HP Chromebook 14A G5 AMD A4-9120C 4GB 32GB 14" Google Chrome OS 64
Quicklinx: FBQWWS00 Mfr#: 7DD00EA#ABU
  • IEEE 802.11n
Master productivity with the HP Chromebook 14A G5, a 14" diagonal Chromebook with the manageable, secure, and intuitive Chrome OS . The durable design is driven by the latest AMD processors, has future-ready, universal USB-C compatibility, and a choice of HD or FHD IPS panel.
  • Speed through your day
    Launch more apps, quickly browse the web, and manage battery power with the latest AMD processors, 4 GB memory, and up to 64 GB eMMC storage. Connect in large spaces with 2x2 802.11ac and MIMO wireless. Charge your device and add accessories with USB-C .
  • Durable with a modern aesthetic
    Deploy a sleek Chromebook that's just <19mm thin and still stands up to daily wear and tear with a durable 180° hinge. It also undergoes MIL-STD 810G and IP 41 testing.
  • Built-in interactivity
    Collaborate across the room and the world with an optional FHD IPS touchscreen, 180° hinge that lies completely flat, wide-angle HD webcam, dual mic, and access to Google Meetings. See clearly in dark rooms with the optional backlit keyboard.
HP Chromebook 14A G5 - 14" - A4 9120C - 4 GB RAM - 32 GB eMMC - UK
Chromebook
Operating System
Chrome OS - English
AMD A4 9120C / 1.6 GHz (2.4 GHz) / 1 MB Cache
4 GB DDR4 (provided memory is soldered)
Storage
32 GB eMMC
Display
14" LED backlight 1366 x 768 / HD
Graphics
AMD Radeon R4
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
2-cell
33.7 cm x 22.6 cm x 1.83 cm
1.57 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year
Chromebook
Operating System
Google Chrome OS - English
Processor / Chipset
CPU
Max Turbo Speed
2.4 GHz
Number of Cores
Dual-Core
Cache
1 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
DDR4 SDRAM
Speed
1866 MHz
Rated Speed
1866 MHz
Storage
Main Storage
32 GB eMMC
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
220 cd/m²
Colour Gamut
67% sRGB
HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
AMD Radeon R4
Camera
Yes - HD
Video Resolutions
720p
Sound
Stereo speakers, array microphone
High Definition Audio
Input
Keyboard, touchpad
Keyboard Layout
Spill-resistant, multi-touch touchpad, gesture function, pick resistant
Communications
Wireless
Miracast, dual stream (2x2)
2-cell lithium polymer
47.36 Wh
AC Adapter
Output
45 Watt
Connections & Expansion
2 x USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , 2 x USB 3.1 Gen 1 (Sleep & Charge) , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Google H1 security chip
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
USB-C power adapter
Low halogen
Localization
1.57 kg
ENERGY STAR Certified
