HP Chromebox G2 Intel Celeron 3865U 4GB 32GB
Quicklinx: FBTSWS00 Mfr#: 3QM63EA#ABU
  • Celeron
  • IEEE 802.11n
Boost productivity in the office and school with the affordable and easy to manage HP Chromebox. Get quick access to data and effortless collaboration with your team using cloud based G Suite for business and Android applications.
  • Lean and light rounded design
    Free up your workspaces with the impressively small, contoured, and mountable design of the HP Chromebox. It fits almost anywhere, including behind a compatible display, .
  • Powerful performance
    Tackle work and school projects by multitasking with powerful Intel 7th or 8th gen processors, up to 16GB memory, and Android apps.
  • Easy setup
    Remote management features make it easy to configure the HP Chromebox as a virtual desktop, a kiosk, or use it for digital signage in schools and businesses.
  • Universal connectivity and charging with USB-C
    Use the optional USB-C port to charge your HP Chromebox and accessories, connect to an optional HP USB-C Dock for port and device connectivity or up to two optional USB-C -compatible 4K display for large-screen productivity.
HP Chromebox G2 - mini - Celeron 3865U 1.8 GHz - 4 GB - SSD 32 GB
Chromebox - mini
1 x Intel Celeron 3865U / 1.8 GHz (Dual-Core)
Cache Memory
2 MB
Cache Per Processor
2 MB
RAM
4 GB (installed) / 16 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
SSD 32 GB - SATA - M.2
Optical Storage
No optical drive
Card Reader
3 in 1
Graphics Controller
Intel HD Graphics 610
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
OS Provided
Google Chrome OS
14.93 cm x 14.93 cm x 4 cm
570 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year
Chromebox
Product Form Factor
Mini
Built-in Devices
Speaker
Processor / Chipset
CPU
Intel Celeron 3865U
Clock Speed
1.8 GHz
Number of Cores
Dual-Core
CPU Qty
1
Cache Memory
Installed Size
2 MB
Cache Per Processor
2 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
SSD - M.2
1 x 32 GB
Interface Type
SATA
Storage Controller
1 x SATA
Optical Storage
No optical drive
Card Reader
3 in 1 card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Ethernet Controller
Realtek RTL8151GH-CG
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 7265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
1 x HDMI , 1 x USB-C , 3 x USB 3.0 (2 front, 1 rear) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone , 2 x USB 2.0
Power adapter
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Low halogen
Power adapter
Efficiency
85%
Operating System / Software
OS Provided
Google Chrome OS English
ENERGY STAR Certified
14.93 cm
14.93 cm
4 cm
570 g
