Foster creativity, collaboration, and learning with the durable, powerful HP Chromebook 11A G6 EE. Designed with co-molded rubber, reinforced corners, and a manageable, secure, and intuitive Chrome OS™, it enables access to thousands of educational Android™ apps and has universal USB-C™ connectivity and charging.
All decked out for the day ahead
Give students a sleek Chromebook that redefines rugged. It measures just <19mm thin and has co-molded rubber contact points, a strengthened corner design, durable 180° hinge, and undergoes MIL-STD 810G and 70 cm drop on concrete testing. -
Power through every project
Quickly launch apps, support fast web browsing, and efficiently manage battery life with the AMD A4-9120C APU processor, 4 GB memory, and eMMc storage up to 32 GB. -
Encourage collaborative learning
Enable engaging group discussions with an optional HD IPS touchscreen that supports easy viewing from multiple angles and a 180° hinge that lies completely flat. Connect in dense environments with 2x2 802.11ac wireless and MIMO. -
Universal connectivity and charging with USB-C
Use the USB-C port to access and charge your USB-C accessories from your Chromebook or charge your Chromebook from any USB-C adapter.
- HP Chromebook 11A G6 - Education Edition - 11.6" - A4 9120C - 4 GB RAM - 16 GB eMMC - UK
- Product Type
- Chromebook
- Operating System
- Chrome OS 64 - English
- Processor
- AMD A4 9120C / 1.6 GHz (2.4 GHz) / 1 MB Cache
- Memory
- 4 GB DDR4 (provided memory is soldered)
- Storage
- 16 GB eMMC
- Display
- 11.6" WLED 1366 x 768 / HD
- Graphics
- AMD Radeon R4
- Input Device
- ClickPad
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 2-cell - up to 10 hours
- 30.6 cm x 20.8 cm x 1.81 cm
- 1.28 kg
- Localisation
- Product Type
- Chromebook
- Operating System
- Google Chrome OS 64 - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.4 GHz
- Number of Cores
- Dual-Core
- Cache
- 1 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
- Speed
- 1866 MHz
- Rated Speed
- 1866 MHz
Storage
- Main Storage
- 16 GB SSD eMMC
Display
- 11.6"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Brightness
- 220 cd/m²
- HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- AMD Radeon R4
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Sound
- Stereo speakers, array microphone
- High Definition Audio
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, gesture function, pick resistant
Communications
- Wireless
- Bluetooth Class
- Class 2
- Miracast
- IEEE 802.11, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 2-cell lithium polymer
- Capacity
- 47.36 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 5 / 9 / 12 / 15 V
Connections & Expansion
- 2 x USB-C 3.1 Gen 1/DisplayPort (Power Delivery) , 2 x USB 2.0 , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Classroom Management, Google Drive (100 GB Cloud Storage) (free for 2 years)
- Google H1 security chip
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- USB-C power adapter
- Localization
- 1.28 kg
