Empower students to create, collaborate, and learn with the rugged HP Chromebook 11 EE. Built with co-molded rubber, reinforced corners, and a manageable, secure, and intuitive Chrome OS , it enables access to thousands of educational Android apps and has universal USB-C connectivity and charging.
Sleek, beautiful, and classroom-ready
Give students a Chromebook that reinvents rugged. It measures a sleek <19mm thin and has co-molded rubber contact points, a strengthened corner design, durable 180° hinge, and passes MIL-STD 810G testing. -
Speed through classwork and assignments
Quickly launch apps, support fast web browsing, efficiently manage battery power, and get up to a 26% performance improvement with the latest multi-core 7th Gen Intel processors, memory up to 8 GB, and eMMc storage up to 64 GB. -
Inspire learning through collaboration
Collaborate easily with an optional HD IPS touchscreen and 180° hinge that lies completely flat for engaging group discussions. Stay connected in large spaces with 2x2 802.11ac wireless. -
Universal connectivity and charging with USB-C
Use the USB-C port to access and charge your USB-C accessories from your Chromebook or charge your Chromebook from any USB-C adapter.
- HP Chromebook 11 G6 - Education Edition - 11.6" - Celeron N3350 - 4 GB RAM - 32 GB eMMC - UK
- Product Type
- Chromebook
- Operating System
- Google Chrome OS 64 - English
- Processor
- Intel Celeron N3350 / 1.1 GHz (2.4 GHz) / 2 MB Cache
- Memory
- 4 GB LPDDR4 (provided memory is soldered)
- Storage
- 32 GB - eMMC
- Display
- 11.6" WLED 1366 x 768 / HD
- Graphics
- Intel HD Graphics 500
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 2-cell - up to 13 hours
- Chalkboard grey
- 30.6 cm x 20.8 cm x 1.8 cm
- 1.24 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year , Limited warranty - battery - 1 year
- Product Type
- Chromebook
- Operating System
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.4 GHz
- Number of Cores
- Dual-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Technology
- LPDDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2400 MHz
Storage
- Main Storage
- 32 GB SSD - (eMMC)
Display
- 11.6"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Brightness
- 220 cd/m²
- 45% colour gamut, Slim Design, HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Sound
- Stereo speakers, microphone
- High Definition Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, gesture function
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
- Miracast
- IEEE 802.11, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 2-cell Lithium Ion
- Capacity
- 47.36 Wh
- Run Time
- Up to 13 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 5 / 9 / 12 / 15 V
Connections & Expansion
- 2 x USB-C 3.1 , 2 x USB 3.1 Gen 1 (Sleep & Charge) , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Google Drive (100 GB Cloud Storage) (free for 2 years), HP Classroom Manager
- Chalkboard grey
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- USB-C power adapter
- Localization
- 1.24 kg
- ENERGY STAR Certified
