HP Chromebook x360 G1 Pentium Gold 4415U 4GB 32GB 14" Chrome OS
Quicklinx: F55CWS00 Mfr#: 6BP69EA#ABU
Display Size: 14in
Processor Model: 4415U
Operating System: Google Chrome OS 64
Installed Memory: 8GB
Hard Drive Capacity: 32GB
  • IEEE 802.11n
£400.52 ex VAT
£480.62 inc VAT
Get a device engineered for the modern workforce with the versatile HP Chromebook x360 14 G1, our first Chromebook to support up to an Intel Core i7 processor. Be a productivity powerhouse with the fast, simple, and secure Chrome OS , Android apps, and full HD 14" diagonal touchscreen.
  • Designed to dazzle, however and wherever you work
    Set a new style standard with the beautiful silhouette of a silver, 16 mm thin Chromebook with an aluminum cover and keyboard deck, diamond-cut touchpad, and narrow-bezel touchscreen display. Work easily in low light with the backlit keyboard.
  • Find your sweet spot
    Adapt to any setting, project or presentation with a 360° hinge that flips and folds the Chromebook into notebook, stand, tent, and tablet modes so you can type, touch, and capture to your heart's content.
  • Master multi-tasking, meetings, and e-mails
    Power through every task with the boost of an 8th Gen Intel processor and up to 13 hours battery life. Open and view more apps at one time on the narrow-bezel screen with up to 64 GB storage and 16 GB memory. Streamline connectivity with USB-C .
HP Chromebook x360 14 G1 - 14" - Pentium Gold 4415U - 8 GB RAM - 32 GB eMMC - UK
Chromebook - flip design
Operating System
Chrome OS 64
Intel Pentium Gold 4415U / 2.3 GHz / 2 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
32 GB eMMC
Display
14" WLED touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 610
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
3-cell
Sleek metal
32.55 cm x 22.7 cm x 1.6 cm
1.6 kg
Environmental Standards
TCO Certified Notebooks 5
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Operating System
Google Chrome OS 64
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
2 MB
64-bit Computing
RAM
8 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2133 MHz
Rated Speed
2133 MHz
Storage
Main Storage
32 GB SSD eMMC
Display
14" - IPS
LCD Backlight Technology
WLED backlight
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
220 cd/m²
Full HD ultra wide-viewing angle (UWVA) BrightView eDP, narrow-bezel design
Audio & Video
Graphics Processor
Camera
Yes - HD
Video Resolutions
720p
Sound
Stereo speakers
Audio Features
Bang & Olufsen Audio
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Multi-touch touchpad, touchpad with gesture support
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265
Dual stream (2x2)
3-cell Lithium Ion
60.9 Wh
AC Adapter
Input
Output
45 Watt
Connections & Expansion
2 x USB-C 3.1 Gen 1 (charging) , USB 3.1 Gen 1 (charging) , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Google Drive (100 GB Cloud Storage) (free for 1 year)
Sleek metal
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
USB-C power adapter
Localization
1.6 kg
TCO Certified
Display Size: 14in
Optical Storage: None
Graphics: Intel HD Graphics 610
Hard Drive Type: SSD
Touchscreen: Yes
Type: Laptop
Brand: HP
Price Range Ex VAT: 300 - 500
