Chromebox. Get easy access to data and effortless collaboration with your team using cloud based Google Apps for Business.
  • Lean and light
    Free up your workspaces with the impressively small, contoured, and sleek design of the HP Chromebox. At just 126 mm x 124 mm x 39 mm (4.96 in. x 4.88 in. x 1.53 in.) it fits almost anywhere.
  • VESA versatility
    Easily attach your HP Chromebox behind a display or secure it to any flat surface using the integrated VESA mount.
  • Performance and productivity in a compact footprint
    Make the most of small work spaces with an optional HP IWC for your HP Chromebox. Combine a display with your HP Chromebox and get convenient front access to all of its inputs.
  • Quick set up and take down
    Make mounting and securing storage your HP Chromebox easier with the HP Quick Release Mounting Bracket.
  • Easy to secure and manage
    The HP Chromebox has security features you need to protect your data along with optional manageability features that help reduce downtime and free up time spent on user support.
  • Help secure critical data
    The embedded Trusted Platform Module (TPM) provides hardware-based encryption to help secure your data and deter attacks from viruses and malware.
HP Chromebox - mini - Celeron 2955U 1.4 GHz - 4 GB - SSD 16 GB
Chromebox - mini
1 x Intel Celeron 2955U / 1.4 GHz (Dual-Core)
Cache Memory
2 MB
Cache Per Processor
2 MB
RAM
4 GB (installed) / 8 GB (max) - DDR3L SDRAM - PC3L-12800
Storage Controller
SATA
Hard Drive
SSD 16 GB - SATA 6Gb/s - M.2
Optical Storage
No optical drive
Card Reader
3 in 1
Graphics Controller
Intel HD Graphics
Audio Output
Integrated
GigE, 802.11b/g/n, Bluetooth 4.0
OS Provided
Google Chrome OS
Software Included
Calendar, Google Gmail, Google Drive, Google Docs, Google Sheets, Google Slides
12.6 cm x 12.4 cm x 3.9 cm
630 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year
Chromebox
Recommended Use
Small business, corporate business, education
Product Form Factor
Mini
Built-in Devices
Speaker
Processor / Chipset
CPU
Intel Celeron 2955U
Clock Speed
1.4 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
2 MB
Cache Per Processor
2 MB
RAM
Installed Size
4 GB / 8 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3L-12800
SO-DIMM 204-pin
Slots
1 (Total) / 0 (empty)
Configuration Features
1 x 4 GB
Hard Drive
SSD - M.2
1 x 16 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA - integrated
Optical Storage
No optical drive
Card Reader
3 in 1 card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Intel HD Graphics
Video Interfaces
HDMI, DisplayPort
Audio Output
Integrated
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
Slots
1 (total) / 0 (free) x SO-DIMM 204-pin
1 x HDMI , 1 x DisplayPort , 4 x USB 3.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone
Theft/Intrusion Protection
VESA Mounting Interface
100 x 100 mm
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, WEEE, A-Tick, ICES, KC, RoHS2, CIT
Power adapter
Power Provided
65 Watt
Efficiency
85%
Operating System / Software
OS Provided
Google Chrome OS
Software
Sustainability Information
ENERGY STAR Certified
12.6 cm
12.4 cm
3.9 cm
630 g
5 °C
35 °C
10 - 90% (non-condensing)
