Product
HP Chromebook 14 Celeron N2940 Chrome OS 4GB/32GB 14"
Quicklinx: C3SLWS00 Mfr#: P5T61EA#ABU
  • Celeron
  • IEEE 802.11n
  • Bluetooth 4.0
Make the move to a cloud-based infrastructure with the HP Chromebook 14. Get down to business with Intel Celeron processors, an optional Full HD IPS panel, Citrix -certified VDI compatibility, and access to Google Apps for Work.
  • Power through your day
    Quickly and efficiently launch apps, browse the web, and manage battery life with reliable Intel Celeron processors. Collaborate freely from almost any angle with a Full HD IPS panel and Google Hangouts with noise suppression software.
  • VDI ready
    Get right to work with an HP Chromebook that's certified for Citrix so you can integrate it seamlessly into your high-performance enterprise virtual desktop environment.
  • Manageability and maintenance made simple
    Breathe easy with the low-maintenance Chrome OS , which updates automatically and has virus protection built in.
  • Quiet mobility
    Hear a pin drop with the remarkably quiet HP Chromebook 14 that doesn't distract because it ditches the fan, plus it's so compact and light that you can work almost anywhere.
HP Chromebook 14 G4 - 14" - Celeron N2940 - 4 GB RAM - 32 GB SSD - UK
Chromebook
Operating System
Chrome OS - English
Intel Celeron N2940 / 1.83 GHz (2.25 GHz) / 2 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
32 GB - eMMC SSD
Display
14" WLED 1920 x 1080 / Full HD
Graphics
Intel HD Graphics
Input Device
ClickPad
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac
3-cell - up to 9.25 hours
Security
Trusted Platform Module (TPM 1.2) Security Chip
34.4 cm x 24 cm x 1.78 cm
1.71 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Limited warranty - battery - 1 year
Chromebook
Operating System
Google Chrome OS - English
Processor / Chipset
CPU
Max Turbo Speed
2.25 GHz
Number of Cores
Quad-Core
Cache
2 MB
64-bit Computing
RAM
4 GB (1 x 4 GB)
Max RAM Supported
4 GB
DDR3L SDRAM
Speed
1600 MHz
Storage
Main Storage
32 GB SSD - (eMMC)
Display
14"
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Slim Design, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Audio & Video
Graphics Processor
Intel HD Graphics
Camera
Yes - 1280 x 720
Camera Features
HP TrueVision HD
Sound
Stereo speakers, microphone
High Definition Audio
Input
Keyboard, ClickPad
Keyboard Layout
Multi-touch touchpad, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7260
IEEE 802.11, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell lithium polymer
37 Wh
Run Time
Up to 9.25 hours
AC Adapter
Output
45 Watt
Connections & Expansion
USB 3.0 , 2 x USB 2.0 , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
HP Registration, Google Drive (100 GB Cloud Storage) (free for 2 years)
Security
Security lock slot (cable lock sold separately), microphone with echo and noise-cancellation, 1 USB 3.0 charging port
Power adapter
Localization
1.71 kg
ENERGY STAR Certified
