HP Chromebook 14-db0003na 14" AMD A4 9120 4GB 32GB Grey
Quicklinx: FGFMWS00 Mfr#: 6AS60EA#ABU
Type: Chromebook
Display Size: 14in
Processor Model: A4-9120
Operating System: Google Chrome OS
Installed Memory: 4GB, 4GB
More than 50 in stock
£190.84 ex VAT
£229.00 inc VAT
Express delivery Order within the next 17 hours for delivery tomorrow
Stay productive and entertained with the Chromebook 14 through a seamless Chrome experience and easy access to your favorite Android apps via the Google Play Store. Do more, experience more with plenty of performance, all-day battery life, and entertainment features like Audio by B&O PLAY. Perfect for home, work, and school.
  • Immersive entertainment
    Make this the perfect PC for your daily dose of entertainment. Includes dual speakers, and Audio by B&O. Plus, a 180° hinge that makes it easy to collaborate and share with others.
  • Work or play
    Delivers plenty of power to take on your day, thanks to an AMD processor. Get great connectivity, and a long battery life.
  • The best of Chrome OS
    This Chromebook gives you the best of Chrome OS enabling you to go online easily, quickly, and securely. Enjoy access to thousands of Android apps right on your desktop.
HP Chromebook 14-db0003na - 14" - A4 9120 - 4 GB RAM - 32 GB eMMC - UK
Chromebook
Operating System
Chrome OS - English
AMD A4 9120 / 2.2 GHz (2.5 GHz) / 1 MB Cache
4 GB DDR4 (provided memory is soldered)
Storage
32 GB eMMC
Display
14" WLED 1366 x 768 / HD
Graphics
AMD Radeon R3
Keyboard
Integrated Webcam
Bluetooth 4.2, 802.11a/b/g/ac
2-cell
Chalkboard grey, resin texture with registered IMR keyboard deck and base
33.7 cm x 22.7 cm x 1.83 cm
1.54 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - pick-up and return
Chromebook
Operating System
Google Chrome OS - English
Processor / Chipset
CPU
Max Turbo Speed
2.5 GHz
Number of Cores
Dual-Core
Cache
1 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
DDR4 SDRAM
Rated Speed
1866 MHz
SO-DIMM 260-pin
Storage
Main Storage
32 GB SSD eMMC
Display
14"
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HD standard-viewing angle (SVA) anti-glare
Audio & Video
Graphics Processor
AMD Radeon R3
Camera
Yes - HD
Camera Features
HP TrueVision HD
Sound
Stereo speakers, dual array microphone
Input
Keyboard, touchpad
Keyboard Layout
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Atheros QCA6174A-5
Dual stream (2x2)
2-cell Lithium Ion
47.36 Wh
AC Adapter
Output
45 Watt
Connections & Expansion
2 x USB-C 3.1 Gen 1 (Sleep & Charge) , Headphone/microphone combo jack , 2 x USB 2.0
Memory Card Reader
Yes (microSD)
Theft/Intrusion Protection
Security Slot Type
Kensington mini security slot
Power adapter, H1 Secure Microcontroller
Localization
1.54 kg
ENERGY STAR Certified
Type: Chromebook
Display Size: 14in
Hard Drive Capacity: 32GB
Optical Storage: None
Graphics: AMD Radeon R3
Hard Drive Type: SSD
Brand: HP
Stock Status: In stock
