Get a device engineered for the modern workforce with the versatile HP Chromebook x360 14 G1, our first Chromebook to support up to an Intel Core i7 processor. Be a productivity powerhouse with the fast, simple, and secure Chrome OS , Android apps, and full HD 14" diagonal touchscreen.
Designed to dazzle, however and wherever you work
Set a new style standard with the beautiful silhouette of a silver, 16 mm thin Chromebook with an aluminum cover and keyboard deck, diamond-cut touchpad, and narrow-bezel touchscreen display. Work easily in low light with the backlit keyboard. -
Find your sweet spot
Adapt to any setting, project or presentation with a 360° hinge that flips and folds the Chromebook into notebook, stand, tent, and tablet modes so you can type, touch, and capture to your heart's content. -
Master multi-tasking, meetings, and e-mails
Power through every task with the boost of an 8th Gen Intel processor and up to 13 hours battery life. Open and view more apps at one time on the narrow-bezel screen with up to 64 GB storage and 16 GB memory. Streamline connectivity with USB-C .
- HP Chromebook x360 14 G1 - 14" - Pentium Gold 4415U - 8 GB RAM - 32 GB eMMC - UK
- Product Type
- Chromebook - flip design
- Operating System
- Chrome OS 64 - English
- Processor
- Intel Pentium Gold 4415U / 2.3 GHz / 2 MB Cache
- Memory
- 8 GB DDR4 (provided memory is soldered)
- Storage
- 32 GB eMMC
- Display
- 14" WLED touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 610
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 3-cell
- Sleek metal
- 32.55 cm x 22.7 cm x 1.6 cm
- 1.6 kg
- Localisation
- Environmental Standards
- TCO Certified Notebooks 5
- Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
- Product Type
- Operating System
- Google Chrome OS 64 - English
Processor / Chipset
- CPU
- Number of Cores
- Dual-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 8 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2133 MHz
Storage
- Main Storage
- 32 GB SSD eMMC
Display
- 14" - IPS
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 220 cd/m²
- Bezel Type
- Flat front
- Full HD ultra wide-viewing angle (UWVA) BrightView eDP, narrow-bezel design
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Sound
- Stereo speakers
- Audio Features
- Bang & Olufsen Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-touch touchpad, touchpad with gesture support
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265
- Dual stream (2x2)
- Technology
- 3-cell Lithium Ion
- Capacity
- 60.9 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- 2 x USB-C 3.1 Gen 1 (charging) , USB 3.1 Gen 1 (charging) , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Google Drive (100 GB Cloud Storage) (free for 1 year)
- Sleek metal
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- USB-C power adapter
- Localization
- 1.6 kg
- TCO Certified
